NiTr0 Posted October 20, 2025 Posted October 20, 2025 11.10.2025 в 18:31, Nick A сказал: I guess transferring the dtb to official armbian kernel 6.12.43 will work. Most of warpme’s collection of patches are already in the official armbian build. There might be some differences. it works OK on stock kernel, but there's some strange things with network/routing. I use static IP with static default route, and often when I run wget or apt install I've got 'network unreachable'; ping 8.8.8.8 -i 0.1 (or other IP not from internal subnet; for ex., external IP of router) - may ping OK without any losses for a seconds and then loss packets for seconds or even tens of seconds, or may report 'ping: Do you want to ping broadcast? Then -b. If not, check your local firewall rules' and exit. IPs from internal subnet are pinged OK. but when I tried to add static route for some external IP via default gateway - it starts to work OK, and works OK even when route is removed. does anybody noticed such strange things? 0 Quote
emor acid Posted October 20, 2025 Posted October 20, 2025 hi, Compilation error, I also decompiled the dts available for Android for reference output.dts @Nick A 0 Quote
Nick A Posted October 21, 2025 Posted October 21, 2025 (edited) @emor acid The error above says you are missing node or label "reg_gmac_3v3". Add this just below "reg_vcc5v" in in your dts. https://github.com/The-going/linux-sf/blob/aa1ea7ec81c99dbc42f6d2ea4244ab4f54d0f3ee/arch/arm64/boot/dts/allwinner/sun50i-h618-bananapi-m4-berry.dts#L101-L108 reg_gmac_3v3: gmac-3v3 { compatible = "regulator-fixed"; regulator-name = "gmac-3v3"; regulator-min-microvolt = <3300000>; regulator-max-microvolt = <3300000>; regulator-always-on; vin-supply = <®_vcc5v>; }; Edited October 21, 2025 by Nick A 0 Quote
Nick A Posted October 21, 2025 Posted October 21, 2025 (edited) @John Taylor I found the driver source code for your wifi but it's for an older android/linux kernel. I asked info@lb-link.com for the linux/android driver. They sent me SWT6621S_H25.34.7.1_F25.34.6.1.rar Edited October 21, 2025 by Nick A 0 Quote
John Taylor Posted October 21, 2025 Posted October 21, 2025 (edited) @nick a Thanks will check it out, Did you post it anywhere or do I need to ask them directly? Edited October 21, 2025 by John Taylor Incomplete message 0 Quote
Алексей Торопов Posted October 21, 2025 Posted October 21, 2025 16.10.2025 в 06:24, Nick A сказал: git clone https://github.com/NickAlilovic/build.git --branch v20251014 [🔨] Failed to apply 2 patches: ->0801-net-wireless-backport-aic8800-sdio-v2025_0410_gb99ca8b6-mm2(:1) (+90143/-0)[2M, 135A] {aicwf_firmware_array.c, rwnx_main.c, rwnx_msg_tx.c, aicwf_sdio.c, rwnx_platform.c, lmac_msg.h, regdb.c, aic8800dc_compat.c, rwnx_rx.c, rwnx_debugfs.c, rwnx_tx.c, aic_bsp_driver.c, aicsdio.c, aic_priv_cmd.c, rwnx_mod_params.c, rwnx_radar.c, aic_br_ext.c, rwnx_msg_rx.c, rwnx_txq.c, rwnx_events.h, aic_btsdio.c, aic_vendor.c, aic8800_btlpm.c, lpm.c, aicwf_usb.c, aicwf_txrxif.c, rwnx_tdls.c, ipc_shared.h, rwnx_defs.h, aicwf_compat_8800dc.c, rwnx_mu_group.c, aicwf_tcp_ack.c, aic_bsp_driver.h, rwnx_cmds.c, lmac_mac.h, aic_btsdio.h, aicsdio_txrxif.c, aic_bsp_main.c, rwnx_compat.h, rwnx_gki.c, rwnx_txq.h, rwnx_rx.h, hal_desc.h, aic_vendor.h, btsdio.c, rwnx_dini.c, aicwf_txrxif.h, aic8800d80_compat.c, rwnx_strs.c, rwnx_cfgfile.c, rwnx_testmode.c, aicwf_sdio.h, aicsdio_txrxif.h, rwnx_debugfs.h, rwnx_msg_tx.h, rwnx_tx.h, rwnx_v7.c, rwnx_mu_group.h, ipc_host.h, aicwf_compat_8800d80.c, md5.c, rwnx_radar.h, rwnx_platform.h, aicsdio.h, reg_access.h, usb_host.c, sdio_host.c, rwnx_prof.h, rwnx_utils.h, rwnx_cmds.h, rwnx_bfmer.c, rwnx_bfmer.h, aicwf_usb.h, aicwf_rx_prealloc.c, rwnx_wakelock.c, rwnx_pci.c, aicwf_tcp_ack.h, aic_bluetooth_main.c, rfkill.c, rwnx_mod_params.h, aic_br_ext.h, rwnx_gki.h, rwnx_irqs.c, aic_bsp_export.h, rwnx_testmode.h, aicwf_txq_prealloc.c, lmac_types.h, aicwf_debug.h, rwnx_tdls.h, ipc_host.c, md5.h, rwnx_fw_trace.c, rwnx_mesh.h, rwnx_mesh.c, aic8800dc_compat.h, sdio_host.h, usb_host.h, rwnx_utils.c, aic8800_bsp.mod.c, rwnx_cfgfile.h, rwnx_fw_trace.h, aic_priv_cmd.h, rwnx_strs.h, aic8800_fdrv.mod.c, rwnx_main.h, ipc_compat.h, aic8800d80_compat.h, aicwf_rx_prealloc.h, aic8800_btlpm.mod.c, lpm.h, rwnx_wakelock.h, rwnx_dini.h, rwnx_irqs.h, rwnx_v7.h, rwnx_msg_rx.h, rfkill.h, rwnx_pci.h, aicwf_compat_8800d80.h, aicwf_compat_8800dc.h, rwnx_version.h, aicwf_txq_prealloc.h, rwnx_version_gen.h, aicwf_firmware_array.h, Makefile, Kconfig}<-,->0803-net-wireless-backport-aic8800-usb-v2025_0410_gb99ca8b6-mm2(:1) (+75824/-0)[2M, 128A] {rwnx_main.c, rwnx_msg_tx.c, rwnx_platform.c, aicwf_compat_8800dc.c, lmac_msg.h, regdb.c, rwnx_rx.c, rwnx_debugfs.c, rwnx_tx.c, rwnx_mod_params.c, aicwf_usb.c, aic_priv_cmd.c, rwnx_msg_rx.c, rwnx_radar.c, aic_br_ext.c, rwnx_txq.c, aicwf_txrxif.c, aicbluetooth.c, aicwf_sdio.c, rwnx_events.h, aicwf_wext_linux.c, aic_vendor.c, rwnx_defs.h, ipc_shared.h, rwnx_tdls.c, ipc_host.c, aic_compat_8800d80x2.c, aic_compat_8800d80.c, rwnx_mu_group.c, aicwf_tcp_ack.c, rwnx_cmds.c, lmac_mac.h, rwnx_fw_dump.c, ipc_host.h, aic_txrxif.c, aicbluetooth_cmds.c, rwnx_compat.h, rwnx_rx.h, rwnx_txq.h, hal_desc.h, aic_vendor.h, aicbluetooth_cmds.h, aicwf_txrxif.h, reg_ipc_app.h, rwnx_dini.c, rwnx_strs.c, aicwf_usb.h, rwnx_cfgfile.c, rwnx_testmode.c, aic_txrxif.h, rwnx_debugfs.h, rwnx_msg_tx.h, rwnx_tx.h, rwnx_v7.c, rwnx_mu_group.h, rwnx_platform.h, md5.c, reg_access.h, rwnx_radar.h, usb_host.c, sdio_host.c, rwnx_utils.h, rwnx_prof.h, aicwf_rx_prealloc.c, rwnx_cmds.h, rwnx_bfmer.c, rwnx_bfmer.h, aicwf_sdio.h, rwnx_wakelock.c, aicwf_compat_8800d80x2.c, aicwf_compat_8800d80.c, rwnx_pci.c, aicwf_tcp_ack.h, aic_bluetooth_main.c, rwnx_mod_params.h, aic_br_ext.h, rwnx_irqs.c, rwnx_testmode.h, aicwf_compat_8800dc.h, lmac_types.h, aicwf_txq_prealloc.c, rwnx_tdls.h, aic_compat_8800d80.h, aicwf_debug.h, md5.h, rwnx_main.h, rwnx_fw_trace.c, rwnx_mesh.h, aic_compat_8800d80x2.h, usb_host.h, rwnx_mesh.c, sdio_host.h, aic_load_fw.mod.c, rwnx_utils.c, aicbluetooth.h, rwnx_cfgfile.h, rwnx_fw_trace.h, aic_priv_cmd.h, rwnx_strs.h, aicwf_rx_prealloc.h, ipc_compat.h, rwnx_wakelock.h, rwnx_dini.h, rwnx_irqs.h, rwnx_v7.h, rwnx_msg_rx.h, rwnx_gki.c, rwnx_pci.h, aicwf_wext_linux.h, rwnx_gki.h, rwnx_version.h, aicwf_compat_8800d80.h, aicwf_compat_8800d80x2.h, rwnx_version_gen.h, aicwf_txq_prealloc.h, Kconfig, Makefile}<- [🔨] Summary: kernel patching: 272 total patches; 270 applied; 216 with problems; 154 not_mbox; 152 needs_rebase; 1 invalid_utf8; 3 invalid_diff; 2 failed_apply; 1 overwrites 0 Quote
Nick A Posted October 21, 2025 Posted October 21, 2025 Delete the cache and output folder. Try again. 1 Quote
MeJune Posted October 31, 2025 Posted October 31, 2025 (edited) After wanting to use Debian 13 (Trixie) @Nick A suggested trying to build it myself, and this was my first experience building an Armbian image. I encountered some obstacles, but I got through them. I saw that the model was mentioned branch v20251014. I tried building it (Mate Desktop), which as build smoother than (v20250306) before. I tried booting it with this box (Transpeed 8K618-T) and and found that the wifi was not visible. I followed the troubleshooting methods in the previous thread solved it. I have installed additional IR remote and OpenVFD. Now everything is smooth and happy. The only thing left is the video acceleration, but that would be difficult because it is beyond my ability. Finally, thank you, @Nick A Edited October 31, 2025 by MeJune 1 Quote
