On 5/10/2025 at 8:29 PM, Nick A said:
You could use this tool to extract your dram settings from an android update or boot0.bin.
https://github.com/apritzel/sunxi-fw
sunxi-fw info -v boot0.bin
Hi @Nick A, I really need your help to understand the way to change the 171-add-x98h-defconfig.patch. Firstly, I extracted the DRAM parameters, but there are 15 of them: DRAM parameters, DRAM parameters 1, ... DRAM parameters E. Some of them have distinct parameters. The first of then (DRAM parameters) have the very identical parameters as yours, only differ in the same parameters, that isn't in patch file like TPR13, but I don't know if it matters. So I tried using the DRAM parameters 1, which is the most different, with clock 600 instead of 648 and almost all parameters different, but it works the same way with the same 2GB of RAM.
I think this is strange, because with so many differences, I expected the image would not work. Do you have any tips for giving me?
My extracted parameters:
./sunxi-fw info -v ./image4.img
@   0: wty: PhoenixSuite image file
    header v3.0, 45 images, 1859 MB
        wty:sys_config.fex      :       34908 bytes @ +0x000000b800
        wty:board.fex           :        1024 bytes @ +0x0000014400
        wty:config.fex          :       53248 bytes @ +0x0000014800
        wty:split_xxxx.fex      :         512 bytes @ +0x0000021800
        wty:sys_partition.fex   :        5601 bytes @ +0x0000021c00
        wty:sunxi.fex           :       71680 bytes @ +0x0000023400
        wty:boot0_nand.fex      :       61440 bytes @ +0x0000034c00
        wty:boot0_sdcard.fex    :       61440 bytes @ +0x0000043c00
        wty:u-boot.fex          :      917504 bytes @ +0x0000052c00
        wty:u-boot-crash.fex    :          37 bytes @ +0x0000132c00
        wty:toc1.fex            :           8 bytes @ +0x0000133000
        wty:toc0.fex            :           8 bytes @ +0x0000133400
        wty:fes1.fex            :       40160 bytes @ +0x0000133800
        wty:boot_package.fex    :     1294336 bytes @ +0x000013d800
        wty:usbtool.fex         :      154624 bytes @ +0x0000279800
        wty:usbtool_crash.fex   :      621056 bytes @ +0x000029f400
        wty:aultools.fex        :      166515 bytes @ +0x0000337000
        wty:aultls32.fex        :      152069 bytes @ +0x000035fc00
        wty:cardtool.fex        :       73728 bytes @ +0x0000385000
        wty:cardscript.fex      :        1899 bytes @ +0x0000397000
        wty:sunxi_gpt.fex       :        8192 bytes @ +0x0000397800
        wty:sunxi_mbr.fex       :       65536 bytes @ +0x0000399800
        wty:dlinfo.fex          :       16384 bytes @ +0x00003a9800
        wty:arisc.fex           :           6 bytes @ +0x00003ad800
        wty:vmlinux.fex         :    12444168 bytes @ +0x00003adc00
        wty:boot-resource.fex   :     7490560 bytes @ +0x0000f8c000
        wty:Vboot-resource.fex  :           4 bytes @ +0x00016b0c00
        wty:env.fex             :      131072 bytes @ +0x00016b1000
        wty:Venv.fex            :           4 bytes @ +0x00016d1000
        wty:boot.fex            :    67108864 bytes @ +0x00016d1400
        wty:Vboot.fex           :           4 bytes @ +0x00056d1400
        wty:vendor_boot.fex     :    33554432 bytes @ +0x00056d1800
        wty:Vvendor_boot.fex    :           4 bytes @ +0x00076d1800
        wty:super.fex           :  1806382676 bytes @ +0x00076d1c00
        wty:Vsuper.fex          :           4 bytes @ +0x0073185400
        wty:misc.fex            :    16777216 bytes @ +0x0073185800
        wty:Vmisc.fex           :           4 bytes @ +0x0074185800
        wty:vbmeta.fex          :        8192 bytes @ +0x0074185c00
        wty:Vvbmeta.fex         :           4 bytes @ +0x0074187c00
        wty:vbmeta_system.fex   :        4096 bytes @ +0x0074188000
        wty:Vvbmeta_system.fex  :           4 bytes @ +0x0074189000
        wty:vbmeta_vendor.fex   :        4096 bytes @ +0x0074189400
        wty:Vvbmeta_vendor.fex  :           4 bytes @ +0x007418a400
        wty:dtbo.fex            :     2097152 bytes @ +0x007418a800
        wty:Vdtbo.fex           :           4 bytes @ +0x007438a800
@ 542: boot0: Allwinner boot0
    eGON checksum matches: 0x505a301a
