noplat Posted November 27, 2016 Posted November 27, 2016 I am having a problem setting up the wireless on OrangePi PC Plus. Kernel module 8189fs is loaded, but no wlan0 interface appears. Here is my lsmod output: root@orangepipcplus:~# lsmod Module Size Used by rfcomm 32863 4 bnep 9617 2 bluetooth 174065 8 bnep,rfcomm mali_drm 2732 1 drm 178255 2 mali_drm sunxi_cir 1601 0 pcf8591 3363 0 bmp085 3487 0 mali 123208 0 ump 29379 3 mali 8189fs 1050451 0 hid_logitech_dj 10040 0 ifconfig and iwconfig do not show any wireless interfaces: root@orangepipcplus:~# ifconfig wlan0 wlan0: error fetching interface information: Device not found root@orangepipcplus:~# iwconfig lo no wireless extensions. tunl0 no wireless extensions. eth0 no wireless extensions. Additionally, something strange happens in syslog when 8189fs is loaded via modprobe: Nov 27 13:29:41 localhost kernel: [ 1157.590035] [mmc]: *** sunxi_mci_update_clk(L490): update clock timeout, fatal error!!! Nov 27 13:29:42 localhost kernel: [ 1158.590038] [mmc]: *** sunxi_mci_update_clk(L490): update clock timeout, fatal error!!! Nov 27 13:29:43 localhost kernel: [ 1159.590026] [mmc]: *** sunxi_mci_update_clk(L490): update clock timeout, fatal error!!! Nov 27 13:29:44 localhost kernel: [ 1160.590023] [mmc]: *** sunxi_mci_update_clk(L490): update clock timeout, fatal error!!! Nov 27 13:29:45 localhost kernel: [ 1161.590043] [mmc]: *** sunxi_mci_update_clk(L490): update clock timeout, fatal error!!! Nov 27 13:29:46 localhost kernel: [ 1162.590034] [mmc]: *** sunxi_mci_update_clk(L490): update clock timeout, fatal error!!! Nov 27 13:29:46 localhost kernel: [ 1162.590184] [mmc]: sdc1 power_supply is null Nov 27 13:29:46 localhost kernel: [ 1162.594306] [mmc]: sdc1 power_supply is null Nov 27 13:29:47 localhost kernel: [ 1163.630030] [mmc]: *** sunxi_mci_update_clk(L490): update clock timeout, fatal error!!! Nov 27 13:29:48 localhost kernel: [ 1164.630069] [mmc]: *** sunxi_mci_update_clk(L490): update clock timeout, fatal error!!! Nov 27 13:29:49 localhost kernel: [ 1165.630026] [mmc]: *** sunxi_mci_update_clk(L490): update clock timeout, fatal error!!! Nov 27 13:29:50 localhost kernel: [ 1166.630024] [mmc]: *** sunxi_mci_update_clk(L490): update clock timeout, fatal error!!! Nov 27 13:29:51 localhost kernel: [ 1167.630052] [mmc]: *** sunxi_mci_update_clk(L490): update clock timeout, fatal error!!! Nov 27 13:29:52 localhost kernel: [ 1168.630020] [mmc]: *** sunxi_mci_update_clk(L490): update clock timeout, fatal error!!! Nov 27 13:29:53 localhost kernel: [ 1169.630025] [mmc]: *** sunxi_mci_update_clk(L490): update clock timeout, fatal error!!! Nov 27 13:29:54 localhost kernel: [ 1170.630024] [mmc]: *** sunxi_mci_update_clk(L490): update clock timeout, fatal error!!! Nov 27 13:29:55 localhost kernel: [ 1171.630023] [mmc]: *** sunxi_mci_update_clk(L490): update clock timeout, fatal error!!! Nov 27 13:29:55 localhost kernel: [ 1171.630172] [mmc]: sdc1 power_supply is null Nov 27 13:29:55 localhost kernel: [ 1171.634263] [mmc]: sdc1 power_supply is null Nov 27 13:29:56 localhost kernel: [ 1172.670030] [mmc]: *** sunxi_mci_update_clk(L490): update clock timeout, fatal error!!! Nov 27 13:29:57 localhost kernel: [ 1173.670021] [mmc]: *** sunxi_mci_update_clk(L490): update clock timeout, fatal error!!! Nov 27 13:29:58 localhost kernel: [ 1174.670017] [mmc]: *** sunxi_mci_update_clk(L490): update clock timeout, fatal error!!! Nov 27 13:29:59 localhost kernel: [ 1175.670023] [mmc]: *** sunxi_mci_update_clk(L490): update clock timeout, fatal error!!! Nov 27 13:30:00 localhost kernel: [ 1176.670024] [mmc]: *** sunxi_mci_update_clk(L490): update clock timeout, fatal error!!! Nov 27 13:30:01 localhost kernel: [ 1177.670021] [mmc]: *** sunxi_mci_update_clk(L490): update clock timeout, fatal error!!! Nov 27 13:30:02 localhost kernel: [ 1178.670023] [mmc]: *** sunxi_mci_update_clk(L490): update clock timeout, fatal error!!! Nov 27 13:30:03 localhost kernel: [ 1179.670016] [mmc]: *** sunxi_mci_update_clk(L490): update clock timeout, fatal error!!! Nov 27 13:30:04 localhost kernel: [ 1180.670015] [mmc]: *** sunxi_mci_update_clk(L490): update clock timeout, fatal error!!! Nov 27 13:30:04 localhost kernel: [ 1180.670162] [mmc]: sdc1 power_supply is null Nov 27 13:30:04 localhost kernel: [ 1180.674255] [mmc]: sdc1 power_supply is null Nov 27 13:30:05 localhost kernel: [ 1181.710016] [mmc]: *** sunxi_mci_update_clk(L490): update clock timeout, fatal error!!! Nov 27 13:30:06 localhost kernel: [ 1182.710017] [mmc]: *** sunxi_mci_update_clk(L490): update clock timeout, fatal error!!! Nov 27 13:30:07 localhost kernel: [ 1183.710018] [mmc]: *** sunxi_mci_update_clk(L490): update clock timeout, fatal error!!! Nov 27 13:30:08 localhost kernel: [ 1184.710020] [mmc]: *** sunxi_mci_update_clk(L490): update clock timeout, fatal error!!! Nov 27 13:30:09 localhost kernel: [ 1185.710021] [mmc]: *** sunxi_mci_update_clk(L490): update clock timeout, fatal error!!! Nov 27 13:30:10 localhost kernel: [ 1186.710018] [mmc]: *** sunxi_mci_update_clk(L490): update clock timeout, fatal error!!! Nov 27 13:30:11 localhost kernel: [ 1187.710025] [mmc]: *** sunxi_mci_update_clk(L490): update clock timeout, fatal error!!! Nov 27 13:30:12 localhost kernel: [ 1188.710023] [mmc]: *** sunxi_mci_update_clk(L490): update clock timeout, fatal error!!! Nov 27 13:30:13 localhost kernel: [ 1189.710023] [mmc]: *** sunxi_mci_update_clk(L490): update clock timeout, fatal error!!! Nov 27 13:30:13 localhost kernel: [ 1189.710169] [mmc]: sdc1 power_supply is null Here is my dmesg output. Thanks for any help! [ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache [ 0.000000] Machine: sun8i [ 0.000000] cma: CMA: reserved 256 MiB at 50000000 [ 0.000000] Memory policy: ECC disabled, Data cache writealloc [ 0.000000] On node 0 totalpages: 262144 [ 0.000000] free_area_init_node: node 0, pgdat c0a22a00, node_mem_map c0b5c000 [ 0.000000] Normal zone: 1710 pages used for memmap [ 0.000000] Normal zone: 0 pages reserved [ 0.000000] Normal zone: 192850 pages, LIFO batch:31 [ 0.000000] HighMem zone: 594 pages used for memmap [ 0.000000] HighMem zone: 66990 pages, LIFO batch:15 [ 0.000000] script_init enter! [ 0.000000] script_init exit! [ 0.000000] PERCPU: Embedded 8 pages/cpu @c1473000 s11968 r8192 d12608 u32768 [ 0.000000] pcpu-alloc: s11968 r8192 d12608 u32768 alloc=8*4096 [ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 259840 [ 0.000000] Kernel command line: console=ttyS0,115200 console=tty1 root=/dev/mmcblk0p1 rootwait rootfstype=ext4 cgroup_enable=memory swapaccount=1 panic=10 consoleblank=0 enforcing=0 loglevel=7 [ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes) [ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes) [ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes) [ 0.000000] allocated 2097152 bytes of page_cgroup [ 0.000000] please try 'cgroup_disable=memory' option if you don't want memory cgroups [ 0.000000] Memory: 1024MB = 1024MB total [ 0.000000] Memory: 758688k/758688k available, 289888k reserved, 270336K highmem [ 0.000000] Virtual kernel memory layout: [ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB) [ 0.000000] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB) [ 0.000000] vmalloc : 0xf0000000 - 0xff000000 ( 240 MB) [ 0.000000] lowmem : 0xc0000000 - 0xef800000 ( 760 MB) [ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB) [ 0.000000][ 0.000000] Additional per-CPU info printed with stalls. [ 0.000000] NR_IRQS:544 [ 0.000000] Architected local timer running at 24.00MHz. [ 0.000000] Switching to timer-based delay loop [ 0.000000] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 178956ms [ 0.000000] Console: colour dummy device 80x30 [ 0.000000] console [tty1] enabled [ 0.000989] Calibrating delay loop (skipped), value calculated using timer frequency.. 4800.00 BogoMIPS (lpj=24000000) [ 0.001055] pid_max: default: 32768 minimum: 301 [ 0.001416] Mount-cache hash table entries: 512 [ 0.002403] Initializing cgroup subsys cpuacct [ 0.002441] Initializing cgroup subsys memory [ 0.002506] Initializing cgroup subsys devices [ 0.002537] Initializing cgroup subsys freezer [ 0.002566] Initializing cgroup subsys blkio [ 0.002608] Initializing cgroup subsys perf_event [ 0.002708] CPU: Testing write buffer coherency: ok [ 0.002775] ftrace: allocating 25741 entries in 76 pages [ 0.030296] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000 [ 0.030338] [sunxi_smp_prepare_cpus] enter [ 0.030386] Setting up static identity map for 0x40691778 - 0x406917d0 [ 0.031354] CPU1: Booted secondary processor [ 0.031354] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001 [ 0.031485] CPU2: Booted secondary processor [ 0.031485] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002 [ 0.040482] CPU3: Booted secondary processor [ 0.040482] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003 [ 0.040603] Brought up 4 CPUs [ 0.040603] SMP: Total of 4 processors activated (19200.00 BogoMIPS). [ 0.040977] devtmpfs: initialized [ 0.050754] wakeup src cnt is : 2. [ 0.050782] [exstandby]leave extended_standby_enable_wakeup_src : event 0x800000 [ 0.050793] [exstandby]leave extended_standby_enable_wakeup_src : wakeup_gpio_map 0x0 [ 0.050804] [exstandby]leave extended_standby_enable_wakeup_src : wakeup_gpio_group 0x40 modules : 0xbf000000 - 0xbfe00000 ( 14 MB)[ 0.061052] NET: Registered protocol family 16 [ 0.061848] DMA: preallocated 2048 KiB pool for atomic coherent allocations [ 0.061848] script_sysfs_init success [ 0.061848] sunxi_dump_init success [ 0.062484] gpiochip_add: registered GPIOs 0 to 383 on device: sunxi-pinctrl [ 0.062484] sunxi-pinctrl sunxi-pinctrl: initialized sunXi PIO driver [ 0.062484] plat: add bmp085 device [ 0.062484] plat: add pcf8591 device [ 0.062484] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers. [ 0.062484] hw-breakpoint: maximum watchpoint size is 8 bytes. [ 0.062484] Not Found clk pll_video in script [ 0.062484] script config pll_de to 864 Mhz [ 0.062484] script config pll_ve to 402 Mhz [ 0.062484] sunxi_default_clk_init [ 0.062484] try to set pll6ahb1 to 200000000 [ 0.062484] try to set ahb clk source to pll6ahb1 [ 0.062484] set ahb clk source to pll6ahb1 [ 0.062484] try to set ahb1 to 200000000 [ 0.062484] try to set apb1 to 100000000 [ 0.070236] bio: create slab <bio-0> at 0 [ 0.070330] [ARISC] :sunxi-arisc driver v1.04 [ 0.090427] [ARISC] :arisc version: [v0.1.58] [ 0.180887] [ARISC] :sunxi-arisc driver v1.04 startup succeeded [ 0.182496] SCSI subsystem initialized [ 0.182496] usbcore: registered new interface driver usbfs [ 0.182496] usbcore: registered new interface driver hub [ 0.182496] Advanced Linux Sound Architecture Driver Version 1.0.25. [ 0.182496] cfg80211: Calling CRDA to update world regulatory domain [ 0.182496] Switching to clocksource arch_sys_counter [ 0.193963] FS-Cache: Loaded [ 0.194275] CacheFiles: Loaded [ 0.205458] NET: Registered protocol family 2 [ 0.216713] IP route cache hash table entries: 32768 (order: 5, 131072 bytes) [ 0.217348] TCP established hash table entries: 131072 (order: 8, 1048576 bytes) [ 0.219133] TCP bind hash table entries: 65536 (order: 7, 786432 bytes) [ 0.220240] TCP: Hash tables configured (established 131072 bind 65536) [ 0.220269] TCP: reno registered [ 0.220293] UDP hash table entries: 512 (order: 2, 16384 bytes) [ 0.220347] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes) [ 0.220720] NET: Registered protocol family 1 [ 0.221154] RPC: Registered named UNIX socket transport module. [ 0.221185] RPC: Registered udp transport module. [ 0.221206] RPC: Registered tcp transport module. [ 0.221227] RPC: Registered tcp NFSv4.1 backchannel transport module. [ 0.221434] Trying to unpack rootfs image as initramfs... [ 0.408925] Freeing initrd memory: 3060K [ 0.409335] hw perfevents: enabled with ARMv7 Cortex_A7 PMU driver, 5 counters available [ 0.409485] sunxi_reg_init enter [ 0.410472] audit: initializing netlink socket (disabled) [ 0.410541] type=2000 audit(0.410:1): initialized [ 0.411698] highmem bounce pool size: 64 pages [ 0.412576] squashfs: version 4.0 (2009/01/31) Phillip Lougher [ 0.412788] misc fatfs initialized [ 0.413521] NFS: Registering the id_resolver key type [ 0.413927] nfs4filelayout_init: NFSv4 File Layout Driver Registering... [ 0.413962] Installing knfsd (copyright (C) 1996 okir@monad.swb.de). [ 0.414760] NTFS driver 2.1.30 [Flags: R/W]. [ 0.415112] fuse init (API version 7.18) [ 0.415842] Btrfs loaded [ 0.415878] msgmni has been set to 1471 [ 0.417305] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253) [ 0.417349] io scheduler noop registered [ 0.417370] io scheduler deadline registered [ 0.417449] io scheduler cfq registered (default) [ 0.417883] [DISP]disp_module_init [ 0.418193] cmdline,init_disp= [ 0.507535] uart0: ttyS0 at MMIO 0x1c28000 (irq = 32) is a SUNXI [ 0.507716] sw_uart_pm()890 - uart0 clk is already enable [ 0.507880] sw_console_setup()1233 - console setup baud 115200 parity n bits 8, flow n [ 0.607606] console [ttyS0] enabled [ 1.227588] sunxi_cmatest_init enter [ 1.429175] sunxi_cmatest_init success [ 1.624756] brd: module loaded [ 1.841891] loop: module loaded [ 1.863698] sunxi_spi_chan_cfg()1376 - [spi-0] has no spi_regulator. [ 1.878111] sunxi_spi_chan_cfg()1376 - [spi-1] has no spi_regulator. [ 1.893015] spi spi0: master is unqueued, this is deprecated [ 1.906895] tun: Universal TUN/TAP device driver, 1.6 [ 1.919777] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com> [ 1.935002] PPP generic driver version 2.4.2 [ 1.947376] PPP BSD Compression module registered [ 1.960023] PPP Deflate Compression module registered [ 1.975821] PPP MPPE Compression module registered [ 1.988650] NET: Registered protocol family 24 [ 2.001068] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver [ 2.035907] sunxi-ehci sunxi-ehci.1: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver [ 2.052659] sunxi-ehci