I have been running Armbian_5.14_Orangepipc_Ubuntu_xenial_3.4.112 that has been upgraded to the 4.7.3 kernel via apt.
Yesterday I allowed it to update to 4.8.3 and it won't boot anymore. Any ideas? I have reverted to the 4.7.3 kernel from a backup and it works again. I have isolated it to the packages :linux-dtb-dev-sun8i linux-firmware-image-dev-sun8i linux-headers-dev-sun8i  linux-image-dev-sun8i
Here is the startup output from serial port:
OPTIONS: I18n
Compiled on Feb  7 2016, 13:37:27.
Port /dev/rfcomm2, 18:35:27
Press CTRL-A Z for help on special keys
S=ca���A��`�b�``�g`C�95�ready
DRAM:  1 GiB
MMC:   SUNXI SD/MMC: 0
In:    serial
Out:   serial
Err:   serial
Net:   phy interface0
eth0: ethernet@1c30000
Hit any key to stop autoboot:  0
switch to partitions #0, OK
mmc0 is current device
Scanning mmc 0:1...
Found U-Boot script /boot.scr
2597 bytes read in 165 ms (14.6 KiB/s)
gpio: pin PL10 (gpio 298) value is 1
gpio: pin PG11 (gpio 203) value is 1
0 bytes read in 174 ms (0 Bytes/s)
0 bytes read in 165 ms (0 Bytes/s)
23462 bytes read in 1160 ms (19.5 KiB/s)
8783428 bytes read in 679 ms (12.3 MiB/s)
5879832 bytes read in 690 ms (8.1 MiB/s)
## Loading init Ramdisk from Legacy Image at 42000000 ...
   Image Name:   uInitrd
   Image Type:   ARM Linux RAMDisk Image (gzip compressed)
   Data Size:    8783364 Bytes = 8.4 MiB
   Load Address: 00000000
   Entry Point:  00000000
   Verifying Checksum ... OK
## Flattened Device Tree blob at 49000000
   Booting using the fdt blob at 0x49000000
   Loading Ramdisk to 4979f000, end 49fff604 ... OK
   Loading Device Tree to 49796000, end 4979eba5 ... OK
Using machid 0x1029 from environment
Starting kernel ...
Uncompressing Linux... done, booting the kernel.
[    0.000000] Booting Linux on physical CPU 0x0
[    0.000000] Linux version 4.8.3-sun8i (root@xenial) (gcc version 5.4.0 201606
[    0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c5387d
[    0.000000] CPU: div instructions available: patching division code
[    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instructie
[    0.000000] OF: fdt:Machine model: Xunlong Orange Pi PC
[    0.000000] cma: Reserved 16 MiB at 0x7ec00000
[    0.000000] Memory policy: Data cache writealloc
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: Using PSCI v0.1 Function IDs from DT
[    0.000000] percpu: Embedded 14 pages/cpu @ef6a9000 s25420 r8192 d23732 u5734
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pa6
[    0.000000] Kernel command line: console=ttyS0,115200 console=tty1 root=UUID7
[    0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[    0.000000] Memory: 1000308K/1048576K available (8192K kernel code, 307K rwd)
[    0.000000] Virtual kernel memory layout:
[    0.000000]     vector  : 0xffff0000 - 0xffff1000   (   4 kB)
[    0.000000]     fixmap  : 0xffc00000 - 0xfff00000   (3072 kB)
[    0.000000]     vmalloc : 0xf0800000 - 0xff800000   ( 240 MB)
[    0.000000]     lowmem  : 0xc0000000 - 0xf0000000   ( 768 MB)
[    0.000000]     pkmap   : 0xbfe00000 - 0xc0000000   (   2 MB)
[    0.000000]     modules : 0xbf000000 - 0xbfe00000   (  14 MB)
[    0.000000]       .text : 0xc0008000 - 0xc0900000   (9184 kB)
[    0.000000]       .init : 0xc0c00000 - 0xc0d00000   (1024 kB)
[    0.000000]       .data : 0xc0d00000 - 0xc0d4cde0   ( 308 kB)
[    0.000000]        .bss : 0xc0d4e000 - 0xc0d9a880   ( 307 kB)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[    0.000000] Hierarchical RCU implementation.
[    0.000000]  Build-time adjustment of leaf fanout to 32.
[    0.000000] NR_IRQS:16 nr_irqs:16 16
[    0.000000] arm_arch_timer: Architected cp15 timer(s) running at 24.00MHz (p.
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycless
[    0.000006] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398s
[    0.000016] Switching to timer-based delay loop, resolution 41ns
[    0.000214] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, maxs
[    0.000521] Console: colour dummy device 80x30
[    0.000989] console [tty1] enabled
[    0.001024] Calibrating delay loop (skipped), value calculated using timer f)
[    0.001060] pid_max: default: 32768 minimum: 301
[    0.001272] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[    0.001296] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[    0.002051] CPU: Testing write buffer coherency: ok
[    0.002390] CPU0: update cpu_capacity 1024
[    0.002416] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[    0.002454] Setting up static identity map for 0x40100000 - 0x40100058
[    0.014358] CPU1: update cpu_capacity 1024
[    0.014365] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[    0.025023] CPU2: update cpu_capacity 1024
[    0.025028] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
[    0.035691] CPU3: update cpu_capacity 1024
[    0.035696] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
[    0.035764] Brought up 4 CPUs
[    0.035876] SMP: Total of 4 processors activated (192.00 BogoMIPS).
