Hi to all,
In the past it was proposed by @Igor to use the u-boot-sunxi/remove-boot-messages-from-hdmi.patch
this now as I can see under the allwinner-optional and seems do nothing on RockPro64 u-boot compile to hide the text
@jock provided in the Tinker forum a userpatch disable-vidconsole.patch which works great on it (tinker)
diff --git a/include/configs/tinker_rk3288.h b/include/configs/tinker_rk3288.h
index bde7d72e6d..3ae9bb05f7 100644
--- a/include/configs/tinker_rk3288.h
+++ b/include/configs/tinker_rk3288.h
@@ -7,9 +7,9 @@
 #define __CONFIG_H
 #define ROCKCHIP_DEVICE_SETTINGS \
-        "stdin=serial,usbkbd\0" \
-        "stdout=serial,vidconsole\0" \
-        "stderr=serial,vidconsole\0"
+        "stdin=serial\0" \
+        "stdout=serial\0" \
+        "stderr=serial\0"
 #include <configs/rk3288_common.h>
On an Linux 5.15.93-rockchip64 aarch64 GNU/Linux - Ubuntu 20.04.6 LTS image the u-boot does not boot the sd, but on a spi u-boot installed, it boots ok
I would like to have working hidden u-boot installed on the sd (bridge spi to disabled with pin 23-25) rather boot first the spi. (feels longer boot)
I try to compile with, tried diff patches but no luck
./compile.sh build BOARD=rockpro64 BRANCH=current BUILD_DESKTOP=no BUILD_MINIMAL=yes BUILD_ONLY=u-boot KERNEL_CONFIGURE=no RELEASE=jammy
Any feedback or existing solution is much appreciated.
To recap:
- Tips or pointers on which patch to be used to hide uboot boot process on RockPro64
- Below is probably to uboot related so Ill test other compiles
PS
I have compiled a non patched/[non applied sunxi hide msgs patch] "linux-u-boot-rockpro64-current_23.08.0-trunk_arm64__2023.01-S62e2-Pee75-He8c0-V2d4f-B9963-R448a.deb" and applied from armbian-config to sd card.
It boots ok with disabled SPI from Power Off
But if OS reboots it stays to black screen (no white light).
If reset pressed or power off and start from buttons, it boots again fine with UBOOT visible (submarine logo and text)
NOTE: @ayufan Ayufan latest uboot on spi works excellent and hidden boot
Edited by 2play