robertoj Posted October 31, 2025 Posted October 31, 2025 Getting video acceleration is realtively easy in bookworm, but making it work in Trixie would be newsworthy 1 Quote
MeJune Posted November 3, 2025 Posted November 3, 2025 @robertoj Yes, yesterday I installed ffmpeg package from jok's repository and tested mp4,webm videos through mpv/smplayer/vlc or even chromium at 1080p@30 smoothly. (@60 stuttering) It's great for software decoding. Now all I need is to watch youtube smoothly on chromium at 1080p. From what I've seen in the comments on the forums, it seems like chromium needs to be new compiled with v4l2 patch and the kernel needs to support it. This is where it gets really difficult for me. 0 Quote
robertoj Posted November 3, 2025 Posted November 3, 2025 (edited) In bookworm, trixie or noble? Edited November 3, 2025 by robertoj 0 Quote
John Taylor Posted November 4, 2025 Posted November 4, 2025 @robertoj I use Nick's exact build (specify the branch) with bookworm. My tanix68 unit has a custom Hal and supplicant firmware, which I'm trying to integrate correctly, but LAN works just fine. 0 Quote
emor acid Posted November 8, 2025 Posted November 8, 2025 On 10/14/2025 at 10:09 PM, Nick A said: sudo pico arch/arm64/boot/dts/allwinner/sun50i-h618-x98h.dts I have a question. After making the modifications as described above and executing the `compile.sh` script, the file `arch/arm64/boot/dts/allwinner/sun50i-h618-x98h.dts` reverts to its original state. Is this normal? How can I determine if my changes have been compiled into the image? @Nick A 0 Quote
Nick A Posted November 8, 2025 Posted November 8, 2025 @emor acid The build system downloads the original uboot and kernel sources. Then it applies the patches on top. Whatever you edited will be erased. The only way around this is to create a patch with your changes. You could use dtc to compile your dts file into a binary dtb. Then copy it into your sdcard. 0 Quote
Алексей Торопов Posted November 8, 2025 Posted November 8, 2025 (edited) Please help, I'm stucked (or, may be stupid). I use my tv-box as printserver (Klipper), it works fine. Now I attempt to use accelerometer ADXL345 usb board, and I havnt success. It must be simple task, but something went wrong here. Board works, flashed normally without any errors and shown as should by lsusb: klipper@transpeed-8k618-t:/usr/lib/udev/rules.d$ lsusb Bus 003 Device 002: ID 1a86:7523 QinHeng Electronics CH340 serial converter Bus 003 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Bus 004 Device 013: ID 1d50:614e OpenMoko, Inc. rp2040 Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Also, it must be appear as serial device, but... klipper@transpeed-8k618-t:/usr/lib/udev/rules.d$ ls -l /dev/serial/by-id total 0 lrwxrwxrwx 1 root root 13 Nov 8 18:47 usb-1a86_USB_Serial-if00-port0 -> ../../ttyUSB0 ...here is my "Ender" only. dmesg: [30617.149526] usb 4-1: new full-speed USB device number 22 using ohci-platform [30617.358206] usb 4-1: New USB device found, idVendor=1d50, idProduct=6177, bcdDevice= 1.00 [30617.358227] usb 4-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3 [30617.358235] usb 4-1: Product: rp2040 [30617.358242] usb 4-1: Manufacturer: katapult [30617.358249] usb 4-1: SerialNumber: E6647C7403433637 [30663.467079] usb 3-1: new full-speed USB device number 3 using ohci-platform [30663.665820] usb 3-1: New USB device found, idVendor=1a86, idProduct=7523, bcdDevice= 2.64 [30663.665867] usb 3-1: New USB device strings: Mfr=0, Product=2, SerialNumber=0 [30663.665891] usb 3-1: Product: USB Serial [30663.668223] ch341 3-1:1.0: ch341-uart converter detected [30663.680198] usb 3-1: ch341-uart converter now attached to ttyUSB0 I've search solutions, but have not resolve. Edited November 9, 2025 by Алексей Торопов 0 Quote