[    0.035894] CPU: All CPU(s) started in HYP mode.
[    0.035910] CPU: Virtualization extensions available.
[    0.036895] devtmpfs: initialized
[    0.043238] VFP support v0.3: implementor 41 architecture 2 part 30 variant 5
[    0.043630] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, ms
[    0.044269] xor: measuring software checksum speed
[    0.135557]    arm4regs  :  1263.200 MB/sec
[    0.235614]    8regs     :   877.200 MB/sec
[    0.335670]    32regs    :   875.600 MB/sec
[    0.435729]    neon      :  1286.000 MB/sec
[    0.435748] xor: using function: neon (1286.000 MB/sec)
[    0.435849] pinctrl core: initialized pinctrl subsystem
[    0.436804] NET: Registered protocol family 16
[    0.437875] DMA: preallocated 256 KiB pool for atomic coherent allocations
[    0.485871] cpuidle: using governor ladder
[    0.515877] cpuidle: using governor menu
[    0.516226] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint.
[    0.516255] hw-breakpoint: maximum watchpoint size is 8 bytes.
[    0.696000] raid6: int32x1  gen()   180 MB/s
[    0.866128] raid6: int32x1  xor()   166 MB/s
[    1.036290] raid6: int32x2  gen()   232 MB/s
[    1.206333] raid6: int32x2  xor()   172 MB/s
[    1.376437] raid6: int32x4  gen()   225 MB/s
[    1.546478] raid6: int32x4  xor()   172 MB/s
[    1.716732] raid6: int32x8  gen()   223 MB/s
[    1.886834] raid6: int32x8  xor()   149 MB/s
[    2.056770] raid6: neonx1   gen()   494 MB/s
[    2.226851] raid6: neonx1   xor()   363 MB/s
[    2.397013] raid6: neonx2   gen()   650 MB/s
[    2.567063] raid6: neonx2   xor()   473 MB/s
[    2.737186] raid6: neonx4   gen()   721 MB/s
[    2.907261] raid6: neonx4   xor()   499 MB/s
[    3.077358] raid6: neonx8   gen()   694 MB/s
[    3.247503] raid6: neonx8   xor()   484 MB/s
[    3.247522] raid6: using algorithm neonx4 gen() 721 MB/s
[    3.247539] raid6: .... xor() 499 MB/s, rmw enabled
[    3.247556] raid6: using intx1 recovery algorithm
[    3.247775] reg-fixed-voltage usb0-vbus: could not find pctldev for node /soe
[    3.249022] SCSI subsystem initialized
[    3.249476] usbcore: registered new interface driver usbfs
[    3.249552] usbcore: registered new interface driver hub
[    3.249641] usbcore: registered new device driver usb
[    3.249843] media: Linux media interface: v0.10
[    3.249901] Linux video capture interface: v2.00
[    3.249979] pps_core: LinuxPPS API ver. 1 registered
[    3.249998] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giom>
[    3.250050] PTP clock support registered
[    3.251625] clocksource: Switched to clocksource arch_sys_counter
[    3.260168] NET: Registered protocol family 2
[    3.260778] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[    3.260874] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[    3.261001] TCP: Hash tables configured (established 8192 bind 8192)
[    3.261075] UDP hash table entries: 512 (order: 2, 16384 bytes)
[    3.261143] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[    3.261361] NET: Registered protocol family 1
[    3.261828] RPC: Registered named UNIX socket transport module.
[    3.261855] RPC: Registered udp transport module.
[    3.261872] RPC: Registered tcp transport module.
[    3.261888] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    3.262115] Trying to unpack rootfs image as initramfs...
[    3.714741] Freeing initrd memory: 8580K (c979f000 - ca000000)
[    3.716352] futex hash table entries: 1024 (order: 4, 65536 bytes)
[    3.716733] Initialise system trusted keyrings
[    3.717119] workingset: timestamp_bits=14 max_order=18 bucket_order=4
[    3.724684] zbud: loaded
[    3.728094] NFS: Registering the id_resolver key type
[    3.728158] Key type id_resolver registered
[    3.728176] Key type id_legacy registered
[    3.728201] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    3.728220] Installing knfsd (copyright © 1996 okir@monad.swb.de).