    DRAM parameters:           A64        H616        A133
        DRAM clock  :         648         648         648
        DRAM type   :         0x3         0x3         0x3
        ZQ value    :   0x3030303           -           -
        ODT enabled :   0xe0e0e0e         0x1           -
        DX ODT      :           -   0x3030303   0x3030303
        DX DRI      :           -   0xe0e0e0e   0xe0e0e0e
        CA DRI      :           -      0x1f12      0x1f12
        PARA0       :           -           -         0x1
        PARA1       :      0x1f12      0x30fb      0x30fb
        PARA2       :         0x1           0           0
        MR0         :      0x30fb       0x840       0x840
        MR1         :           0         0x4         0x4
        MR2         :       0x840         0x8         0x8
        MR3         :         0x4           0           0
        TPR0        :         0x8  0xc0001002           0
        TPR2        :           0           0  0xc0001002
        TPR6        :           0  0x33808080  0x33808080
        TPR10       :           0    0x2f1107    0x2f1107
        TPR11       :           0  0xddddcccc  0xddddcccc
        TPR12       :  0xc0001002  0xeddc7665  0xeddc7665
        TPR13       :           0        0x40        0x40
    DRAM parameters 1:         A64        H616        A133
        DRAM clock  :         600         600         600
        CA DRI      :           -      0x1c1a      0x1c1a
        PARA0       :           -           -         0x1
        PARA1       :      0x1c1a      0x30fb      0x30fb
        PARA2       :         0x1           0           0
        MR1         :           0         0x4         0x4
        MR2         :       0x840         0x8         0x8
        MR3         :         0x4           0           0
        TPR0        :         0x8  0xc000130a           0
        TPR2        :           0           0  0xc000130a
        TPR10       :           0    0x2f0006    0x2f0006
        TPR12       :  0xc000130a  0xeddc6554  0xeddc6554
        TPR13       :           0        0x40        0x40
    DRAM parameters 2:         A64        H616        A133
        CA DRI      :           -      0x1c12      0x1c12
        PARA0       :           -           -         0x1
        PARA1       :      0x1c12      0x30fb      0x30fb
        PARA2       :         0x1           0           0
        MR1         :           0         0x4         0x4
        MR2         :       0x840         0x8         0x8
        MR3         :         0x4           0           0
        TPR0        :         0x8  0xc0000a05           0
        TPR2        :           0           0  0xc0000a05
        TPR12       :  0xc0000a05  0xeddc7564  0xeddc7564
        TPR13       :           0        0x40        0x40
    DRAM parameters 3:         A64        H616        A133
        PARA0       :           -           -         0x1
        PARA2       :         0x1           0           0
        MR1         :           0         0x4         0x4
        MR2         :       0x840         0x8         0x8
        MR3         :         0x4           0           0
        TPR13       :           0        0x40        0x40
    DRAM parameters 4:         A64        H616        A133
        PARA0       :           -           -         0x1
        PARA2       :         0x1           0           0
        MR1         :           0         0x4         0x4
        MR2         :       0x840         0x8         0x8
        MR3         :         0x4           0           0
        TPR13       :           0        0x40        0x40
    DRAM parameters 5:         A64        H616        A133
        PARA0       :           -           -         0x1
        PARA2       :         0x1           0           0
        MR1         :           0         0x4         0x4
        MR2         :       0x840         0x8         0x8
        MR3         :         0x4           0           0
        TPR13       :           0        0x40        0x40
    DRAM parameters 6:         A64        H616        A133
        PARA0       :           -           -         0x1
        PARA2       :         0x1           0           0