sunxi-ehci.1: new USB bus registered, assigned bus number 1 [ 2.069471] sunxi-ehci sunxi-ehci.1: irq 104, io mem 0xf1c1a000 [ 2.100032] sunxi-ehci sunxi-ehci.1: USB 0.0 started, EHCI 1.00 [ 2.115016] hub 1-0:1.0: USB hub found [ 2.127065] hub 1-0:1.0: 1 port detected [ 2.159609] sunxi-ehci sunxi-ehci.2: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver [ 2.176477] sunxi-ehci sunxi-ehci.2: new USB bus registered, assigned bus number 2 [ 2.193351] sunxi-ehci sunxi-ehci.2: irq 106, io mem 0xf1c1b000 [ 2.220039] sunxi-ehci sunxi-ehci.2: USB 0.0 started, EHCI 1.00 [ 2.234514] ehci_irq: highspeed device connect [ 2.235063] hub 2-0:1.0: USB hub found [ 2.247111] hub 2-0:1.0: 1 port detected [ 2.279663] sunxi-ehci sunxi-ehci.3: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver [ 2.296538] sunxi-ehci sunxi-ehci.3: new USB bus registered, assigned bus number 3 [ 2.313362] sunxi-ehci sunxi-ehci.3: irq 108, io mem 0xf1c1c000 [ 2.340040] sunxi-ehci sunxi-ehci.3: USB 0.0 started, EHCI 1.00 [ 2.354972] hub 3-0:1.0: USB hub found [ 2.366865] hub 3-0:1.0: 1 port detected [ 2.474932] hub 4-0:1.0: USB hub found [ 2.486905] hub 4-0:1.0: 1 port detected [ 2.499410] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver [ 2.520060] ehci_irq: highspeed device disconnect [ 2.534118] sunxi-ohci sunxi-ohci.1: SW USB2.0 'Open' Host Controller (OHCI) Driver [ 2.550534] sunxi-ohci sunxi-ohci.1: new USB bus registered, assigned bus number 5 [ 2.566802] sunxi-ohci sunxi-ohci.1: irq 105, io mem 0xf1c1a400 [ 2.644565] hub 5-0:1.0: USB hub found [ 2.656448] hub 5-0:1.0: 1 port detected [ 2.688833] sunxi-ohci sunxi-ohci.2: SW USB2.0 'Open' Host Controller (OHCI) Driver [ 2.705185] sunxi-ohci sunxi-ohci.2: new USB bus registered, assigned bus number 6 [ 2.721406] sunxi-ohci sunxi-ohci.2: irq 107, io mem 0xf1c1b400 [ 2.760045] ehci_irq: highspeed device disconnect [ 2.794604] hub 6-0:1.0: USB hub found [ 2.806425] hub 6-0:1.0: 1 port detected [ 2.838724] sunxi-ohci sunxi-ohci.3: SW USB2.0 'Open' Host Controller (OHCI) Driver [ 2.854995] sunxi-ohci sunxi-ohci.3: new USB bus registered, assigned bus number 7 [ 2.871202] sunxi-ohci sunxi-ohci.3: irq 109, io mem 0xf1c1c400 [ 2.944590] hub 7-0:1.0: USB hub found [ 2.956471] hub 7-0:1.0: 1 port detected [ 2.988793] sunxi-ohci sunxi-ohci.4: SW USB2.0 'Open' Host Controller (OHCI) Driver [ 3.005126] sunxi-ohci sunxi-ohci.4: new USB bus registered, assigned bus number 8 [ 3.021470] sunxi-ohci sunxi-ohci.4: irq 111, io mem 0xf1c1d400 [ 3.094553] hub 8-0:1.0: USB hub found [ 3.106593] hub 8-0:1.0: 1 port detected [ 3.119179] Initializing USB Mass Storage driver... [ 3.132653] usbcore: registered new interface driver usb-storage [ 3.147177] USB Mass Storage support registered. [ 3.160144] usbcore: registered new interface driver ums-alauda [ 3.174584] usbcore: registered new interface driver ums-cypress [ 3.189016] usbcore: registered new interface driver ums-datafab [ 3.200047] usb 6-1: new full-speed USB device number 2 using sunxi-ohci [ 3.289577] usbcore: registered new interface driver ums-onetouch [ 3.303744] usbcore: registered new interface driver ums-realtek [ 3.317746] usbcore: registered new interface driver ums-sddr09 [ 3.331530] usbcore: registered new interface driver ums-sddr55 [ 3.345198] usbcore: registered new interface driver ums-usbat [ 3.358895] uinput result 0 , vmouse_init [ 3.359515] mousedev: PS/2 mouse device common for all mice [ 3.372939] sunxikbd_init failed. [ 3.384453] ls_fetch_sysconfig_para: type err device_used = -1073060220. [ 3.399234] =========script_get_err============ [ 3.411307] ltr_init: ls_fetch_sysconfig_para err. [ 3.411650] [RTC] WARNING: Rtc time will be wrong!! [ 3.424058] [RTC] WARNING: use *internal OSC* as clock source [ 3.437672] sunxi-rtc sunxi-rtc: rtc core: registered sunxi-rtc as rtc0 [ 3.452118] i2c /dev entries driver [ 3.463423] IR RC5(x) protocol handler initialized [ 3.475928] sunxi cedar version 0.1 [ 3.475971] [cedar]: install start!!! [ 3.476193] [cedar]: install end!!! [ 3.476430] sunxi_i2c_do_xfer()985 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x18) [ 3.493076] sunxi_i2c_do_xfer()985 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x19) [ 3.509534] sunxi_i2c_do_xfer()985 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x1a) [ 3.525869] sunxi_i2c_do_xfer()985 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x29) [ 3.542138] sunxi_i2c_do_xfer()985 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x2a) [ 3.558355] sunxi_i2c_do_xfer()985 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x2b) [ 3.574452] sunxi_i2c_do_xfer()985 