[    3.729471] JFS: nTxBlock = 8009, nTxLock = 64079
[    3.737566] SGI XFS with ACLs, security attributes, realtime, no debug enabld
[    3.744506] Key type asymmetric registered
[    3.744599] bounce: pool size: 64 pages
[    3.744864] Block layer SCSI generic (bsg) driver version 0.4 loaded (major )
[    3.745028] io scheduler noop registered
[    3.745051] io scheduler deadline registered
[    3.745485] io scheduler cfq registered (default)
[    3.746061] sun4i-usb-phy 1c19400.phy: could not find pctldev for node /soc/e
[    3.748344] sun8i-h3-pinctrl 1c20800.pinctrl: initialized sunXi PIO driver
[    3.749052] sun8i-h3-r-pinctrl 1f02c00.pinctrl: initialized sunXi PIO driver
[    3.803375] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled
[    3.806030] console [ttyS0] disabled
[    3.826219] 1c28000.serial: ttyS0 at MMIO 0x1c28000 (irq = 40, base_baud = 1A
[    4.635519] console [ttyS0] enabled
[    4.642659] brd: module loaded
[    4.651728] loop: module loaded
[    4.655748] libphy: Fixed MDIO Bus: probed
[    4.661193] usbcore: registered new interface driver catc
[    4.666679] usbcore: registered new interface driver kaweth
[    4.672275] pegasus: v0.9.3 (2013/04/25), Pegasus/Pegasus II USB Ethernet drr
[    4.679723] usbcore: registered new interface driver pegasus
[    4.685436] usbcore: registered new interface driver rtl8150
[    4.691153] usbcore: registered new interface driver r8152
[    4.696707] usbcore: registered new interface driver lan78xx
[    4.702434] usbcore: registered new interface driver asix
[    4.707876] usbcore: registered new interface driver ax88179_178a
[    4.714026] usbcore: registered new interface driver cdc_ether
[    4.719901] usbcore: registered new interface driver cdc_eem
[    4.725611] usbcore: registered new interface driver dm9601
[    4.731223] usbcore: registered new interface driver sr9700
[    4.736867] usbcore: registered new interface driver CoreChips
[    4.742778] usbcore: registered new interface driver smsc75xx
[    4.748582] usbcore: registered new interface driver smsc95xx
[    4.754387] usbcore: registered new interface driver gl620a
[    4.760003] usbcore: registered new interface driver net1080
[    4.765715] usbcore: registered new interface driver plusb
[    4.771242] usbcore: registered new interface driver rndis_host
[    4.777219] usbcore: registered new interface driver cdc_subset
[    4.783203] usbcore: registered new interface driver MOSCHIP usb-ethernet drr
[    4.790669] usbcore: registered new interface driver cdc_ncm
[    4.796389] usbcore: registered new interface driver huawei_cdc_ncm
[    4.802718] usbcore: registered new interface driver cdc_mbim
[    4.808469] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    4.815012] ehci-platform: EHCI generic platform driver
[    4.820595] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    4.826805] ohci-platform: OHCI generic platform driver
[    4.832388] usbcore: registered new interface driver cdc_wdm
[    4.838108] usbcore: registered new interface driver usb-storage
[    4.844986] sun6i-rtc 1f00000.rtc: rtc core: registered rtc-sun6i as rtc0
[    4.851830] sun6i-rtc 1f00000.rtc: RTC enabled
[    4.856430] i2c /dev entries driver
[    4.863450] sunxi-wdt 1c20ca0.watchdog: Watchdog enabled (timeout=16 sec, no)
[    4.871651] sun8i-h3-pinctrl 1c20800.pinctrl: unknown pin PL7
[    4.877408] pinctrl core: failed to register map default (0): invalid type gn
[    4.885814] sunxi-mmc 1c0f000.mmc: Got CD GPIO
[    4.941657] sunxi-mmc 1c0f000.mmc: base:0xf0d2a000 irq:23
[    4.947662] sunxi-mmc 1c10000.mmc: allocated mmc-pwrseq
[    5.731614] sunxi-mmc 1c10000.mmc: fatal err update clk timeout
[    5.744623] mmc0: host does not support reading read-only switch, assuming we
[    5.754583] mmc0: new high speed SDHC card at address 0007
[    5.760645] mmcblk0: mmc0:0007 SD32G 29.0 GiB
[    5.765159] sunxi-mmc 1c10000.mmc: base:0xf0d2e000 irq:24
[    5.766555]  mmcblk0: p1 p2 p3
[    5.831649] sunxi-mmc 1c11000.mmc: base:0xf0d3c000 irq:25
[    5.852196] ledtrig-cpu: registered to indicate activity on CPUs
[    5.858311] hidraw: raw HID events driver © Jiri Kosina
[    5.863906] usbcore: registered new interface driver usbhid
[    5.869484] usbhid: USB HID core driver
[    5.874124] Initializing XFRM netlink socket
[    5.879071] NET: Registered protocol family 10
[    5.884454] NET: Registered protocol family 17
[    5.888928] NET: Registered protocol family 15
[    5.893445] bridge: automatic filtering via arp/ip/ip6tables has been deprec.