        MR1         :           0         0x4         0x4
        MR2         :       0x840         0x8         0x8
        MR3         :         0x4           0           0
        TPR13       :           0        0x40        0x40
    DRAM parameters 7:         A64        H616        A133
        PARA0       :           -           -         0x1
        PARA2       :         0x1           0           0
        MR1         :           0         0x4         0x4
        MR2         :       0x840         0x8         0x8
        MR3         :         0x4           0           0
        TPR13       :           0        0x40        0x40
    DRAM parameters 8:         A64        H616        A133
        PARA0       :           -           -         0x1
        PARA2       :         0x1           0           0
        MR1         :           0         0x4         0x4
        MR2         :       0x840         0x8         0x8
        MR3         :         0x4           0           0
        TPR13       :           0        0x40        0x40
    DRAM parameters 9:         A64        H616        A133
        PARA0       :           -           -         0x1
        PARA2       :         0x1           0           0
        MR1         :           0         0x4         0x4
        MR2         :       0x840         0x8         0x8
        MR3         :         0x4           0           0
        TPR13       :           0        0x40        0x40
    DRAM parameters A:         A64        H616        A133
        PARA0       :           -           -         0x1
        PARA2       :         0x1           0           0
        MR1         :           0         0x4         0x4
        MR2         :       0x840         0x8         0x8
        MR3         :         0x4           0           0
        TPR13       :           0        0x40        0x40
    DRAM parameters B:         A64        H616        A133
        PARA0       :           -           -         0x1
        PARA2       :         0x1           0           0
        MR1         :           0         0x4         0x4
        MR2         :       0x840         0x8         0x8
        MR3         :         0x4           0           0
        TPR13       :           0        0x40        0x40
    DRAM parameters C:         A64        H616        A133
        PARA0       :           -           -         0x1
        PARA2       :         0x1           0           0
        MR1         :           0         0x4         0x4
        MR2         :       0x840         0x8         0x8
        MR3         :         0x4           0           0
        TPR13       :           0        0x40        0x40
    DRAM parameters D:         A64        H616        A133
        PARA0       :           -           -         0x1
        PARA2       :         0x1           0           0
        MR1         :           0         0x4         0x4
        MR2         :       0x840         0x8         0x8
        MR3         :         0x4           0           0
        TPR13       :           0        0x40        0x40
    DRAM parameters E:         A64        H616        A133
        PARA0       :           -           -         0x1
        PARA2       :         0x1           0           0
        MR1         :           0         0x4         0x4
        MR2         :       0x840         0x8         0x8
        MR3         :         0x4           0           0
        TPR13       :           0        0x40        0x40
I think the only difference with x98h is the emmc gpio #. So it should boot but not off of emmc. Unless x98h has the correct value.
I'm not sure if this will fix your problem because it's the kernel not detecting your dram. I don't know why. You can ask for help in this IRC channel.
https://oftc.catirclogs.org/linux-sunxi/2025-05-18
You can find the dram config options here. I don't see TPR13 as an option so you can leave that out.
https://elixir.bootlin.com/u-boot/v2025.07-rc2/source/arch/arm/mach-sunxi/Kconfig
if DRAM_SUN50I_H616
config DRAM_SUNXI_DX_ODT
	hex "DRAM DX ODT parameter"
	help
	  DX ODT value from vendor DRAM settings.
config DRAM_SUNXI_DX_DRI
	hex "DRAM DX DRI parameter"
	help
	  DX DRI value from vendor DRAM settings.
