wilmardo Posted September 1, 2023 Posted September 1, 2023 Hi all, For most Nanopi devices there are packages in the registry which contain the u-boot files, for example: https://mirrors.dotsrc.org/armbian-apt/pool/main/l/linux-u-boot-nanopi-r4s-current/ Is there a reason these packages aren't present for the Nanopi R6S? The reason behind this question is that I used to extract the u-boot from these packages to experiment with other OS'es which have no official release for a certain device. Of course I can get the u-boot from the downloadable images its first couple bytes, but downloading just the package is way smaller. If there is another source to obtain the u-boot blobs I am all ears. I found that I can build them myself from the armbian/build repository with something like this but this isn't as lean as just downloading a package: ./compile.sh \ BUILD_ONLY=u-boot \ BOARD=nanopi-r6s \ BRANCH=legacy \ RELEASE=focal \ BUILD_MINIMAL=yes \ BUILD_DESKTOP=no \ KERNEL_CONFIGURE=no Hopefully someone could point me in the right direction, thanks for all the time in getting support to these ARM devices ♥️ 0 Quote
Solution Werner Posted September 1, 2023 Solution Posted September 1, 2023 There are no packages for 23.05 release at all due to major stability issues. I think there aren't older ones either because R6S has been added after 23.02 release. Anyway as you already guessed you can use the build framework to create a package bundle for your board and do whatever you want with them. Or simply wait a few days until 23.08 release which will have both images and apt repo up to date 0 Quote
wilmardo Posted September 4, 2023 Author Posted September 4, 2023 Massive thanks, this exactly answers my question :) 0 Quote