[    5.906113] 8021q: 802.1Q VLAN Support v1.8
[    5.910348] Key type dns_resolver registered
[    5.914959] Registering SWP/SWPB emulation handler
[    5.920362] registered taskstats version 1
[    5.924489] Loading compiled-in X.509 certificates
[    5.929361] zswap: loaded using pool lzo/zbud
[    5.935091] Btrfs loaded, crc32c=crc32c-generic
[    5.957660] Key type encrypted registered
[    5.963622] ehci-platform 1c1a000.usb: EHCI Host Controller
[    5.969239] ehci-platform 1c1a000.usb: new USB bus registered, assigned bus 1
[    5.977261] ehci-platform 1c1a000.usb: irq 27, io mem 0x01c1a000
[    6.011631] ehci-platform 1c1a000.usb: USB 2.0 started, EHCI 1.00
[    6.018002] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[    6.024825] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber1
[    6.032075] usb usb1: Product: EHCI Host Controller
[    6.036959] usb usb1: Manufacturer: Linux 4.8.3-sun8i ehci_hcd
[    6.042806] usb usb1: SerialNumber: 1c1a000.usb
[    6.047978] hub 1-0:1.0: USB hub found
[    6.051802] hub 1-0:1.0: 1 port detected
[    6.056409] ehci-platform 1c1b000.usb: EHCI Host Controller
[    6.062039] ehci-platform 1c1b000.usb: new USB bus registered, assigned bus 2
[    6.069976] ehci-platform 1c1b000.usb: irq 29, io mem 0x01c1b000
[    6.101632] ehci-platform 1c1b000.usb: USB 2.0 started, EHCI 1.00
[    6.107950] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[    6.114760] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber1
[    6.122009] usb usb2: Product: EHCI Host Controller
[    6.126893] usb usb2: Manufacturer: Linux 4.8.3-sun8i ehci_hcd
[    6.132740] usb usb2: SerialNumber: 1c1b000.usb
[    6.137877] hub 2-0:1.0: USB hub found
[    6.141692] hub 2-0:1.0: 1 port detected
[    6.146215] ehci-platform 1c1c000.usb: EHCI Host Controller
[    6.151868] ehci-platform 1c1c000.usb: new USB bus registered, assigned bus 3
[    6.159785] ehci-platform 1c1c000.usb: irq 31, io mem 0x01c1c000
[    6.191627] ehci-platform 1c1c000.usb: USB 2.0 started, EHCI 1.00
[    6.197930] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
[    6.204741] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber1
[    6.211990] usb usb3: Product: EHCI Host Controller
[    6.216874] usb usb3: Manufacturer: Linux 4.8.3-sun8i ehci_hcd
[    6.222728] usb usb3: SerialNumber: 1c1c000.usb
[    6.227862] hub 3-0:1.0: USB hub found
[    6.231683] hub 3-0:1.0: 1 port detected
[    6.236214] ehci-platform 1c1d000.usb: EHCI Host Controller
[    6.241842] ehci-platform 1c1d000.usb: new USB bus registered, assigned bus 4
[    6.249744] ehci-platform 1c1d000.usb: irq 33, io mem 0x01c1d000
[    6.281628] ehci-platform 1c1d000.usb: USB 2.0 started, EHCI 1.00
[    6.287940] usb usb4: New USB device found, idVendor=1d6b, idProduct=0002
[    6.294750] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber1
[    6.301992] usb usb4: Product: EHCI Host Controller
[    6.306876] usb usb4: Manufacturer: Linux 4.8.3-sun8i ehci_hcd
[    6.312722] usb usb4: SerialNumber: 1c1d000.usb
[    6.317843] hub 4-0:1.0: USB hub found
[    6.321661] hub 4-0:1.0: 1 port detected
[    6.326174] ohci-platform 1c1a400.usb: Generic Platform OHCI controller
[    6.332843] ohci-platform 1c1a400.usb: new USB bus registered, assigned bus 5
[    6.340729] ohci-platform 1c1a400.usb: irq 28, io mem 0x01c1a400
[    6.415841] usb usb5: New USB device found, idVendor=1d6b, idProduct=0001
[    6.422659] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber1
[    6.429892] usb usb5: Product: Generic Platform OHCI controller
[    6.435829] usb usb5: Manufacturer: Linux 4.8.3-sun8i ohci_hcd
[    6.441676] usb usb5: SerialNumber: 1c1a400.usb
[    6.446784] hub 5-0:1.0: USB hub found
[    6.450585] hub 5-0:1.0: 1 port detected
[    6.455103] ohci-platform 1c1b400.usb: Generic Platform OHCI controller
[    6.461761] ohci-platform 1c1b400.usb: new USB bus registered, assigned bus 6
[    6.469654] ohci-platform 1c1b400.usb: irq 30, io mem 0x01c1b400
[    6.545855] usb usb6: New USB device found, idVendor=1d6b, idProduct=0001
[    6.552666] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber1
[    6.559900] usb usb6: Product: Generic Platform OHCI controller
[    6.565840] usb usb6: Manufacturer: Linux 4.8.3-sun8i ohci_hcd
[    6.571689] usb usb6: SerialNumber: 1c1b400.usb
[    6.576784] hub 6-0:1.0: USB hub found
[    6.580586] hub 6-0:1.0: 1 port detected
[    6.585108] ohci-platform 1c1c400.usb: Generic Platform OHCI controller
[    6.591775] ohci-platform 1c1c400.usb: new USB bus registered, assigned bus 7
[    6.599658] ohci-platform 1c1c400.usb: irq 32, io mem 0x01c1c400
[    6.675847] usb usb7: New USB device found, idVendor=1d6b, idProduct=0001
[    6.682665] usb usb7: New USB device strings: Mfr=3, Product=2, SerialNumber1
[    6.689899] usb usb7: Product: Generic Platform OHCI controller
[    6.695834] usb usb7: Manufacturer: Linux 4.8.3-sun8i ohci_hcd
[    6.701681] usb usb7: SerialNumber: 1c1c400.usb
[    6.706748] hub 7-0:1.0: USB hub found
[    6.710549] hub 7-0:1.0: 1 port detected
[    6.715065] ohci-platform 1c1d400.usb: Generic Platform OHCI controller
[    6.721726] ohci-platform 1c1d400.usb: new USB bus registered, assigned bus 8
[    6.729598] ohci-platform 1c1d400.usb: irq 34, io mem 0x01c1d400
[    6.805826] usb usb8: New USB device found, idVendor=1d6b, idProduct=0001
[    6.812643] usb usb8: New USB device strings: Mfr=3, Product=2, SerialNumber1
[    6.819877] usb usb8: Product: Generic Platform OHCI controller
[    6.825812] usb usb8: Manufacturer: Linux 4.8.3-sun8i ohci_hcd
[    6.831659] usb usb8: SerialNumber: 1c1d400.usb
[    6.836721] hub 8-0:1.0: USB hub found
[    6.840521] hub 8-0:1.0: 1 port detected
[    6.845123] usb_phy_generic.0.auto supply vcc not found, using dummy regulatr
[    6.853189] of_cfs_init
[    6.855752] of_cfs_init: OK
[    6.862580] vcc5v0: disabling
[    7.521619] sunxi-mmc 1c10000.mmc: fatal err update clk timeout
[    7.581609] sunxi-mmc 1c11000.mmc: fatal err update clk timeout
[    7.588633] Freeing unused kernel memory: 1024K (c0c00000 - c0d00000)
[    8.331608] sunxi-mmc 1c11000.mmc: fatal err update clk timeout
[    8.331612] sunxi-mmc 1c10000.mmc: fatal err update clk timeout
Loading, please wait...