config DRAM_SUNXI_CA_DRI
	hex "DRAM CA DRI parameter"
	help
	  CA DRI value from vendor DRAM settings.
config DRAM_SUNXI_ODT_EN
	hex "DRAM ODT EN parameter"
	default 0x1
	help
	  ODT EN value from vendor DRAM settings.
config DRAM_SUNXI_TPR0
	hex "DRAM TPR0 parameter"
	default 0x0
	help
	  TPR0 value from vendor DRAM settings.
config DRAM_SUNXI_TPR2
	hex "DRAM TPR2 parameter"
	default 0x0
	help
	  TPR2 value from vendor DRAM settings.
config DRAM_SUNXI_TPR6
	hex "DRAM TPR6 parameter"
	default 0x3300c080
	help
	  TPR6 value from vendor DRAM settings.
config DRAM_SUNXI_TPR10
	hex "DRAM TPR10 parameter"
	help
	  TPR10 value from vendor DRAM settings. It tells which features
	  should be configured, like write leveling, read calibration, etc.
config DRAM_SUNXI_TPR11
	hex "DRAM TPR11 parameter"
	default 0x0
	help
	  TPR11 value from vendor DRAM settings.
config DRAM_SUNXI_TPR12
	hex "DRAM TPR12 parameter"
	default 0x0
	help
	  TPR12 value from vendor DRAM settings.
Edited by Nick A
20 часов назад, Nick A сказал:
You need to add the module config to the kernel configuration file and compile a new image.  Edit the kernel configuration file manually.
Thank you, I tried. But this is not my level, it is too difficult for me.
I'll probably wait for your next release.
klipper@transpeed-8k618-t:~/8821au-20210708$ sudo modprobe 8812au
modprobe: ERROR: could not insert '8812au': Unknown symbol in module, or unknown parameter (see dmesg)
klipper@transpeed-8k618-t:~/8821au-20210708$ sudo dmesg | grep 8812
[    7.950162] module 8812au: .gnu.linkonce.this_module section size must match the kernel's built struct module size at run time
klipper@transpeed-8k618-t:~/8821au-20210708$ dkms status
rtl8812au/5.13.6-23, 6.12.11-edge-sunxi64, aarch64: installed
rtl8821au/5.12.5.2, 6.12.11-edge-sunxi64, aarch64: installed
I've compile a new image with MT7601U, it works.
What should I do for rtl8812 to work?
That github page tells you that the in-kernel driver is better than morrownr's driver.
Have you tried that first? Search for rtw88 in the /lib/modules folder
Try rebuilding armbian, find rtw88 or 8812au in the linux configuration menu and activate them.
12.06.2025 в 00:12, robertoj сказал:
This is 88XXAU in the config. Yes, this driver allows you to see the device as a network device, the adapter gets a new interface name wlx<macaddress>, but it cannot connect to the network and does not receive a list of available networks.
I don't know what else to do... I usually research and learn on the go :)
Search the 88xxau.c in your downloaded linux source. Try to find any link to documentation or github.
Search 8812au in the respberry pi forum
On 10/3/2024 at 3:59 PM, MMorales said:
First go to armbian-config to change some kernel with has his own headers available like 6.10.9 (i had problem with rebooting with 6.7.12)
configure an internet connection
unpack the attached file to root dir /
cd /linux_openvfd
cp openvfd.dts /boot/dtb/allwinner/overlay/
armbian-add-overlay /boot/dtb/allwinner/overlay/openvfd.dts
reboot
ln -sf /boot/System.map-$(uname -r) /lib/modules/$(uname -r)/build/System.map
cd cd /linux_openvfd/driver
make -j 4
depmod -a
make modules_install
modprobe openvfd
cd ..
chmod +x OpenVFDService
cp OpenVFDService /usr/sbin/
cp openvfd.service /etc/systemd/system/openvfd.service
#apt install python3-psutil
systemctl enable openvfd.service
systemctl start openvfd.service
After this, openvfd is working but if you want my scroll.py as a service uncomment in openvfd.service and comment the existing one.