Werner Posted November 10, 2025 Posted November 10, 2025 That's an interesting question. The chip itself seems to communiate via spi or i2c. Since USB cannot do that they put a raspberry microcontroller (RP2040) on it to handle this. The communication then uses a simple serial connection with the ch341 chip. I assume the klipper thingies can handle this by themselves automatically while when connecting this to a different device, you have to come up with some way to communicate with this board. 0 Quote
Алексей Торопов Posted November 10, 2025 Posted November 10, 2025 (edited) 8 часов назад, Werner сказал: The communication then uses a simple serial connection with the ch341 chip. Not exactly. CH341 is the connection of my printer (Klipper), and here all right: [30663.467079] usb 3-1: new full-speed USB device number 3 using ohci-platform [30663.665820] usb 3-1: New USB device found, idVendor=1a86, idProduct=7523, bcdDevice= 2.64 [30663.665867] usb 3-1: New USB device strings: Mfr=0, Product=2, SerialNumber=0 [30663.665891] usb 3-1: Product: USB Serial [30663.668223] ch341 3-1:1.0: ch341-uart converter detected [30663.680198] usb 3-1: ch341-uart converter now attached to ttyUSB0 Accelerometer board: [30617.149526] usb 4-1: new full-speed USB device number 22 using ohci-platform [30617.358206] usb 4-1: New USB device found, idVendor=1d50, idProduct=6177, bcdDevice= 1.00 [30617.358227] usb 4-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3 [30617.358235] usb 4-1: Product: rp2040 [30617.358242] usb 4-1: Manufacturer: katapult [30617.358249] usb 4-1: SerialNumber: E6647C7403433637 It looks like Armbian needs a driver. When connecting this card to Windows or Mac, the device is identified as a serial port. Probably, something like this - Enable ACM Edited November 10, 2025 by Алексей Торопов 0 Quote
Nick A Posted November 10, 2025 Posted November 10, 2025 (edited) You need to set this to y or m in your kernel config. https://github.com/NickAlilovic/build/blob/v20250306/config/kernel/linux-sunxi64-edge.config#L5745 https://www.kernelconfig.io/config_usb_acm Edited November 10, 2025 by Nick A 0 Quote
Алексей Торопов Posted November 11, 2025 Posted November 11, 2025 18 часов назад, Nick A сказал: You need to set this to y or m in your kernel config. Yes, already compile and all works now. root@transpeed-8k618-t:~# ls -l /dev/serial/by-id/* lrwxrwxrwx 1 root root 13 Nov 11 16:12 /dev/serial/by-id/usb-1a86_USB_Serial-if00-port0 -> ../../ttyUSB0 lrwxrwxrwx 1 root root 13 Nov 11 15:56 /dev/serial/by-id/usb-Klipper_rp2040_E6647C7403433637-if00 -> ../../ttyACM0 0 Quote
dale Posted November 26, 2025 Posted November 26, 2025 @Nick A this is updated patch for x98h that enables wifi after warm reboot. 2001-arm64-dts-allwinner-h618-add-x98h.patch 0 Quote
Nick A Posted November 26, 2025 Posted November 26, 2025 Thanks @dale I'll test it out on my box first and add it later on today. 0 Quote
