pierre-pret Posted July 10, 2023 Posted July 10, 2023 With Armbian 22 (kernel 5.15 and bullseye/jammy) the Orange PI 3 LTS worked great including WiFi, ETH, Bluetooth. Partly thanks to @Ukhellfire and @going. Downloadable here: https://xogium.performanceservers.nl/archive/orangepi3-lts/archive/ Below is what I find the status is for the new Armbian 23 images provided for here : https://www.armbian.com/orangepi3-lts/ Branch current: Main downloads Armbian 23 with kernel 6.1 bookworm: It boots, but every 3rd or 4th keystroke is ignored. No ETH, no WiFi. Armbian 23 with kernel 6.1 jammy: It boots, keystrokes are OK, ETH is OK, but WiFi doesn't work. Branch edge: Rolling release downloads Armbian 23 with kernel 6.4 bookworm: Doesn't boot, no board lights come on. Armbian 23 with kernel 6.4 lunar: Doesn't boot, no board lights come on. Branch edge: When I build myself There doesn't seem to be any selection to make edge boot regardless of kernel (5.15, 6.1 or 6.4) or bookworm/bullseye. Branch current: When I build myself I found a way to get a good build of Armbian 23: use branch current with legacy kernel 5.15: 1) Checkout the last current commit: https://github.com/armbian/build/commit/6af50cfcdd46661038fd30c71548362012df6438 2) Edit config/boards/orangepi3-lts.csc and add support for legacy kernel: KERNEL_TARGET="legacy,current,edge" 3) Build legacy bullseye: ./compile.sh build BOARD=orangepi3-lts BRANCH=legacy RELEASE=bullseye @Igor I can send free Orange PI 3 LTS boards to US based Armbian contributors if it can improve community support of this board. 0 Quote
going Posted July 10, 2023 Posted July 10, 2023 git checkout -b test c6e450189f140db5ffc0167b035dfbec6304fabb @pierre-pret Will a working image be assembled on this commit? 0 Quote
Gunjan Gupta Posted July 11, 2023 Posted July 11, 2023 @pierre-pretCould you please create and test an image from my branch https://github.com/viraniac/armbian_build/tree/opi3 0 Quote
Igor Posted July 11, 2023 Posted July 11, 2023 On 7/10/2023 at 4:58 AM, pierre-pret said: Armbian 23 with kernel 6.4 bookworm: Doesn't boot, no board lights come on. Armbian 23 with kernel 6.4 lunar: Doesn't boot, no board lights come on. Few hours before leaving for vacations, I found out the same. I didn't have time to debug ... there is something wrong with u-boot / ATF settings. We have some ideas but I am out of office and can't test. On 7/10/2023 at 4:58 AM, pierre-pret said: to US based Armbian contributors if it can improve community support of this board. Thanks for your offer, but sadly that helps little. We have virtually unlimited access to cheap hardware - most vendors happily send us whenever we need them - one engineering hour costs more then one hardware pcs. Time is a problem. Not many can afford to work weeks and weeks straight and pay all the living expenses. To support competitors that skips all this and for you that usually don't even notice or care. (generally speaking) Allwinner wise, not just this SoC or this board specifically - for https://armbian.atlassian.net/browse/AR-1502 we wasted several weeks, we made some progress, we made expenses to upgrade test gears, we lost hundreds of hours ... nobody even noticed. If you want to help improving support, help with your time and expertise. I can sent you a free board too 0 Quote
Gunjan Gupta Posted September 29, 2023 Posted September 29, 2023 @pierre-pretWe have recently done a lot of fixes for this board. Some are included in latest 23.8.3 image while others (for things like ethernet fix and wrong ram size detection by u-boot on reboot) are available from beta repository. If you try building an image again now. I believe you will have much smoother experience. Feel free to let us know if you face any issues. 0 Quote
vuhuy Posted December 2, 2023 Posted December 2, 2023 Quick update for other users wondering. WiFi, ethernet and UART3 works all fine for me currently. Prebuild image, no beta repository, just all stock. Image: Armbian 23.11.1 Bookworm Kernel: 6.1.63-current-sunxi64 Thank you contributors/community. 1 Quote
icyleaf Posted September 28, 2024 Posted September 28, 2024 Armbian Linux v6.6 with 6.6 kernel not works again. sadly. 0 Quote