starting version 229
[    8.406855] random: systemd-udevd: uninitialized urandom read (16 bytes read)
[    8.411385] random: udevadm: uninitialized urandom read (16 bytes read)
[    8.413014] random: udevadm: uninitialized urandom read (16 bytes read)
[    8.413394] random: udevadm: uninitialized urandom read (16 bytes read)
[    8.413756] random: udevadm: uninitialized urandom read (16 bytes read)
[    8.414129] random: udevadm: uninitialized urandom read (16 bytes read)
[    8.414499] random: udevadm: uninitialized urandom read (16 bytes read)
[    8.414898] random: udevadm: uninitialized urandom read (16 bytes read)
[    8.415318] random: udevadm: uninitialized urandom read (16 bytes read)
[    8.415686] random: udevadm: uninitialized urandom read (16 bytes read)
[    9.091625] sunxi-mmc 1c11000.mmc: fatal err update clk timeout
[    9.091628] sunxi-mmc 1c10000.mmc: fatal err update clk timeout
[    9.476440] random: fast init done
[    9.532053] BTRFS: device label OPI_root_btrfs devid 1 transid 15463 /dev/mm2
done.
Warning: fsck not present, so skipping root file system
[    9.607317] BTRFS info (device mmcblk0p2): disk space caching is enabled
[    9.614125] BTRFS info (device mmcblk0p2): has skinny extents
[    9.663948] BTRFS info (device mmcblk0p2): detected SSD devices, enabling SSe
done.
[   10.213018] systemd[1]: System time before build time, advancing clock.
[   10.295193] systemd[1]: systemd 229 running in system mode. (+PAM +AUDIT +SE)
[   10.313813] systemd[1]: Detected architecture arm.
Welcome to Ubuntu 16.04.1 LTS!
[   10.353961] systemd[1]: Set hostname to <orangepipc>.
[   10.869548] systemd[1]: Started Forward Password Requests to Wall Directory .
[  OK  ] Started Forward Password Requests to Wall Directory Watch.
[   10.902618] systemd[1]: Set up automount Arbitrary Executable File Formats F.
[  OK  ] Set up automount Arbitrary Executab...ats File System Automount Point.
[   10.942023] systemd[1]: Listening on Journal Socket.
[  OK  ] Listening on Journal Socket.
[   10.971944] systemd[1]: Listening on udev Kernel Socket.
[  OK  ] Listening on udev Kernel Socket.
[   11.001753] systemd[1]: Reached target Remote File Systems (Pre).
[  OK  ] Reached target Remote File Systems (Pre).
[   11.031891] systemd[1]: Listening on udev Control Socket.
[  OK  ] Listening on udev Control Socket.
[   11.062276] systemd[1]: Created slice System Slice.
[  OK  ] Created slice System Slice.
         Starting Nameserver information manager...
         Starting Load Kernel Modules...
[  OK  ] Created slice system-serial\x2dgetty.slice.
         Starting Uncomplicated firewall...
[  OK  ] Created slice system-systemd\x2dfsck.slice.
[  OK  ] Created slice User and Session Slice.
[   11.377980] ip_tables: © 2000-2006 Netfilter Core Team
         Starting Restore / save the current clock...
[   11.411911] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
         Mounting POSIX Message Queue File System...
[  OK  ] Listening on Syslog Socket.
[   11.467484] ip6_tables: © 2000-2006 Netfilter Core Team
[  OK  ] Listening on /dev/initctl Compatibility Named Pipe.
[  OK  ] Reached target Remote File Systems.
[  OK  ] Reached target Slices.
[  OK  ] Reached target Encrypted Volumes.
         Mounting Debug File System...
         Starting Create list of required st... nodes for the current kernel...
         Starting Set console keymap...
[  OK  ] Listening on Journal Socket (/dev/log).
         Starting Remount Root and Kernel File Systems...
[   11.815614] BTRFS info (device mmcblk0p2): disk space caching is enabled
[  OK  ] Listening on fsck to fsckd communication Socket.
[  OK  ] Mounted Debug File System.
[  OK  ] Mounted POSIX Message Queue File System.
[FAILED] Failed to start Load Kernel Modules.
See 'systemctl status systemd-modules-load.service' for details.
