helios Posted June 11, 2023 Share Posted June 11, 2023 Hi, I am trying to install/boot latest Armbian Jammy minimal on Tanix TX3-H box without success. Technical Details: Box: Tanix TX3-H (BZ) CPU: S905X3 Memory: 4 GB Storage: 64 GB Box: https://androidpctv.com/review-tanix-tx3-s905x3-opinion/ Board Images: Attached I created bootable both usb and sdcard but the box boots into a dark blank screen. I followed the Amlogic boxes instructions but no luck. Tried the different DTBs from the Meson SM1 series, none booted up. Any guidance on using Armbian on this box will be very helpful and appreciated 🙏 0 Quote Link to comment Share on other sites More sharing options...
spirake Posted June 12, 2023 Share Posted June 12, 2023 Hello I also tried the last version and it doesn't start. The only version that starts from usb is Armbian_23.02.0-trunk_Aml-s9xx-box_kinetic_edge_6.0.11_xfce_desktop 1 Quote Link to comment Share on other sites More sharing options...
SteeMan Posted June 12, 2023 Share Posted June 12, 2023 Can you add the version information for the builds you are trying that are not working. I'm otherwise just guessing. 0 Quote Link to comment Share on other sites More sharing options...
helios Posted June 13, 2023 Author Share Posted June 13, 2023 Hi @SteeMan I checked both the server and minimal versions from the latest available release: Armbian_23.5.1_Aml-s9xx-box_jammy_current_6.1.30_minimal.img.xz Armbian_23.5.1_Aml-s9xx-box_jammy_current_6.1.30.img.xz https://redirect.armbian.com/aml-s9xx-box/archive/Armbian_23.5.1_Aml-s9xx-box_jammy_current_6.1.30_minimal.img.xz I tried all the DTBs from SM1 series. 0 Quote Link to comment Share on other sites More sharing options...
helios Posted June 13, 2023 Author Share Posted June 13, 2023 (edited) After seeing @spirake 's thread, I was wondering about the Armbian version running in my other TV Box(Beelink GT1 Ultimate - S912). Luckily I had a copy of the image and flashed it to the USB drive. The image version is Armbian_23.02.2_Aml-s9xx-box_jammy_current_6.1.11 To my surprise, it worked! The box booted up and started working @SteeMan The Wifi, BT, HDMI, and Ethernet look good. RAM, Storage sizes look good. I even installed the Armbian to EMMC successfully. I guess something is wrong with the latest image version and therefore doesn't boot. Picture of Armbian_23.02.2_Aml-s9xx-box_jammy_current_6.1.11 up and running in Tanix TX3-H Edited June 13, 2023 by helios Added more details 0 Quote Link to comment Share on other sites More sharing options...
spirake Posted June 13, 2023 Share Posted June 13, 2023 This is functional 0 Quote Link to comment Share on other sites More sharing options...
spirake Posted June 13, 2023 Share Posted June 13, 2023 (edited) And this image does not start, the screen remains black Armbian_23.5.0-trunk.240_Aml-s9xx-box_bookworm_edge_6.2.16_xfce_desktop.img Edited June 13, 2023 by spirake 0 Quote Link to comment Share on other sites More sharing options...
boxonly26 Posted June 13, 2023 Share Posted June 13, 2023 @spirake use your last working dtb and uboot, I also have the same problem with latest armbian trunk build, copy my dtb and uboot from last working img solved my problem. I have wechip v9 s905x3 tvbox with 100m eth, 6222B-SRC Wi-Fi Module, 4gb/32gb 0 Quote Link to comment Share on other sites More sharing options...
SteeMan Posted June 13, 2023 Share Posted June 13, 2023 1 hour ago, boxonly26 said: copy my dtb and uboot from last working img The u-boot-s905x2-s922 file hasn't changed. So it shouldn't be necessary to copy that. Can you look at the file size of the two and also run diff on the two files. Again they should be the same as that file hasn't changed. If they are different, then something in the build process is causing a problem. 0 Quote Link to comment Share on other sites More sharing options...
boxonly26 Posted June 13, 2023 Share Posted June 13, 2023 (edited) @SteeMan the latest uboot from armbian community (Ive downloaded last week armbian bookworm trunk img) have different size with my working stable bullseye armbian img downloaded few months ago from archived armbian stable (both link are from your instruction). I use sei610 dtb and s905x2 renamed to uboot.ext Edited June 13, 2023 by boxonly26 0 Quote Link to comment Share on other sites More sharing options...
helios Posted June 13, 2023 Author Share Posted June 13, 2023 The size of u-boot-s905x2-s922 file is unchanged but the file count is different between 2 versions in boot partition... 0 Quote Link to comment Share on other sites More sharing options...
