Peter Andersson Posted June 26, 2023 Posted June 26, 2023 (edited) Hi I just installed armbian on my rockpi 4c+ and wanted to check the temperature so I found that I should be able to run cat /etc/armbianmonitor/datasources/soctemp But that just gives the error cat: /etc/armbianmonitor/datasources/soctemp: No such file or directory It seems /etc/armbianmonitor/datasources/soctemp is a link to /sys/devices/virtual/thermal/thermal_zone0/temp but I have no /sys/devices/virtual/thermal/thermal_zone0 directory, under thermal I have ├── cooling_device0 │ ├── cur_state │ ├── max_state │ ├── power │ │ ├── autosuspend_delay_ms │ │ ├── control │ │ ├── runtime_active_time │ │ ├── runtime_status │ │ └── runtime_suspended_time │ ├── stats │ │ ├── reset │ │ ├── time_in_state_ms │ │ ├── total_trans │ │ └── trans_table │ ├── subsystem -> ../../../../class/thermal │ ├── type │ └── uevent └── cooling_device1 ├── cur_state ├── max_state ├── power │ ├── autosuspend_delay_ms │ ├── control │ ├── runtime_active_time │ ├── runtime_status │ └── runtime_suspended_time ├── stats │ ├── reset │ ├── time_in_state_ms │ ├── total_trans │ └── trans_table ├── subsystem -> ../../../../class/thermal ├── type └── uevent Guessing this is a bug? Both cur_state files yield 0 when cat them. https://paste.armbian.com/ekebicased I'm using the Armbian_v22.05.2_Rockpi-4cplus_bullseye_current_6.1.33_minimal.img image It seems I can find the same content under /sys/class/thermal/ as under /sys/devices/virtual/thermal/ I have also tried to install lm-sensors but it fails to find any sensors to read, after that i tried to use a rolling release, but it never fetched a IP, guessing the boot failed, but as I have no micro hdmi adapter I could not check what failed. Edit 2023-06-27 I downloaded the latest ubuntu server image from https://github.com/radxa/debos-radxa/releases/tag/20230201-0944 and there it seems to work, is there someway I can find what driver/process created the thermal_zone? After that I tested the latest armbian ubuntu minimal image, sadly it also lacks the /sys/devices/virtual/thermal/ Edited June 27, 2023 by Peter Andersson 0 Quote
Peter Andersson Posted June 29, 2023 Author Posted June 29, 2023 For some reason I'm not allowed to edit the question any more, so I will add additional content I found here instead... I tried to compare the loaded kernel modules of both distros but that didn't give me any information. So next I looked at the device tree using dtc -I fs /sys/firmware/devicetree/base the content has been attached. It has the following rockchip-system-monitor { compatible = "rockchip,system-monitor"; rockchip,polling-delay = <0xc8>; phandle = <0x15e>; rockchip,thermal-zone = "soc-thermal"; }; device-tree-radax-ubuntu.txtFetching info... 0 Quote
Werner Posted June 30, 2023 Posted June 30, 2023 On 6/29/2023 at 11:01 AM, Peter Andersson said: For some reason I'm not allowed to edit the question any more, Expand Editing posts is only possible after a certain period of time after creation in order to prevent abuse. It is perfectly fine to add new information as a fresh posting in this case. Your prudence is appreciated. 0 Quote
usual user Posted June 30, 2023 Posted June 30, 2023 On 6/26/2023 at 9:09 PM, Peter Andersson said: wanted to check the temperature Expand What does tmon tell about your thermal subsystem? 1 Quote
Peter Andersson Posted July 3, 2023 Author Posted July 3, 2023 (edited) I ran hwinfo on the distro where things thermal monitoring works as expected and noticed rockchip-thermal: /devices/platform/ff260000.tsadc My guess is that this is the driver that adds the thermal's, but I have no idea what path it points to? Edit: I can confirm that the rockchip-thermal does not exist in armbian, and sadly I have no idea how to add it.. Edited July 4, 2023 by Peter Andersson 0 Quote
Peter Andersson Posted July 4, 2023 Author Posted July 4, 2023 Usual user, when I run tmon on the armbian distro I get No thermal zones found, exit my guess is that the needed drivers or configuration is missing in armbian. 0 Quote
usual user Posted July 5, 2023 Posted July 5, 2023 On 7/4/2023 at 7:31 PM, Peter Andersson said: the needed drivers or configuration is missing Expand Exactly, either there is no thermal zone wired-up in the DT or the kernel build configuration lacks the necessary drivers enabled. To exclude the DTB, you can upload yours used in armbian and I can investigate accordingly. 0 Quote
Peter Andersson Posted July 5, 2023 Author Posted July 5, 2023 (edited) usual user, not sure I follow 100%, but what I have found is that the rk3399-rock-4c-plus.dts and rk3399.dtsi files in the https://github.com/radxa/kernel/tree/linux-5.10-gen-rkr4.1/arch/arm64/boot/dts/rockchip repo are different than the same files in the linux repo. I'm not sure if both are used or if its just the rk3399-rock-4c-plus.dts Would it be safe to compile armbian with the rk3399-rock-4c-plus.dts from radxa? they use a old version of the linux kernel (4.4 if I remember correctly). If it is could you give me some instruction how I would go about replacing the file locally before building a new image? Edit: it looks like the rk3399-rock-4c-plus.dts uses rk3399.dtsi, rk3399-linux.dtsi and rk3399-t-opp.dtsi Edited July 5, 2023 by Peter Andersson 0 Quote
usual user Posted July 5, 2023 Posted July 5, 2023 On 7/5/2023 at 12:49 PM, Peter Andersson said: could you give me some instruction Expand I asked you, as a first step, to upload the rk3399-rock-4c-plus.dtb, which is currently provided by the Armbian OS, to be able to check if the thermal zone is really not wired-up. There's no point in putting effort into fixing something that isn't broken. 0 Quote
Peter Andersson Posted July 8, 2023 Author Posted July 8, 2023 (edited) Sorry for the delay, and thanks for your help and patience Usual user, I'm not 100% sure My first idea was to look here https://github.com/armbian/linux-rockchip/tree/rockchip-sdk-5.10/arch/arm64/boot/dts/rockchip but that repo does not seem to have a rk3399-rock-4c-plus.dts for some reason. So my guess is that it uses the one in the linux repo? https://raw.githubusercontent.com/torvalds/linux/master/arch/arm64/boot/dts/rockchip/rk3399-rock-4c-plus.dts I managed to dump some content using dtc -I fs -O dts /sys/firmware/devicetree/base I have attached it to the post. From what i can see the armbian has some thermal stuff, but the one from radax has more. device-tree-armbian-bookworm.txtFetching info... Edited July 10, 2023 by Peter Andersson 0 Quote