[  OK  ] Started Uncomplicated firewall.
[  OK  ] Started Restore / save the current clock.
[  OK  ] Started Create list of required sta...ce nodes for the current kernel.
[  OK  ] Started Set console keymap.
[  OK  ] Started Remount Root and Kernel File Systems.
[  OK  ] Started Nameserver information manager.
         Starting Load/Save Random Seed...
         Starting udev Coldplug all Devices...
         Starting Create Static Device Nodes in /dev...
         Mounting Configuration File System...
         Starting Apply Kernel Variables...
[  OK  ] Mounted Configuration File System.
[  OK  ] Started Load/Save Random Seed.
[  OK  ] Started Create Static Device Nodes in /dev.
[  OK  ] Started Apply Kernel Variables.
         Starting udev Kernel Device Manager...
[  OK  ] Reached target Local File Systems (Pre).
         Mounting /tmp...
[  OK  ] Mounted /tmp.
[  OK  ] Started Entropy daemon using the HAVEGE algorithm.
         Starting Journal Service...
[  OK  ] Started udev Coldplug all Devices.
[  OK  ] Started udev Kernel Device Manager.
[  OK  ] Started Dispatch Password Requests to Console Directory Watch.
[  OK  ] Started Journal Service.
         Starting Flush Journal to Persistent Storage...
[  OK  ] Started Flush Journal to Persistent Storage.
[   13.766510] Bad mode in prefetch abort handler detected
[   13.771766] Bad mode in prefetch abort handler detected
[   13.776998] Bad mode in prefetch abort handler detected
[   13.782229] Bad mode in prefetch abort handler detected
[   13.787456] Bad mode in prefetch abort handler detected
[   13.792683] Bad mode in prefetch abort handler detected
[   13.797910] Bad mode in prefetch abort handler detected
[   13.803138] Bad mode in prefetch abort handler detected
[   13.808366] Bad mode in prefetch abort handler detected
[   13.813618] Internal error: Oops - bad mode: 0 [#1] SMP ARM
[   13.819211] Modules linked in: cpufreq_dt uio_pdrv_genirq thermal_sys uio ips
[   13.859304] CPU: 0 PID: 372 Comm: haveged Not tainted 4.8.3-sun8i #2
[   13.865662] Hardware name: Allwinner sun8i Family
[   13.870372] task: c98063c0 task.stack: ee144000
[   13.874908] PC is at 0x1c
[   13.877541] LR is at __probe_kernel_read+0x48/0xac
[   13.882339] pc : [<0000001c>]    lr : [<c01c5220>]    psr: 000f0197
[   13.882339] sp : ee145610  ip : 0000001c  fp : 00127a39
[   13.893817] r10: 8119fb80  r9 : 00000000  r8 : c0ac4cd4
[   13.899047] r7 : ee145744  r6 : 00000055  r5 : 00000000  r4 : ffffe000
[   13.905590] r3 : 00000000  r2 : ffffffe4  r1 : 0000001c  r0 : 000f0193
[   13.912126] Flags: nzcv  IRQs off  FIQs on  Mode ABT_32  ISA ARM  Segment noe
[   13.919354] Control: 10c5387d  Table: 6e1b006a  DAC: 00000000
[   13.925100] Process haveged (pid: 372, stack limit = 0xee144210)
[   13.931105] Stack: (0xee145610 to 0xee146000)
[   13.935464] 5600:                                     000f0193 0000001c ffff0
[   13.943644] 5620: ffffe000 00000000 00000055 ee145744 c0ac4cd4 00000000 81199
[   13.951824] 5640: 0000001c ee145610 c01c5220 0000001c 000f0197 ffffffff 00005
[   13.960003] 5660: ee145744 c0ac4cd4 ee145698 00000004 00000000 ffffe000 c01cc
[   13.968183] 5680: ee145744 600f0193 ee145744 c0ac4cd4 c010b890 c0d50738 c0d0b
[   13.976364] 56a0: c054bfd8 c0d0cec8 c016c0a4 0000002b c016c924 c0d4e29c c0d03
[   13.984544] 56c0: c010b570 c0d7307e 0000002b 00000002 00000000 600f0193 00000
[   13.992724] 56e0: c0d7307c 00000000 ee145744 0000001c 000f0197 ffffffff c0ac0
[   14.000904] 5700: 8119fb80 00127a39 c016cd80 c0ac4cb0 ee145730 0000000a ee14c
[   14.009084] 5720: 000f0197 ffffffff c0ac4cd4 00000000 8119fb80 00127a39 c0103
[   14.017264] 5740: c01c5220 000f0193 0000001c ffffffe4 00000000 ffffe000 00005
[   14.025443] 5760: ee145878 c0ac4cd4 00000000 8119fb80 00127a39 0000001c ee140
[   14.033623] 5780: 0000001c 000f0197 ffffffff 00000000 00000055 ee145878 c0acc
[   14.041804] 57a0: 00000004 00000000 ffffe000 c01c5220 0000001c ee145878 600f8