SteeMan Posted June 13, 2023 Share Posted June 13, 2023 @helios thanks for posting that. One thing that has changed between the two versions is the name of the kernel image. It used to be uImage and is now Image. Can you look at the extlinux.conf files on the two versions to make sure they are changed appropriately for the kernel name change? 0 Quote Link to comment Share on other sites More sharing options...
helios Posted June 14, 2023 Author Share Posted June 14, 2023 (edited) It seems to be updated correctly... There are mentions about image boot issues in the Armbian Leaflet #8 and AR-1765 in release changelog. May be these are all related to the issue we are facing 🤔 Edited June 14, 2023 by helios Add image issues 0 Quote Link to comment Share on other sites More sharing options...
helios Posted June 15, 2023 Author Share Posted June 15, 2023 (edited) For debugging, I copied over just the u-boot and dtb from another unofficial source. First, I replaced just the DTB and no change. But after replacing the u-boot, the box booted up but it was very laggy and had issues like keyboard inputs were randomly working, OS(Jammy) freezed, box was heating up etc... I have reverted back again to Armbian_23.02.2_Aml-s9xx-box_jammy_current_6.1.11 Edited June 15, 2023 by helios 0 Quote Link to comment Share on other sites More sharing options...
boxonly26 Posted June 16, 2023 Share Posted June 16, 2023 latest armbian community build https://github.com/armbian-alpha/os/releases/download/23.8.0-trunk.53/Armbian_23.8.0-trunk.53_Aml-s9xx-box_bookworm_edge_6.2.16_minimal.img.xz#aml-s9xx-box works flawless after i've changed the uboot from facebook group / unofficial armbian u-boot. I'm using x96air dtb for my wechip v9 aml s905x3 soc, wifi and 100m ethernet works without problem, i also installed pi-apps. idk if this breaks forum rules if i place this uboot u-boot.ext 2 Quote Link to comment Share on other sites More sharing options...
helios Posted June 16, 2023 Author Share Posted June 16, 2023 When I tried the latest trunk(Armbian_23.8.0-trunk.53_Aml-s9xx-box_lunar_edge_6.2.16_minimal), the box booted up but it was very buggy. There were some FS errors during storage expand on first boot and even the OS initialization failed. But the errors were gone after 3 restarts. Something broke after 23.5.1 release... 😟 0 Quote Link to comment Share on other sites More sharing options...
boxonly26 Posted June 16, 2023 Share Posted June 16, 2023 I wanna switch to old armbian stable image but i couldn't download from armbian mirrors. I have a couple in my pc but my brother borrowed my ram sticks. This latest trunk build can't install some apps from pi-apps, it says error upgrading package even for minecraft bedrock 🙃 0 Quote Link to comment Share on other sites More sharing options...
well83 Posted July 29, 2023 Share Posted July 29, 2023 @boxonly26https://fi.mirror.armbian.de/archive/aml-s9xx-box/archive/ 0 Quote Link to comment Share on other sites More sharing options...
helios Posted December 19, 2023 Author Share Posted December 19, 2023 Hi @SteeMan I gave another shot of installing latest stable Armbian(Armbian_23.11.1_Aml-s9xx-box_jammy_current_6.1.63.img.xz) on TX3. This time both of my TX3(BZ) boxes booted up and installed smoothly in 1st attempt itself without any errors. Everything is working great so far 👍 👌 I wish the spirit of Armbian stays alive forever. It gave a second life and real purpose to these boxes 🙏 My heartfelt thanks to the entire Armbian team and unsung heroes of the Amlogic TV boxes testers 🙇 0 Quote Link to comment Share on other sites More sharing options...
Alexx Posted February 15 Share Posted February 15 Hi @helios what dtb are you using to boot the image? 0 Quote Link to comment Share on other sites More sharing options...
helios Posted March 11 Author Share Posted March 11 I tested all the DTBs from SM1 series and settled down with meson-sm1-h96-max.dtb ... meson-sm1-sei610.dtb also works fine... 0 Quote Link to comment Share on other sites More sharing options...