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x4c) [ 3.590536] sunxi_i2c_do_xfer()985 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x4d) [ 3.606450] sunxi_i2c_do_xfer()985 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x4e) [ 3.622311] sunxi_i2c_do_xfer()985 - [i2c1] incomplete xfer (status: 0x20, dev addr: 0x18) [ 3.638064] sunxi_i2c_do_xfer()985 - [i2c1] incomplete xfer (status: 0x20, dev addr: 0x19) [ 3.731034] sunxi_i2c_do_xfer()985 - [i2c1] incomplete xfer (status: 0x20, dev addr: 0x4d) [ 3.746229] sunxi_i2c_do_xfer()985 - [i2c1] incomplete xfer (status: 0x20, dev addr: 0x4e) [ 3.761122] sunxi_wdt_init_module: sunxi WatchDog Timer Driver v1.0 [ 3.774026] sunxi_wdt_probe: devm_ioremap return wdt_reg 0xf1c20ca0, res->start 0x01c20ca0, res->end 0x01c20cbf [ 3.785464] sunxi_wdt_probe: initialized (g_timeout=16s, g_nowayout=0) [ 3.804463] wdt_enable, write reg 0xf1c20cb8 val 0x00000000 [ 3.816526] timeout_to_interv, line 167 [ 3.826603] interv_to_timeout, line 189 [ 3.836613] wdt_set_tmout, write 0x000000b0 to mode reg 0xf1c20cb8, actual timeout 16 sec [ 3.852103] device-mapper: ioctl: 4.22.0-ioctl (2011-10-19) initialised: dm-devel@redhat.com [ 3.867736] calibrat: max_cpufreq 1200Mhz Type 0! [ 3.868044] [mmc]: SD/MMC/SDIO Host Controller Driver(v1.111 2015-4-13 15:24) Compiled in Oct 23 2016 at 16:04:43 [ 3.868077] [mmc]: get mmc0's sdc_power is null! [ 3.868105] [mmc]: get mmc1's sdc_power is null! [ 3.868114] [mmc]: get mmc1's 2xmode ok, val = 1 [ 3.868123] [mmc]: get mmc1's ddrmode ok, val = 1 [ 3.868152] [mmc]: get mmc2's sdc_power is null! [ 3.868161] [mmc]: get mmc2's 2xmode ok, val = 1 [ 3.868170] [mmc]: get mmc2's ddrmode ok, val = 1 [ 3.868183] [mmc]: MMC host used card: 0x7, boot card: 0x0, io_card 2 [ 3.871874] [mmc]: sdc0 power_supply is null [ 3.875411] no blue_led, ignore it! [ 3.885524] Registered led device: red_led [ 3.885648] Registered led device: green_led [ 3.885667] no led_0, ignore it! [ 3.890065] usb 8-1: new full-speed USB device number 2 using sunxi-ohci [ 3.908647] no led_1, ignore it! [ 3.918272] no led_2, ignore it! [ 3.927733] no led_3, ignore it! [ 3.937102] no led_4, ignore it! [ 3.946378] no led_5, ignore it! [ 3.955551] no led_6, ignore it! [ 3.964688] no led_7, ignore it! [ 3.978582] generic-usb 0003:046D:C318.0001: input,hidraw0: USB HID v1.11 Keyboard [Logitech Logitech Illuminated Keyboard] on usb-sunxi-ohci-1/input0 [ 3.993161] mmc0: new high speed SDHC card at address 0007 [ 4.011490] mmcblk0: mmc0:0007 SL16G 14.4 GiB [ 4.023922] mmcblk0: p1 [ 4.101217] asoc: sndcodec <-> sunxi-codec mapping ok [ 4.102200] [mmc]: sdc2 power_supply is null [ 4.114170] [DAUDIO]sunxi-daudio cannot find any using configuration for controllers, return directly! [ 4.131343] [I2S]snddaudio cannot find any using configuration for controllers, return directly! [ 4.147754] [DAUDIO0] driver not init,just return. [ 4.162987] asoc: sndhdmi <-> sunxi-hdmiaudio.0 mapping ok [ 4.176948] oprofile: using arm/armv7-ca7 [ 4.184599] mmc2: new high speed DDR MMC card at address 0001 [ 4.185108] mmcblk1: mmc2:0001 8WPD3R 7.28 GiB [ 4.185332] mmcblk1boot0: mmc2:0001 8WPD3R partition 1 4.00 MiB [ 4.185547] mmcblk1boot1: mmc2:0001 8WPD3R partition 2 4.00 MiB [ 4.186828] mmcblk1: p1 p2 p3 < p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15 p16 > [ 4.186876] mmcblk1: p1 size 10412032 extends beyond EOD, truncated [ 4.191411] mmcblk1boot1: unknown partition table [ 4.192865] mmcblk1boot0: unknown partition table [ 4.193115] mmcblk mmc2:0001: Card claimed for testing. [ 4.193129] mmc2:0001: 8WPD3R 7.28 GiB [ 4.270376] u32 classifier [ 4.329696] Performance counters on [ 4.340980] input device check on [ 4.351989] Actions configured [ 4.362805] IPv4 over IPv4 tunneling driver [ 4.374996] TCP: bic registered [ 4.385272] TCP: cubic registered [ 4.395748] TCP: westwood registered [ 4.406548] TCP: highspeed registered [ 4.417484] TCP: hybla registered [ 4.428058] TCP: htcp registered [ 4.438566] TCP: vegas registered [ 4.449200] TCP: veno registered [ 4.459769] TCP: scalable registered [ 4.470763] TCP: lp registered [ 4.481197] TCP: yeah registered [ 4.491856] TCP: illinois registered [ 4.502949] Initializing XFRM netlink socket [ 4.515124] NET: Registered protocol family 10 [ 4.528536] NET: Registered protocol family 17 [ 4.540819] NET: Registered protocol family 15 [ 4.619934] cmdline,disp= [ 4.630351] [HDMI] power vcc-hdmi-18 [ 4.661119] ths_fetch_sysconfig_para: type err device_used = 1. [ 4.676521] CPU Budget:corekeeper enabled [ 4.688521] CPU Budget:Register notifier [ 4.700056] CPU Budget:register Success [ 4.711340] sunxi-budget-cooling