[   14.049985] 57c0: c0ac4cd4 c010b890 c0d50738 c0d0cec8 0000002b c054bfd8 c0d04
[   14.058165] 57e0: 0000002b c016c924 c0d4e29c c0d07a90 600f0193 c010b570 c0d7b
[   14.066346] 5800: 00000002 00000000 600f0193 00000000 00000000 c0d7307c 00008
[   14.074526] 5820: 0000001c 000f0197 ffffffff c0ac4cd4 00000000 8119fb80 00120
[   14.082706] 5840: c0ac4cb0 ee145864 0000000a ee145878 0000001c 000f0197 ffff4
[   14.090887] 5860: 00000000 8119fb80 00127a39 c010b98c 000f0193 c01c5220 000fc
[   14.099067] 5880: ffffffe4 00000000 ffffe000 00000000 00000055 ee1459ac c0ac0
[   14.107247] 58a0: 8119fb80 00127a39 0000001c ee145878 c01c5220 0000001c 000ff
[   14.115427] 58c0: 00000000 00000055 ee1459ac c0ac4cd4 ee145900 00000004 00000
[   14.123607] 58e0: c01c5220 0000001c ee1459ac 600f0193 ee1459ac c0ac4cd4 c0108
[   14.131787] 5900: c0d0cec8 0000002b c054bfd8 c0d0cec8 c016c0a4 0000002b c016c
[   14.139966] 5920: c0d07a90 600f0193 c010b570 c0d7307e 0000002b 00000002 00003
[   14.148146] 5940: 00000000 00000000 c0d7307c 00000000 ee1459ac 0000001c 000ff
[   14.156326] 5960: c0ac4cd4 00000000 8119fb80 00127a39 c016cd80 c0ac4cb0 ee14a
[   14.164507] 5980: ee1459ac 0000001c 000f0197 ffffffff c0ac4cd4 00000000 81199
[   14.172686] 59a0: c010b98c 000f0193 c01c5220 000f0193 0000001c ffffffe4 00000
[   14.180866] 59c0: 00000000 00000055 ee145ae0 c0ac4cd4 00000000 8119fb80 0012c
[   14.189046] 59e0: ee1459ac c01c5220 0000001c 000f0197 ffffffff 00000000 00000
[   14.197225] 5a00: c0ac4cd4 ee145a34 00000004 00000000 ffffe000 c01c5220 00000
[   14.205407] 5a20: 600f0193 ee145ae0 c0ac4cd4 c010b890 c0d50738 c0d0cec8 00008
[   14.213587] 5a40: c0d0cec8 c016c0a4 0000002b c016c924 c0d4e29c c0d07a90 600f0
[   14.221767] 5a60: c0d7307e 0000002b 00000002 00000000 600f0193 00000000 0000c
[   14.229948] 5a80: 00000000 ee145ae0 0000001c 000f0197 ffffffff c0ac4cd4 00000
[   14.238127] 5aa0: 00127a39 c016cd80 c0ac4cb0 ee145acc 0000000a ee145ae0 00007
[   14.246309] 5ac0: ffffffff c0ac4cd4 00000000 8119fb80 00127a39 c010b98c 000f0
[   14.254488] 5ae0: 000f0193 0000001c ffffffe4 00000000 ffffe000 00000000 00004
[   14.262668] 5b00: c0ac4cd4 00000000 8119fb80 00127a39 0000001c ee145ae0 c01cc
[   14.270848] 5b20: 000f0197 ffffffff 00000000 00000055 ee145c14 c0ac4cd4 ee144
[   14.279028] 5b40: 00000000 ffffe000 c01c5220 0000001c ee145c14 600f0193 ee144
[   14.287209] 5b60: c010b890 c0d50738 c0d0cec8 0000002b c054bfd8 c0d0cec8 c016b
[   14.295389] 5b80: c016c924 c0d4e29c c0d07a90 600f0193 c010b570 c0d7307e 00002
[   14.303569] 5ba0: 00000000 600f0193 00000000 00000000 c0d7307c 00000000 ee14c
[   14.311750] 5bc0: 000f0197 ffffffff c0ac4cd4 00000000 8119fb80 00127a39 c0160
[   14.319929] 5be0: ee145c00 0000000a ee145c14 0000001c 000f0197 ffffffff c0ac0
[   14.328109] 5c00: 8119fb80 00127a39 c010b98c 000f0193 c01c5220 000f0193 00004
[   14.336289] 5c20: 00000000 ffffe000 00000000 00000055 ee145d48 c0ac4cd4 00000
[   14.344469] 5c40: 00127a39 0000001c ee145c14 c01c5220 0000001c 000f0197 ffff0
[   14.352648] 5c60: 00000055 ee145d48 c0ac4cd4 ee145c9c 00000004 00000000 ffff0
[   14.360829] 5c80: 0000001c ee145d48 600f0193 ee145d48 c0ac4cd4 c010b890 c0d58
[   14.369009] 5ca0: 0000002b c054bfd8 c0d0cec8 c016c0a4 0000002b c016c924 c0d40
[   14.377189] 5cc0: 600f0193 c010b570 c0d7307e 0000002b 00000002 00000000 600f0
[   14.385368] 5ce0: 00000000 c0d7307c 00000000 ee145d48 0000001c 000f0197 ffff4
[   14.393548] 5d00: 00000000 8119fb80 00127a39 c016cd80 c0ac4cb0 ee145d34 00008
[   14.401728] 5d20: 0000001c 000f0197 ffffffff c0ac4cd4 00000000 8119fb80 0012c
[   14.409908] 5d40: 000f0193 c01c5220 000f0193 0000001c ffffffe4 00000000 ffff0
[   14.418088] 5d60: 00000055 ee145e7c c0ac4cd4 00000000 8119fb80 00127a39 00008
[   14.426268] 5d80: c01c5220 0000001c 000f0197 ffffffff 00000000 00000055 ee144
[   14.434447] 5da0: ee145dd0 00000004 00000000 ffffe000 c01c5220 0000001c ee143
[   14.442627] 5dc0: ee145e7c c0ac4cd4 c010b890 c0d50738 c0d0cec8 0000002b c0548