#ExecStart=/bin/sh -c '[ `cat /proc/device-tree/openvfd/compatible` = "open,vfd" ] && /sbin/modprobe openvfd; python3 /linux_openvfd/scroll.py'
Correct openvfd.dts, some compiling fixes and extra glyphs for cool animations added to this file.
# make -j 4
make -C /lib/modules/6.12.33-current-meson64/build M=/home/INSTALKI/linux_openvfd/driver modules
make[1]: Enter the directory '/usr/src/linux-headers-6.12.33-current-meson64'
  CC [M]  /home/INSTALKI/linux_openvfd/driver/protocols/i2c_sw.o
  CC [M]  /home/INSTALKI/linux_openvfd/driver/protocols/i2c_hw.o
  CC [M]  /home/INSTALKI/linux_openvfd/driver/protocols/spi_sw.o
  CC [M]  /home/INSTALKI/linux_openvfd/driver/controllers/dummy.o
  CC [M]  /home/INSTALKI/linux_openvfd/driver/controllers/seg7_ctrl.o
/home/INSTALKI/linux_openvfd/driver/controllers/seg7_ctrl.c:11:6: warning: no previous prototype for ‘transpose8rS64’ [-Wmissing-prototypes]
   11 | void transpose8rS64(unsigned char* A, unsigned char* B) {
/home/INSTALKI/linux_openvfd/driver/controllers/seg7_ctrl.c:40:8: warning: no previous prototype for ‘seg7_write_display_data’ [-Wmissing-prototypes]
   40 | size_t seg7_write_display_data(const struct vfd_display_data *data, unsigned short *raw_wdata, size_t sz)
  CC [M]  /home/INSTALKI/linux_openvfd/driver/controllers/fd628.o
  CC [M]  /home/INSTALKI/linux_openvfd/driver/controllers/fd650.o
  CC [M]  /home/INSTALKI/linux_openvfd/driver/controllers/hd44780.o
  CC [M]  /home/INSTALKI/linux_openvfd/driver/controllers/gfx_mono_ctrl.o
  CC [M]  /home/INSTALKI/linux_openvfd/driver/controllers/ssd1306.o
  CC [M]  /home/INSTALKI/linux_openvfd/driver/controllers/pcd8544.o
/home/INSTALKI/linux_openvfd/driver/controllers/gfx_mono_ctrl.c:239:6: warning: no previous prototype for ‘transpose_buffer’ [-Wmissing-prototypes]
  239 | void transpose_buffer(unsigned char *buffer, const struct rect *rect)
  CC [M]  /home/INSTALKI/linux_openvfd/driver/controllers/il3829.o
  CC [M]  /home/INSTALKI/linux_openvfd/driver/openvfd_drv.o
/home/INSTALKI/linux_openvfd/driver/openvfd_drv.c:44:7: warning: "CONFIG_AMLOGIC_LEGACY_EARLY_SUSPEND" is not defined, evaluates to 0 [-Wundef]
   44 | #elif CONFIG_AMLOGIC_LEGACY_EARLY_SUSPEND
/home/INSTALKI/linux_openvfd/driver/openvfd_drv.c: In function ‘register_openvfd_driver’:
/home/INSTALKI/linux_openvfd/driver/openvfd_drv.c:400:75: warning: suggest braces around empty body in an ‘else’ statement [-Wempty-body]
  400 |                 pr_dbg("%s: Succeeded to add openvfd module \n", __func__);
/home/INSTALKI/linux_openvfd/driver/openvfd_drv.c: At top level:
/home/INSTALKI/linux_openvfd/driver/openvfd_drv.c:622:19: warning: no previous prototype for ‘gpiochip_find’ [-Wmissing-prototypes]
  622 | struct gpio_chip *gpiochip_find(void *data,
/home/INSTALKI/linux_openvfd/driver/openvfd_drv.c:669:5: warning: no previous prototype for ‘evaluate_pin’ [-Wmissing-prototypes]
  669 | int evaluate_pin(const char *name, const unsigned int *vfd_arg, struct vfd_pin *pin, unsigned char enable_skip_evaluation)