sunxi-budget-cooling: Cooling device registered: thermal-budget-0 [ 4.731673] [rf_pm]: module power0 name vcc-wifi-33 [ 4.731689] [rf_pm]: Did not config module_power1 in sys_config [ 4.731699] [rf_pm]: Did not config module_power2 in sys_config [ 4.731709] [rf_pm]: Did not config module_power3 in sys_config [ 4.731719] [rf_pm]: mod has no chip_en gpio [ 4.731728] [rf_pm]: regulator on. [ 4.731744] [rf_pm]: set losc_out 32k out[wifi_pm]: set wl_reg_on 1 ! [ 4.832086] hci: ERR: sunxi_ehci is already enable, can not enable again [ 4.833627] [mmc]: sdc1 power_supply is null [ 4.846840] hci: ERR: sunxi_ohci is already enable, can not enable again [ 4.961406] [wifi_pm]: wifi gpio init is OK !! [ 4.961470] [rfkill]: init no bt used in configuration [ 4.961480] ALSA device list: [ 4.971829] #0: audiocodec [ 4.982276] #1: sndhdmi [ 4.993037] Freeing init memory: 328K [ 5.056968] systemd-udevd[104]: starting version 215 [ 5.185954] logitech-djreceiver 0003:046D:C52B.0005: hiddev0,hidraw2: USB HID v1.11 Device [Logitech USB Receiver] on usb-sunxi-ohci-1/input2 [ 5.214591] logitech-djdevice 0003:046D:C52B.0006: input,hidraw3: USB HID v1.11 Mouse [Logitech Unifying Device. Wireless PID:4009] on usb-sunxi-ohci-1:1 [ 5.270124] [DISP] disp_device_attached_and_enable,line:159:attched ok, mgr0<-->device0, type=4, mode=10 [ 5.870023] [mmc]: *** sunxi_mci_update_clk(L490): update clock timeout, fatal error!!! [ 6.870022] [mmc]: *** sunxi_mci_update_clk(L490): update clock timeout, fatal error!!! [ 7.870047] [mmc]: *** sunxi_mci_update_clk(L490): update clock timeout, fatal error!!! [ 8.870039] [mmc]: *** sunxi_mci_update_clk(L490): update clock timeout, fatal error!!! [ 9.870042] [mmc]: *** sunxi_mci_update_clk(L490): update clock timeout, fatal error!!! [ 10.870038] [mmc]: *** sunxi_mci_update_clk(L490): update clock timeout, fatal error!!! [ 11.870039] [mmc]: *** sunxi_mci_update_clk(L490): update clock timeout, fatal error!!! [ 12.870037] [mmc]: *** sunxi_mci_update_clk(L490): update clock timeout, fatal error!!! [ 13.870090] [mmc]: *** sunxi_mci_update_clk(L490): update clock timeout, fatal error!!! [ 15.523485] systemd[1]: Detected architecture 'arm'. [ 15.583742] systemd[1]: Set hostname to <orangepipcplus>. [ 15.910051] [mmc]: *** sunxi_mci_update_clk(L490): update clock timeout, fatal error!!! [ 15.996015] systemd[1]: Cannot add dependency job for unit display-manager.service, ignoring: Unit display-manager.service failed to load: No such file or directory. [ 16.023800] systemd[1]: Expecting device dev-ttyS0.device... [ 16.047965] systemd[1]: Starting Forward Password Requests to Wall Directory Watch. [ 16.065285] systemd[1]: Started Forward Password Requests to Wall Directory Watch. [ 16.082393] systemd[1]: Starting Remote File Systems (Pre). [ 16.106552] systemd[1]: Reached target Remote File Systems (Pre). [ 16.122151] systemd[1]: Starting Encrypted Volumes. [ 16.145741] systemd[1]: Reached target Encrypted Volumes. [ 16.160708] systemd[1]: Starting Dispatch Password Requests to Console Directory Watch. [ 16.178896] systemd[1]: Started Dispatch Password Requests to Console Directory Watch. [ 16.196912] systemd[1]: Starting Paths. [ 16.220051] systemd[1]: Reached target Paths. [ 16.234236] systemd[1]: Starting Arbitrary Executable File Formats File System Automount Point. [ 16.264034] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point. [ 16.284359] systemd[1]: Starting Root Slice. [ 16.309417] systemd[1]: Created slice Root Slice. [ 16.324518] systemd[1]: Starting User and Session Slice. [ 16.351081] systemd[1]: Created slice User and Session Slice. [ 16.367574] systemd[1]: Starting /dev/initctl Compatibility Named Pipe. [ 16.395817] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe. [ 16.413719] systemd[1]: Starting Delayed Shutdown Socket. [ 16.440744] systemd[1]: Listening on Delayed Shutdown Socket. [ 16.457384] systemd[1]: Starting Journal Socket (/dev/log). [ 16.484727] systemd[1]: Listening on Journal Socket (/dev/log). [ 16.501761] systemd[1]: Starting udev Control Socket. [ 16.528470] systemd[1]: Listening on udev Control Socket. [ 16.544810] systemd[1]: Starting udev Kernel Socket. [ 16.571485] systemd[1]: Listening on udev Kernel Socket. [ 16.587839] systemd[1]: Starting Journal Socket. [ 16.614507] systemd[1]: Listening on Journal Socket. [ 16.630553] systemd[1]: Starting System Slice. [ 16.656443] systemd[1]: Created slice System Slice. [ 16.671811] systemd[1]: Started File System Check on Root Device. [ 16.688363] systemd[1]: Starting system-serial\x2dgetty.slice. [ 16.715162] systemd[1]: Created slice system-serial\x2dgetty.slice. [ 