mPCIE mSATA SSD not recognized on OPi3 (not B nor LTS).
laurentppol
Hi there, I have OPi3 (not B nor LTS), now I got an SSD module ( https://allegro.pl/oferta/dysk-ssd-128gb-msata-6gb-s-13044566959 ), and it does not seem to work (nothing related in lsblk). I am using Armbian 21.02.3). Any ideas?
the red LED is on, mechanically looks compatible with socket
do I need something to enable this?
armbianmonitor -u : http://ix.io/4Bkf
Link to comment
Share on other sites
Armbian & Khadas are rewarding contributors
PCIe port is not supported: Allwinner H6 has a quirky PCIe controller that doesn’t map the PCIe address space properly to CPU, and accessing the PCIe config space, IO space or memory space will need to be wrapped. As Linux doesn’t wrap PCIe memory space access, it’s not possible to do a proper PCIe controller driver for H6. The BSP kernel modifies the driver to wrap the access, so it’s also not generic, and only devices with modified driver will work. Armbian does not support BSP based kernels. You can find more information here and here
Link to comment