/home/INSTALKI/linux_openvfd/driver/openvfd_drv.c:752:6: warning: no previous prototype for ‘get_pin_from_dt’ [-Wmissing-prototypes]
  752 | void get_pin_from_dt(const char *name, const struct platform_device *pdev, struct vfd_pin *pin)
/home/INSTALKI/linux_openvfd/driver/openvfd_drv.c:763:5: warning: no previous prototype for ‘request_pin’ [-Wmissing-prototypes]
  763 | int request_pin(const char *name, struct vfd_pin *pin, unsigned char enable_skip)
/home/INSTALKI/linux_openvfd/driver/openvfd_drv.c:1034:19: error: initialization of ‘void (*)(struct platform_device *)’ from incompatible pointer type ‘int (*)(struct platform_device *)’ [-Werror=incompatible-pointer-types]
 1034 |         .remove = openvfd_driver_remove,
/home/INSTALKI/linux_openvfd/driver/openvfd_drv.c:1034:19: note: (near initialization for ‘openvfd_driver.<anonymous>.remove’)
/home/INSTALKI/linux_openvfd/driver/openvfd_drv.c: In function ‘print_param_debug’:
/home/INSTALKI/linux_openvfd/driver/openvfd_drv.c:611:1: warning: the frame size of 1040 bytes is larger than 1024 bytes [-Wframe-larger-than=]
  611 | }
cc1: some warnings being treated as errors
make[3]: *** [scripts/Makefile.build:229: /home/INSTALKI/linux_openvfd/driver/openvfd_drv.o] Error 1
make[2]: *** [/usr/src/linux-headers-6.12.33-current-meson64/Makefile:1945: /home/INSTALKI/linux_openvfd/driver] Error 2
make[1]: *** [Makefile:224: __sub-make] Error 2
make[1]: Leaving the directory '/usr/src/linux-headers-6.12.33-current-meson64'
make: *** [Makefile:5: modules] Error 2
I'm trying to compile the "openvfd" driver but the compilation ends with an error.
I'm a complete noob at these things and I really want this driver
so I'd be very grateful for any help.
On 6/23/2025 at 12:00 AM, c0rnelius said:
It needs to be patched against the source-tree.
And how to compile openvfd with this patch?
How to apply this patch to openvfd?
18.09.2024 в 16:33, Nick A сказал:
I edited the broadcom kernel drivers.
/drivers/net/wireless/broadcom/brcm80211/include/brcm_hw_ids.h
#define BRCM_CC_43342_CHIP_ID    43342
/drivers/net/wireless/broadcom/brcm80211/brcmfmac/sdio.c
BRCMF_FW_DEF(43342, "brcmfmac43342-sdio");
BRCMF_FW_ENTRY(BRCM_CC_43342_CHIP_ID, 0xFFFFFFFF, 43342),
I made a patch for you. Copy the patch to build/patch/kernel/archive/sunxi-6.9/patches.armbian directory.
Edit build/patch/kernel/archive/sunxi-6.9/series.armbian and build/patch/kernel/archive/sunxi-6.9/series.conf to include the new patch.
Then copy firmware files below to your sdcard.
I've used this patch, but it doesn't work for my case.
Is it possible to change something for this chip?
klipperr@transpeed-8k618-t:~$ dmesg | grep brcmf
[    9.510496] brcmfmac: brcmf_fw_alloc_request: Unknown chip BCM43342/1
[   10.520808] brcmfmac: brcmf_sdio_htclk: HT Avail timeout (1000000): clkctl 0x50
[   10.545676] brcmfmac: brcmf_ops_sdio_probe: F2 error, probe failed -19...
