Guest Posted June 13, 2023 Share Posted June 13, 2023 (edited) Hello! After update my BPi M2+ to Armbian 23.02.2 Focal with Linux 5.15.93-sunxi, the network is complett fucked up! /etc/network/interfaces (my default settings for my LAN and networksettings) is now ignored. armbian-config can only setup LO and it is even not saved after changing DNS IP. The device name is changed from eth0 to end0 (without any warnings!!!). The network settings are now only throu DHCP. that's not what I want! Every changes are ignored! WTF is going on with this distribution! My complett networks settings are gone or ignored! Can anyone tell me, how I get my old interfaces settings back?!!! Edit: After checking it a bit further, I found that armbian-config even overwrites my settings and doesn't even apply the settings I make in armbian-config. Whereas I can't even set the actual network interface! Who has fabricated this garbage! Edited June 13, 2023 by RSU Link to comment Share on other sites More sharing options...
Werner Posted June 13, 2023 Share Posted June 13, 2023 As most software this comes without any warranty. If you do not like it feel free to use any other comparable distribution. Either that or adjust your attitude. Like this nobody will care. Link to comment Share on other sites More sharing options...