dale Posted November 27, 2025 Posted November 27, 2025 @Nick A do you know how to remove key ring error? [🐳|🌱] git: Fetch from remote completed, rev-parsing... [ 'debootstrap-debian-devel' 'master' 'FETCH_HEAD' ] [🐳|🌱] Debootstrap version [ '1.0.142' for /armbian/cache/sources/debootstrap-debian-devel/debootstrap ] [🐳|🌱] Installing base system with 5 packages [ Stage 1/2 ] [🐳|🔨] I: Retrieving InRelease [🐳|🔨] I: Checking Release signature [🐳|🔨] E: Release signed by unknown key (key id F8D2585B8783D481) [🐳|🔨] The specified keyring /usr/share/keyrings/debian-archive-keyring.gpg may be incorrect or out of date. [🐳|🔨] You can find the latest Debian release key at https://ftp-master.debian.org/keys.html [🐳|💥] error! [ Debootstrap first stage failed /armbian/cache/sources/debootstrap-debian-devel/debootstrap bookworm yes ] 0 Quote
Nick A Posted November 27, 2025 Posted November 27, 2025 (edited) @dale I had the same problem last night. Should be fixed now. Clone or update the repository. You will need to install Docker. https://github.com/NickAlilovic/build/commit/025e4487f87233bfb823c7d51162d877b2a9fd6f https://github.com/armbian/build/issues/8572 Edited November 27, 2025 by Nick A 1 Quote
MeJune Posted December 1, 2025 Posted December 1, 2025 I built Debian 13 (Trixie) branch v20251014 running Transpeed-8k618t and tested it for general use. The system ran smoothly, so I started testing Bluetooth and the included IR remote control. Bluetooth doesn't detecting a signal. I've read in previous posts about this and found that Bluetooth still doesn't compleworking. Is this correct? IR remote control works properly when used image on an sd card. But when installed to emmc from image of sd card and ran it. IR remote doesn't work at all. I've tested it several times. Does anyone else have the same problem as me? 0 Quote
Malay Posted December 1, 2025 Posted December 1, 2025 27.11.2025 в 17:02, Nick A сказал: Hello. I get an error when compiling. Can you please help? I'm using the following command: ./compile.sh BOARD=vontar-h618 BRANCH=edge BUILD_DESKTOP=yes BUILD_MINIMAL=no DESKTOP_ENVIRONMENT=xfce DESKTOP_ENVIRONMENT_CONFIG_NAME=config_base KERNEL_CONFIGURE=no RELEASE=trixie git clone https://github.com/NickAlilovic/build.git --branch v20251014 Log file in attachment log-build-14db644f-d9db-4a13-ae47-79423f220cb6.log 0 Quote
Nick A Posted December 1, 2025 Posted December 1, 2025 (edited) @Malay delete patch/u-boot/u-boot-aw/99-dump-dram-controller-regs.patch. Using your compiler it causes a fatal error. The compiler I'm using it creates a warning. You don't need it anyways, it's for ram debug messages. I removed it from my repository, Edited December 1, 2025 by Nick A 1 Quote
Phi Hùng Nguyễn Posted December 2, 2025 Posted December 2, 2025 Hello, sorry for my very bad english. I have a Vonstar H618 box, I can't find firmware support for it in this list https://github.com/ophub/amlogic-s9xxx-armbian/releases?ref=armbian.io I have downloaded the original firmware from the vontar homepage https://www.vontar.cn/pages/download. I hope everyone can help me install armbian on my device. Thank you very much 0 Quote
Werner Posted December 2, 2025 Posted December 2, 2025 2 hours ago, Phi Hùng Nguyễn said: https://github.com/ophub/amlogic-s9xxx-armbian/releases?ref=armbian.io Because this is not Armbian. This is a fork which uses the name Armbian without permission. We do not support 3rd party forks. 0 Quote
Nick A Posted December 2, 2025 Posted December 2, 2025 (edited) @Phi Hùng Nguyễn that link looks nothing like Armbian. You shouldn’t install it on your tv box. Try my build it's unofficial Armbian but I provided source code. So you know what you are installing on your tv box. You can build it yourself if you want to. https://github.com/NickAlilovic/build/releases/tag/20250306 Edited December 2, 2025 by Nick A 0 Quote