[   10.546133] usbcore: registered new interface driver brcmfmac
Edited by Алексей Торопов
On 6/26/2025 at 2:21 PM, c0rnelius said:
Build a new  IMG or KERNEL as one normally would for your unit.
I did so, but openvfd still doesn't work and can't compile.
One more tv-box, HK1 Rbox.
It hase an HK2735M chip
Almost all things works, but WiFi can't connect to 5G, while 2.4 work fine. It see 5G AP, but connection fail.
@transpeed-8k618-t:~$ dmesg | grep brcmfmac
[    7.019181] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac4335-sdio for chip BCM4335/1
[    7.019857] usbcore: registered new interface driver brcmfmac
[    7.094608] brcmfmac mmc2:0001:1: Direct firmware load for brcm/brcmfmac4335-sdio.clm_blob failed with error -2
[    7.094631] brcmfmac mmc2:0001:1: Falling back to sysfs fallback for: brcm/brcmfmac4335-sdio.clm_blob
[    9.242828] brcmfmac: brcmf_c_process_clm_blob: no clm_blob available (err=-2), device may have limited channels available
[    9.242856] brcmfmac: brcmf_c_process_txcap_blob: no txcap_blob available (err=-2)
[    9.243349] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4335/1 wl0: Mar 24 2013 20:36:01 version 6.30.171.24.20 (B0 Station/P2P)
PS: Okay, that's fixed. I just changed the channel on the router, it works with channel less than 40
26.06.2025 в 15:21, c0rnelius сказал:
Add the patch to: patch/kernel/archive/meson64-6.12/
Enable in the defconfig: echo "CONFIG_OPENVFD=m" >> config/kernel/linux-meson64-current.config
OK, I did it. USB does not work when uploading a new image.
On 4/3/2025 at 7:03 AM, firepower said:
latest build  Armbian-unofficial 25.05.0-trunk noble, 6.12.11-edge-sunxi64, cinnamon 6.04
tanix-tx6s-axp313.csc
working: 3 USB, Wifi, IR remote,LED Clock
not working: Bluetooth,Video Acceleration, sound out via jack (2 analog audio output shown)
vontar-h618.csc
working: 2 USB, Wifi (needed to rename brcmfmac4334-sdio.rockchip,rk3318-box.txt > brcmfmac4334-sdio.txt), IR remote, LED Clock, sound jack out via jack (3 analog audio output shown)
not working: Bluetooth, Video Acceleration
Edited April 4 by firepower
Regarding video acceleration in H618:
Can you try the latest armbian with linux edge?
https://forum.armbian.com/topic/32449-repository-for-v4l2request-hardware-video-decoding-rockchip-allwinner/#findComment-216587
(the announcement refers to 6.13, but I don't know if it applies to 6.14 or 6.15)
... I think armbian 25.5.1 with linux edge option, builds linux 6.13.x
https://github.com/armbian/build/releases/tag/v25.5.1  (and it seems that minimal images de-activates v4l2)
I see the patches in my armbian build folder, I compiled in many ways, but I didn't get video acceleration.
I didn't get new kernel modules that seem to be related to the patch source code.
Perhaps I needed to check that the specific patches are activated or find the linux config option=m
Update: you can see that the Linux source files are applied, right before the compilation stage... copy paste the entire terminal scrolled text (or find the appropriate output/log/... file)... search the patch file names
I couldn't get acceleration, but hopefully someone else can, and share the method.
Edited by robertoj
I've been seeing compilation errors regularly these days:
jq: 1 compile error
[🚸] Could not find package filename for 'base-files' in distro repo [ looking for base-files, found_package_filename is  ]
[🚸] Command failed, retrying in 15s [ apt_find_upstream_package_version_and_download_url base-files ]
jq: error: syntax error, unexpected '/', expecting $end (Unix shell quoting issues?) at <top-level>, line 1:
/home/alex/build/.tmp/work-1f60b5cb-301f-4099-b761-2fb9f2bb57be/tmp.NGlcPEF1pE
jq: 1 compile error
Provide full logs
I have some issue trying to build a new image.