16.731890] systemd[1]: Starting system-getty.slice. [ 17.180977] systemd[1]: Mounted Huge Pages File System. [ 17.202021] systemd[1]: Started Set Up Additional Binary Formats. [ 17.218950] systemd[1]: Mounting Debug File System... [ 17.360500] systemd[1]: Mounting POSIX Message Queue File System... [ 17.453861] systemd[1]: Starting Load Kernel Modules... [ 17.520874] systemd[1]: Starting udev Coldplug all Devices... [ 17.641143] systemd[1]: Starting LSB: Set keymap... [ 17.720676] systemd[1]: Starting Slices. [ 17.743099] [wifi_pm]: set wl_reg_on 1 ! [ 17.744422] systemd[1]: Reached target Slices. [ 17.766492] UMP: UMP device driver loaded [ 17.770591] systemd[1]: Mounted POSIX Message Queue File System. [ 17.795648] mali clk: 252 MHz [ 17.795886] mali clk: 252 MHz [ 17.797799] Mali: Mali device driver loaded [ 17.821424] systemd[1]: Mounted Debug File System. [ 17.910023] [mmc]: *** sunxi_mci_update_clk(L490): update clock timeout, fatal error!!! [ 17.999676] systemd[1]: Started Increase datagram queue length. [ 18.179724] systemd[1]: Started Restore / save the current clock. [ 18.319624] systemd[1]: Started Create list of required static device nodes for the current kernel. [ 18.479763] systemd[1]: Started Load Kernel Modules. [ 18.670054] systemd[1]: Started LSB: Set keymap. [ 18.869760] systemd[1]: Started udev Coldplug all Devices. [ 18.888278] systemd[1]: Time has been changed [ 18.902335] systemd[1]: Starting Apply Kernel Variables... [ 18.910035] [mmc]: *** sunxi_mci_update_clk(L490): update clock timeout, fatal error!!! [ 19.111077] systemd[1]: Mounted Configuration File System. [ 19.126405] systemd[1]: Mounting FUSE Control File System... [ 19.210788] systemd[1]: Starting Create Static Device Nodes in /dev... [ 19.410748] systemd[1]: Starting Syslog Socket. [ 19.434877] systemd[1]: Listening on Syslog Socket. [ 19.449234] systemd[1]: Starting Journal Service... [ 19.570632] systemd[1]: Started Journal Service. [ 20.641749] sunxi_i2c_do_xfer()985 - [i2c0] incomplete xfer (status: 0x48, dev addr: 0x48) [ 20.910049] [mmc]: *** sunxi_mci_update_clk(L490): update clock timeout, fatal error!!! [ 21.157059] EXT4-fs (mmcblk0p1): re-mounted. Opts: commit=600,errors=remount-ro [ 21.418812] Adding 131068k swap on /var/swap. Priority:-1 extents:1 across:131068k SS [ 21.910025] [mmc]: *** sunxi_mci_update_clk(L490): update clock timeout, fatal error!!! [ 22.910023] [mmc]: *** sunxi_mci_update_clk(L490): update clock timeout, fatal error!!! [ 22.910199] [mmc]: sdc1 power_supply is null [ 22.914365] [mmc]: sdc1 power_supply is null [ 23.116132] systemd-journald[189]: Received request to flush runtime journal from PID 1 [ 23.416624] gmac0: probed [ 23.428143] gmac0 gmac0: eth0: eth0: PHY ID 00441400 at 0 IRQ poll (gmac0-0:00) [ 23.950096] [mmc]: *** sunxi_mci_update_clk(L490): update clock timeout, fatal error!!! [ 24.897358] Registered IR keymap rc-empty [ 24.910416] rc0: sunxi-ir as /devices/virtual/rc/rc0 [ 24.927814] rc rc0: lirc_dev: driver ir-lirc-codec (sunxi-ir) registered at minor = 0 [ 24.950339] [mmc]: *** sunxi_mci_update_clk(L490): update clock timeout, fatal error!!! [ 25.929557] [DISP] disp_ioctl,line:1584:para err in disp_ioctl, cmd = 0x0,screen id = 65536 [ 25.950117] [mmc]: *** sunxi_mci_update_clk(L490): update clock timeout, fatal error!!! [ 25.987482] [drm] Initialized drm 1.1.0 20060810 [ 26.006541] Mali DRM initialize, driver name: mali_drm, version 2.1 [ 26.014191] [drm] Initialized mali_drm 2.1.1 20101111 on minor 0 [ 26.021052] Mali DRM initialize, driver name: mali_drm, version 2.1 [ 26.028560] [drm] Initialized mali_drm 2.1.1 20101111 on minor 1 [ 26.420295] PHY: gmac0-0:00 - Link is Up - 100/Full [ 26.432347] vmouse_input_dev_open [ 26.950061] [mmc]: *** sunxi_mci_update_clk(L490): update clock timeout, fatal error!!! [ 27.950119] [mmc]: *** sunxi_mci_update_clk(L490): update clock timeout, fatal error!!! [ 28.950217] [mmc]: *** sunxi_mci_update_clk(L490): update clock timeout, fatal error!!! [ 29.950128] [mmc]: *** sunxi_mci_update_clk(L490): update clock timeout, fatal error!!! [ 30.950434] [mmc]: *** sunxi_mci_update_clk(L490): update clock timeout, fatal error!!! [ 31.950103] [mmc]: *** sunxi_mci_update_clk(L490): update clock timeout, fatal error!!! [ 31.950247] [mmc]: sdc1 power_supply is null [ 31.954514] [mmc]: sdc1 power_supply is null [ 32.990025] [mmc]: *** sunxi_mci_update_clk(L490): update clock timeout, fatal error!!! [ 33.990024] [mmc]: *** sunxi_mci_update_clk(L490): update clock timeout, fatal error!!! [ 34.070018] eth0: no IPv6 routers present [ 34.990017] [mmc]: *** sunxi_mci_update_clk(L490): update clock