NiTr0 Posted October 20 Posted October 20 11.10.2025 в 18:31, Nick A сказал: I guess transferring the dtb to official armbian kernel 6.12.43 will work. Most of warpme’s collection of patches are already in the official armbian build. There might be some differences. it works OK on stock kernel, but there's some strange things with network/routing. I use static IP with static default route, and often when I run wget or apt install I've got 'network unreachable'; ping 8.8.8.8 -i 0.1 (or other IP not from internal subnet; for ex., external IP of router) - may ping OK without any losses for a seconds and then loss packets for seconds or even tens of seconds, or may report 'ping: Do you want to ping broadcast? Then -b. If not, check your local firewall rules' and exit. IPs from internal subnet are pinged OK. but when I tried to add static route for some external IP via default gateway - it starts to work OK, and works OK even when route is removed. does anybody noticed such strange things? 0 Quote
emor acid Posted October 20 Posted October 20 hi, Compilation error, I also decompiled the dts available for Android for reference output.dts @Nick A 0 Quote
Nick A Posted October 21 Posted October 21 (edited) @emor acid The error above says you are missing node or label "reg_gmac_3v3". Add this just below "reg_vcc5v" in in your dts. https://github.com/The-going/linux-sf/blob/aa1ea7ec81c99dbc42f6d2ea4244ab4f54d0f3ee/arch/arm64/boot/dts/allwinner/sun50i-h618-bananapi-m4-berry.dts#L101-L108 reg_gmac_3v3: gmac-3v3 { compatible = "regulator-fixed"; regulator-name = "gmac-3v3"; regulator-min-microvolt = <3300000>; regulator-max-microvolt = <3300000>; regulator-always-on; vin-supply = <®_vcc5v>; }; Edited October 21 by Nick A 0 Quote
Nick A Posted October 21 Posted October 21 (edited) @John Taylor I found the driver source code for your wifi but it's for an older android/linux kernel. I asked info@lb-link.com for the linux/android driver. They sent me SWT6621S_H25.34.7.1_F25.34.6.1.rar Edited October 21 by Nick A 0 Quote
John Taylor Posted October 21 Posted October 21 (edited) @nick a Thanks will check it out, Did you post it anywhere or do I need to ask them directly? Edited October 21 by John Taylor Incomplete message 0 Quote
Алексей Торопов Posted October 21 Posted October 21 16.10.2025 в 06:24, Nick A сказал: git clone https://github.com/NickAlilovic/build.git --branch v20251014 [🔨] Failed to apply 2 patches: ->0801-net-wireless-backport-aic8800-sdio-v2025_0410_gb99ca8b6-mm2(:1) (+90143/-0)[2M, 135A] {aicwf_firmware_array.c, rwnx_main.c, rwnx_msg_tx.c, aicwf_sdio.c, rwnx_platform.c, lmac_msg.h, regdb.c, aic8800dc_compat.c, rwnx_rx.c, rwnx_debugfs.c, rwnx_tx.c, aic_bsp_driver.c, aicsdio.c, aic_priv_cmd.c, rwnx_mod_params.c, rwnx_radar.c, aic_br_ext.c, rwnx_msg_rx.c, rwnx_txq.c, rwnx_events.h, aic_btsdio.c, aic_vendor.c, aic8800_btlpm.c, lpm.c, aicwf_usb.c, aicwf_txrxif.c, rwnx_tdls.c, ipc_shared.h, rwnx_defs.h, aicwf_compat_8800dc.c, rwnx_mu_group.c, aicwf_tcp_ack.c, aic_bsp_driver.h, rwnx_cmds.c, lmac_mac.h, aic_btsdio.h, aicsdio_txrxif