[🌱] artifact [ armbian-base-files :: armbian-base-files() ]
/home/nick/Desktop/build/.tmp/work-3ba39b3b-774c-4ca7-9727-9091c1861a2f/tmp.UXcUDUX3m2
jq: 1 compile error
/home/nick/Desktop/build/.tmp/work-3ba39b3b-774c-4ca7-9727-9091c1861a2f/tmp.E4L2MRkv6o
jq: 1 compile error
/home/nick/Desktop/build/.tmp/work-3ba39b3b-774c-4ca7-9727-9091c1861a2f/tmp.GvFd0v7vHh
jq: 1 compile error
If you restart the build with the same options it continues where the build left off and compiles fine.
[🌱] Found upstream base-files package filename [ base-files_12.4+deb12u11_arm64.deb ]
[🌱] Found base-files upstream package version [ 12.4+deb12u11 ]
[🌱] Getting ORAS manifest [ ORAS manifest from ghcr.io/armbian/os/armbian-base-files-bookworm-arm64:1-bookworm-1armbian1-Baa17-U12.4--deb12u11-R55fa ]
[🌱] Artifact is available in remote cache [ ghcr.io/armbian/os/armbian-base-files-bookworm-arm64:1-bookworm-1armbian1-Baa17-U12.4--deb12u11-R55fa - 'armbian-base-files-bookworm-arm64 - 1-bookworm-1armbian1-Baa17-U12.4--deb12u11-R55fa - Armbian armbian-base-files original bookworm version "12.4+deb12u11" framework bash hash "aa17ac95f5df03a9" - type: deb' ]
[🌱] Obtaining artifact from remote cache [ ghcr.io/armbian/os/armbian-base-files-bookworm-arm64:1-bookworm-1armbian1-Baa17-U12.4--deb12u11-R55fa into base-files_1-bookworm-1armbian1-Baa17-U12.4--deb12u11-R55fa_arm64.deb ]
✓ Pulled      base-files_1-bookworm-1armbian1-Baa17-U12.4--deb12u11-R55fa_arm64.deb        51.6/51.6 kB 100.00%   11ms
  └─ sha256:0fdb605bead0a6b686964f17e6cd33b487c94c32b01abdff64a72b9ec12590ec
✓ Pulled      application/vnd.oci.image.manifest.v1+json        901/901  B 100.00%  222µs
  └─ sha256:4ab7c71e4c8dd5f07c15499186dab687550c9237898f4e9fa99d72e76e232549
[🔨]   Pulled [registry] ghcr.io/armbian/os/armbian-base-files-bookworm-arm64:1-bookworm-1armbian1-Baa17-U12.4--deb12u11-R55fa
[🔨]   Digest: sha256:4ab7c71e4c8dd5f07c15499186dab687550c9237898f4e9fa99d72e76e232549
[💖] artifact [ obtained from remote cache: armbian-base-files-bookworm-arm64 1-bookworm-1armbian1-Baa17-U12.4--deb12u11-R55fa ]
[🌱] Reversioning package [ re-version 'armbian-base-files-bookworm-arm64(deb)::1-bookworm-1armbian1-Baa17-U12.4--deb12u11-R55fa' to '25.05.0-trunk-12.4+deb12u11-bookworm' ]
[🔨]   removed '/home/nick/Desktop/build/output/packages-hashed/extra/bookworm-utils/base-files_1-bookworm-1armbian1-Baa17-U12.4--deb12u11-R55fa_arm64.deb'
log-build-b4214f74-4d03-4030-9e38-7a16d2e86846.log
Edited by Nick A