timeout, fatal error!!! [ 40.990023] [mmc]: *** sunxi_mci_update_clk(L490): update clock timeout, fatal error!!! [ 40.990172] [mmc]: sdc1 power_supply is null [ 40.994271] [mmc]: sdc1 power_supply is null [ 42.030025] [mmc]: *** sunxi_mci_update_clk(L490): update clock timeout, fatal error!!! [ 42.515654] Bluetooth: Core ver 2.16 [ 42.521825] NET: Registered protocol family 31 [ 42.527137] Bluetooth: HCI device and connection manager initialized [ 42.535290] Bluetooth: HCI socket layer initialized [ 42.541020] Bluetooth: L2CAP socket layer initialized [ 42.546994] Bluetooth: SCO socket layer initialized [ 42.628922] Bluetooth: BNEP (Ethernet Emulation) ver 1.3 [ 42.634997] Bluetooth: BNEP filters: protocol multicast [ 43.030081] [mmc]: *** sunxi_mci_update_clk(L490): update clock timeout, fatal error!!! [ 44.030112] [mmc]: *** sunxi_mci_update_clk(L490): update clock timeout, fatal error!!! [ 45.030029] [mmc]: *** sunxi_mci_update_clk(L490): update clock timeout, fatal error!!! [ 45.828467] Bluetooth: RFCOMM TTY layer initialized [ 45.834159] Bluetooth: RFCOMM socket layer initialized [ 45.839902] Bluetooth: RFCOMM ver 1.11 [ 46.030030] [mmc]: *** sunxi_mci_update_clk(L490): update clock timeout, fatal error!!! [ 47.030029] [mmc]: *** sunxi_mci_update_clk(L490): update clock timeout, fatal error!!! [ 48.030042] [mmc]: *** sunxi_mci_update_clk(L490): update clock timeout, fatal error!!! [ 49.030024] [mmc]: *** sunxi_mci_update_clk(L490): update clock timeout, fatal error!!! [ 50.030021] [mmc]: *** sunxi_mci_update_clk(L490): update clock timeout, fatal error!!! [ 50.030169] [mmc]: sdc1 power_supply is null [ 50.034258] [mmc]: sdc1 power_supply is null [ 51.070024] [mmc]: *** sunxi_mci_update_clk(L490): update clock timeout, fatal error!!! [ 52.070023] [mmc]: *** sunxi_mci_update_clk(L490): update clock timeout, fatal error!!! [ 53.070019] [mmc]: *** sunxi_mci_update_clk(L490): update clock timeout, fatal error!!! [ 54.070024] [mmc]: *** sunxi_mci_update_clk(L490): update clock timeout, fatal error!!! [ 55.070020] [mmc]: *** sunxi_mci_update_clk(L490): update clock timeout, fatal error!!! [ 56.070017] [mmc]: *** sunxi_mci_update_clk(L490): update clock timeout, fatal error!!! [ 57.070021] [mmc]: *** sunxi_mci_update_clk(L490): update clock timeout, fatal error!!! [ 58.070018] [mmc]: *** sunxi_mci_update_clk(L490): update clock timeout, fatal error!!! [ 59.070059] [mmc]: *** sunxi_mci_update_clk(L490): update clock timeout, fatal error!!! [ 59.070245] [mmc]: sdc1 power_supply is null [ 59.074358] [mmc]: sdc1 power_supply is null [ 60.110022] [mmc]: *** sunxi_mci_update_clk(L490): update clock timeout, fatal error!!! [ 61.110021] [mmc]: *** sunxi_mci_update_clk(L490): update clock timeout, fatal error!!! [ 62.110021] [mmc]: *** sunxi_mci_update_clk(L490): update clock timeout, fatal error!!! [ 63.110022] [mmc]: *** sunxi_mci_update_clk(L490): update clock timeout, fatal error!!! [ 64.110020] [mmc]: *** sunxi_mci_update_clk(L490): update clock timeout, fatal error!!! [ 65.110021] [mmc]: *** sunxi_mci_update_clk(L490): update clock timeout, fatal error!!! [ 66.110023] [mmc]: *** sunxi_mci_update_clk(L490): update clock timeout, fatal error!!! [ 67.110020] [mmc]: *** sunxi_mci_update_clk(L490): update clock timeout, fatal error!!! [ 68.110019] [mmc]: *** sunxi_mci_update_clk(L490): update clock timeout, fatal error!!! [ 68.110157] [mmc]: sdc1 power_supply is null [ 68.114248] [mmc]: sdc1 power_supply is null [ 69.150021] [mmc]: *** sunxi_mci_update_clk(L490): update clock timeout, fatal error!!! [ 70.150020] [mmc]: *** sunxi_mci_update_clk(L490): update clock timeout, fatal error!!! [ 71.150022] [mmc]: *** sunxi_mci_update_clk(L490): update clock timeout, fatal error!!! [ 72.150022] [mmc]: *** sunxi_mci_update_clk(L490): update clock timeout, fatal error!!! [ 73.150029] [mmc]: *** sunxi_mci_update_clk(L490): update clock timeout, fatal error!!! [ 74.150026] [mmc]: *** sunxi_mci_update_clk(L490): update clock timeout, fatal error!!! [ 75.150025] [mmc]: *** sunxi_mci_update_clk(L490): update clock timeout, fatal error!!! [ 76.150025] [mmc]: *** sunxi_mci_update_clk(L490): update clock timeout, fatal error!!! [ 77.150023] [mmc]: *** sunxi_mci_update_clk(L490): update clock timeout, fatal error!!! [ 77.150171] [mmc]: sdc1 power_supply is null
Igor Posted November 27, 2016 Posted November 27, 2016 Opi PC+ works really very well ... I would suspect hardware / power supply troubles. I assume you are using our latest, more or less unaltered, image?
noplat Posted November 28, 2016 Author Posted November 28, 2016 Yes, I am using the latest image and I did apt-get upgrade