.c, aic_bsp_main.c, rwnx_compat.h, rwnx_gki.c, rwnx_txq.h, rwnx_rx.h, hal_desc.h, aic_vendor.h, btsdio.c, rwnx_dini.c, aicwf_txrxif.h, aic8800d80_compat.c, rwnx_strs.c, rwnx_cfgfile.c, rwnx_testmode.c, aicwf_sdio.h, aicsdio_txrxif.h, rwnx_debugfs.h, rwnx_msg_tx.h, rwnx_tx.h, rwnx_v7.c, rwnx_mu_group.h, ipc_host.h, aicwf_compat_8800d80.c, md5.c, rwnx_radar.h, rwnx_platform.h, aicsdio.h, reg_access.h, usb_host.c, sdio_host.c, rwnx_prof.h, rwnx_utils.h, rwnx_cmds.h, rwnx_bfmer.c, rwnx_bfmer.h, aicwf_usb.h, aicwf_rx_prealloc.c, rwnx_wakelock.c, rwnx_pci.c, aicwf_tcp_ack.h, aic_bluetooth_main.c, rfkill.c, rwnx_mod_params.h, aic_br_ext.h, rwnx_gki.h, rwnx_irqs.c, aic_bsp_export.h, rwnx_testmode.h, aicwf_txq_prealloc.c, lmac_types.h, aicwf_debug.h, rwnx_tdls.h, ipc_host.c, md5.h, rwnx_fw_trace.c, rwnx_mesh.h, rwnx_mesh.c, aic8800dc_compat.h, sdio_host.h, usb_host.h, rwnx_utils.c, aic8800_bsp.mod.c, rwnx_cfgfile.h, rwnx_fw_trace.h, aic_priv_cmd.h, rwnx_strs.h, aic8800_fdrv.mod.c, rwnx_main.h, ipc_compat.h, aic8800d80_compat.h, aicwf_rx_prealloc.h, aic8800_btlpm.mod.c, lpm.h, rwnx_wakelock.h, rwnx_dini.h, rwnx_irqs.h, rwnx_v7.h, rwnx_msg_rx.h, rfkill.h, rwnx_pci.h, aicwf_compat_8800d80.h, aicwf_compat_8800dc.h, rwnx_version.h, aicwf_txq_prealloc.h, rwnx_version_gen.h, aicwf_firmware_array.h, Makefile, Kconfig}<-,->0803-net-wireless-backport-aic8800-usb-v2025_0410_gb99ca8b6-mm2(:1) (+75824/-0)[2M, 128A] {rwnx_main.c, rwnx_msg_tx.c, rwnx_platform.c, aicwf_compat_8800dc.c, lmac_msg.h, regdb.c, rwnx_rx.c, rwnx_debugfs.c, rwnx_tx.c, rwnx_mod_params.c, aicwf_usb.c, aic_priv_cmd.c, rwnx_msg_rx.c, rwnx_radar.c, aic_br_ext.c, rwnx_txq.c, aicwf_txrxif.c, aicbluetooth.c, aicwf_sdio.c, rwnx_events.h, aicwf_wext_linux.c, aic_vendor.c, rwnx_defs.h, ipc_shared.h, rwnx_tdls.c, ipc_host.c, aic_compat_8800d80x2.c, aic_compat_8800d80.c, rwnx_mu_group.c, aicwf_tcp_ack.c, rwnx_cmds.c, lmac_mac.h, rwnx_fw_dump.c, ipc_host.h, aic_txrxif.c, aicbluetooth_cmds.c, rwnx_compat.h, rwnx_rx.h, rwnx_txq.h, hal_desc.h, aic_vendor.h, aicbluetooth_cmds.h, aicwf_txrxif.h, reg_ipc_app.h, rwnx_dini.c, rwnx_strs.c, aicwf_usb.h, rwnx_cfgfile.c, rwnx_testmode.c, aic_txrxif.h, rwnx_debugfs.h, rwnx_msg_tx.h, rwnx_tx.h, rwnx_v7.c, rwnx_mu_group.h, rwnx_platform.h, md5.c, reg_access.h, rwnx_radar.h, usb_host.c, sdio_host.c, rwnx_utils.h, rwnx_prof.h, aicwf_rx_prealloc.c, rwnx_cmds.h, rwnx_bfmer.c, rwnx_bfmer.h, aicwf_sdio.h, rwnx_wakelock.c, aicwf_compat_8800d80x2.c, aicwf_compat_8800d80.c, rwnx_pci.c, aicwf_tcp_ack.h, aic_bluetooth_main.c, rwnx_mod_params.h, aic_br_ext.h, rwnx_irqs.c, rwnx_testmode.h, aicwf_compat_8800dc.h, lmac_types.h, aicwf_txq_prealloc.c, rwnx_tdls.h, aic_compat_8800d80.h, aicwf_debug.h, md5.h, rwnx_main.h, rwnx_fw_trace.c, rwnx_mesh.h, aic_compat_8800d80x2.h, usb_host.h, rwnx_mesh.c, sdio_host.h, aic_load_fw.mod.c, rwnx_utils.c, aicbluetooth.h, rwnx_cfgfile.h, rwnx_fw_trace.h, aic_priv_cmd.h, rwnx_strs.h, aicwf_rx_prealloc.h, ipc_compat.h, rwnx_wakelock.h, rwnx_dini.h, rwnx_irqs.h, rwnx_v7.h, rwnx_msg_rx.h, rwnx_gki.c, rwnx_pci.h, aicwf_wext_linux.h, rwnx_gki.h, rwnx_version.h, aicwf_compat_8800d80.h, aicwf_compat_8800d80x2.h, rwnx_version_gen.h, aicwf_txq_prealloc.h, Kconfig, Makefile}<- [🔨] Summary: kernel patching: 272 total patches; 270 applied; 216 with problems; 154 not_mbox; 152 needs_rebase; 1 invalid_utf8; 3 invalid_diff; 2 failed_apply; 1 overwrites 0 Quote
