Simo Posted June 8, 2023 Posted June 8, 2023 Hi, i've an Hdd of 1TB and i would like to use it as a storage for my orange pi 5. I would like to install armbian and boot directly from the Hdd the operating system. I need only to buy the adaptor for sata interface. Before to buy it i've read some posts and also watched this video https://www.youtube.com/watch?v=Z5-sZt_O51w&pp=ygUZb3JhbmdlIHBpIDUgYm9vdCBmcm9tIHVzYg%3D%3D and this guy was not able to boot the orange pi directly from the Hdd because the adaptor was creating some problem. 1) I would like to ask you if someone knows if in this months this problem was been resolved or not 2) If it is not yet solved, i would like to install the OS and boot it from the MicroSD card and use the Hdd with the adaptor as a storage (like a big usb stick), does in this way the Hdd will be visible and would i be able to use it? 0 Quote
NicoD Posted June 8, 2023 Posted June 8, 2023 You do have a way to power your HDD do you? Or is it an SSD? A sata adapter only powers 2.5" devices. If it's 3.5" HDD then you need 12V. I would advice not to boot from HDD. If something goes wrong with the image on an sd-card then you just replace the sd-card without loosing anything from the HDD. Do use a good sd-card. Hard drives also aren't super fast, so no real speed benifit in using that. 1 Quote
Turbine Posted June 19, 2023 Posted June 19, 2023 If ssd, self powered USB hub works. Although I'd just mount it and keep booting off the SD. 0 Quote
