OttawaHacker Posted July 19, 2023 Posted July 19, 2023 (edited) Has anyone successfully migrated from 23.2 (stable) to 23.5 (stable)? Is that scenario possible today? I'm looking to get the Bluetooth working, I know it has been fixed in 23.5 but that one is currently broken. Edited July 19, 2023 by OttawaHacker 0 Quote
Werner Posted July 19, 2023 Posted July 19, 2023 apt repository does not offer 23.05 packages (yet). Risk of break existing installation is too high so shipping is delayed or skipped entirely until 23.08 is released. However you can always use the build framework to create your own set of firmware packages and install them via dpkg. https://github.com/armbian/build/ 2 Quote
OttawaHacker Posted July 19, 2023 Author Posted July 19, 2023 5 hours ago, Werner said: However you can always use the build framework to create your own set of firmware packages and install them via dpkg. https://github.com/armbian/build/ That build system is amazing but can I use the same build system and upgrade my current packages? 0 Quote
Werner Posted July 20, 2023 Posted July 20, 2023 Yes. Simply build the kernel for your board, then go to the output directory and copy the needed .deb files to your board. Then install them there via dpkg -i ... 0 Quote