MeJune Posted October 31 Posted October 31 (edited) After wanting to use Debian 13 (Trixie) @Nick A suggested trying to build it myself, and this was my first experience building an Armbian image. I encountered some obstacles, but I got through them. I saw that the model was mentioned branch v20251014. I tried building it (Mate Desktop), which as build smoother than (v20250306) before. I tried booting it with this box (Transpeed 8K618-T) and and found that the wifi was not visible. I followed the troubleshooting methods in the previous thread solved it. I have installed additional IR remote and OpenVFD. Now everything is smooth and happy. The only thing left is the video acceleration, but that would be difficult because it is beyond my ability. Finally, thank you, @Nick A Edited October 31 by MeJune 1 Quote
robertoj Posted October 31 Posted October 31 Getting video acceleration is realtively easy in bookworm, but making it work in Trixie would be newsworthy 1 Quote
MeJune Posted Monday at 03:50 AM Posted Monday at 03:50 AM @robertoj Yes, yesterday I installed ffmpeg package from jok's repository and tested mp4,webm videos through mpv/smplayer/vlc or even chromium at 1080p@30 smoothly. (@60 stuttering) It's great for software decoding. Now all I need is to watch youtube smoothly on chromium at 1080p. From what I've seen in the comments on the forums, it seems like chromium needs to be new compiled with v4l2 patch and the kernel needs to support it. This is where it gets really difficult for me. 0 Quote
robertoj Posted Monday at 11:28 PM Posted Monday at 11:28 PM (edited) In bookworm, trixie or noble? Edited Monday at 11:28 PM by robertoj 0 Quote
John Taylor Posted Tuesday at 12:11 AM Posted Tuesday at 12:11 AM @robertoj I use Nick's exact build (specify the branch) with bookworm. My tanix68 unit has a custom Hal and supplicant firmware, which I'm trying to integrate correctly, but LAN works just fine. 0 Quote
emor acid Posted 1 hour ago Posted 1 hour ago On 10/14/2025 at 10:09 PM, Nick A said: sudo pico arch/arm64/boot/dts/allwinner/sun50i-h618-x98h.dts I have a question. After making the modifications as described above and executing the `compile.sh` script, the file `arch/arm64/boot/dts/allwinner/sun50i-h618-x98h.dts` reverts to its original state. Is this normal? How can I determine if my changes have been compiled into the image? @Nick A 0 Quote
Nick A Posted 9 minutes ago Posted 9 minutes ago @emor acid The build system downloads the original uboot and kernel sources. Then it applies the patches on top. Whatever you edited will be erased. The only way around this is to create a patch with your changes. You could use dtc to compile your dts file into a binary dtb. Then copy it into your sdcard. 0 Quote
