bsrobot Posted August 11, 2023 Posted August 11, 2023 (edited) Hi, I would like to use st7735 in an orangePI zero 2 (H616). The st7735 module was purchased at the following link: https://it.aliexpress.com/item/33031122936.html?spm=a2g0o.order_list.order_list_main.32.c5eb36966Y6eGs&gatewayAdapt=glo2ita Armbian usage. I connected st7735 in the following way: OPI --------> st7735 23 --------> SCK 19 --------> SDA 24 --------> CS 13 --------> AD 11 --------> RTD 4 --------> VCC 25 --------> GND I then ran the following command: sudo modprobe fbtft_device custom name=fb_st7735r gpios=dc:3,reset:0 speed=16000000 rotate=90 The screen stays white with a red stripe at the bottom. I can't find any errors in dmesg. /dev/fb1 is created how can i use the command con2fbmap 1 1 which I found by following this guide: https://www.instructables.com/Orange-Pi-Zero-Connect-TFT-SPI-ST7735/ Thank you Edited August 11, 2023 by bsrobot 0 Quote
Peter Gregory Posted August 12, 2023 Posted August 12, 2023 I recently got my SPI display to work with OPZero2. This document was very helpful: https://tienda.tettsa.gt/wp-content/uploads/2022/08/OrangePi_Zero2_H616_User-manual_v3.7.pdf Your GPIO pin numbers are not correct. I wired to the same GPIO pins suggested in the document above: 1 - VCC (1) 3.3v 2 - GND (6) Gnd 3 - CS (24) Spi1 CS 4 - RESET (7) GPIO 6 - 73 5 - DC (11) GPIO 1 - 70 6 - SDI (MOSI) (19) Spi1 MOSI 7 - SCLK (23) Spi1 CLK 8 - LED (13) GPIO 0 - 69 9 - SDO (MISO) (21) Spi1 MISO The GPIO mapping looks like this: options fbtft_device custom name=fb_ili9341 gpios=dc:70,reset:73,led:69 speed=16000000 busnum=1 cs=1 bgr=1 txtbuflen-32768 fps=10 rotate=90 0 Quote
bsrobot Posted August 20, 2023 Author Posted August 20, 2023 (edited) Thanks for the reply. In these days I will start some tests. One question, I don't have the led pin. Could the LED pin be my BLK? Another curiosity, why use fb_ili9341 and not fb_st7735r? on PCB i have only SDA i don't have MISO and MOSI pins. How can I do? Thank you Edited August 22, 2023 by bsrobot 0 Quote
konsD Posted March 20, 2025 Posted March 20, 2025 Is the topic still relevant? I'm also trying to connect ST7735S + OPI Z3. But my screen doesn't even light up. I checked the screen on the ESP - it's working. There is no clear description anywhere of what packages need to be installed on the system. I would like to display information about the system on the screen 0 Quote