[   14.450807] 5de0: c016c0a4 0000002b c016c924 c0d4e29c c0d07a90 600f0193 c010e
[   14.458986] 5e00: 0000002b 00000002 00000000 600f0193 00000000 00000000 c0d70
[   14.467166] 5e20: ee145e7c 0000001c 000f0197 ffffffff c0ac4cd4 00000000 81199
[   14.475345] 5e40: c016cd80 c0ac4cb0 ee145e68 0000000a ee145e7c 0000001c 000ff
[   14.483525] 5e60: c0ac4cd4 00000000 8119fb80 00127a39 c010b98c 000f0193 c01c3
[   14.491705] 5e80: 02002010 ffffffe4 00000000 ffffe000 bf000000 00000055 ee144
[   14.499885] 5ea0: 00000000 8119fb80 00127a39 0000001c ee145e7c c01c5220 00007
[   14.508065] 5ec0: ffffffff bf000000 00000055 ee145fb0 c0ac4cd4 ee145f04 00000
[   14.516244] 5ee0: ffffe000 c01c5220 02002010 ee145fb0 600f0193 ee145fb0 c0ac0
[   14.524424] 5f00: c0d50738 c01ab17c 0000002b c054bfd8 c0d0cec8 c016c0a4 00004
[   14.532604] 5f20: c0d4e29c c0d07a90 600f0193 c010b570 c0d7307e 0000002b 00000
[   14.540784] 5f40: 600f0193 00000000 00000000 c0d7307c ef1c7000 ee145fb0 02007
[   14.548963] 5f60: ffffffff 29aaaaab 00000001 8119fb80 00127a39 c016cd80 c0acc
[   14.557143] 5f80: f080200c ee145fb0 02002010 000f0197 ffffffff 29aaaaab 00000
[   14.565323] 5fa0: 00127a39 c010b98c 000f0193 bea17540 000f0193 1a2db126 1bff0
[   14.573503] 5fc0: be8d2a2c a7d5b608 0000162f ffffffff 29aaaaab 00000001 81199
[   14.581683] 5fe0: 02002010 ee145fb0 bea17540 02002010 000f0197 ffffffff fffff
[   14.589879] [<c01c5220>] (__probe_kernel_read) from [<00000000>] (  (null))
[   14.596844] Code: bad PC value
[   14.599903] ---[ end trace a495395ac3c4eb4e ]---
[**    ] (1 of 3) A start job is running for...mcblk0p3.device (23s / 1min 30s):
[   34.777471]  1-...: (1 GPs behind) idle=aed/140000000000000/0 softirq=685/69
[   34.785692]  (detected by 3, t=2102 jiffies, g=-70, c=-71, q=5239)
[   34.792070] Task dump for CPU 1:
[   34.795426] systemd-udevd   R running      0   390      1 0x00000003
[   34.802105] [<c08bb968>] (__schedule) from [<00000054>] (0x54)
[*     ] (1 of 3) A start job is running for...mcblk0p3.device (38s / 1min 30s)e
[**    ] (1 of 3) A start job is running for...0p3.device (1min 26s / 1min 30s):
[   97.827432]  1-...: (1 GPs behind) idle=aed/140000000000000/0 softirq=685/69
[   97.835652]  (detected by 0, t=8408 jiffies, g=-70, c=-71, q=5383)
[   97.842035] Task dump for CPU 1:
[   97.845390] systemd-udevd   R running      0   390      1 0x00000003
[   97.852070] [<c08bb968>] (__schedule) from [<00000054>] (0x54)
[ TIME ] Timed out waiting for device dev-ttyS0.device.
[DEPEND] Dependency failed for Serial Getty on ttyS0.
[ TIME ] Timed out waiting for device dev-mmcblk0p3.device.
[DEPEND] Dependency failed for /dev/mmcblk0p3.
[DEPEND] Dependency failed for Swap.
[ TIME ] Timed out waiting for device dev-mmcblk0p1.device.
[DEPEND] Dependency failed for /boot.
[DEPEND] Dependency failed for Local File Systems.
[DEPEND] Dependency failed for File System Check on /dev/mmcblk0p1.
Kernel is experimental / development and it breaks sometimes. That's the reason why we don't officially provide this kernel yet.
Thank you Igor. I understand. I am just "reporting" this issue so it can be looked at when the time is right.
The previous version works very well so it could be a simple thing to resolve for the right person. Either way, someone should know and (hopefully) now they might.
When there is an update, I will be happy to try it on for size. Especially now that I have btrfs snapshots to roll me back fast if it all goes wrong.
AFAIK boot problems are already resolved, but I don't follow this closely to point you to the best working dev branch. Actually there are lots of changes and things are fragmented at this stage - each dev is working on one certain problem - so you need to follow more resources to get a big picture. IIRC thermal protection and CPU frequency scaling does not work yet or broken. HDMI video driver was just introduced ...
Thanks for reporting.
