I'm doing a build inside a Docker container (Ubuntu Xenial 16.04; started with --privileged) and I've tried several builds but all of them fail.  The .img file gets created but after copying to the SD card they always fail (unrecognized file system).  Here's the output of compile.sh:
[ o.k. ] Creating board support package [ orangepizero default ]
[ .... ] Fingerprinting
[ o.k. ] Building package [ linux-xenial-root-orangepizero ]
[ o.k. ] Starting rootfs and image building process for [ orangepizero xenial ]
[ o.k. ] Extracting xenial-ng-armhf.50a...4c9.tgz [ 0 days old ]
xenial-ng-armhf.50a...4c9.tgz: 75.6MiB [ 204MiB/s] [====================================================================================================================================================================================================================>] 100%
[ o.k. ] Applying distribution specific tweaks for [ xenial ]
sed: can't read /root/armbian-devel/output/cache/sdcard-default-orangepizero-xenial/etc/ssh/sshd_config: No such file or directory
[ o.k. ] Applying common tweaks
/root/armbian-devel/lib/distributions.sh: line 37: /root/armbian-devel/output/cache/sdcard-default-orangepizero-xenial/etc/modprobe.d/orangepizero.conf: No such file or directory
sed: can't read /root/armbian-devel/output/cache/sdcard-default-orangepizero-xenial/etc/default/console-setup: No such file or directory
chage: the shadow password file is not present
[ o.k. ] Installing kernel [ linux-image-sun8i ]
[ o.k. ] Installing u-boot [ linux-u-boot-orangepizero ]
[ o.k. ] Installing headers [ linux-headers-sun8i ]
[ o.k. ] Installing generic firmware [ armbian-firmware ]
[ o.k. ] Installing board support package [ orangepizero ]
sed: can't read /root/armbian-devel/output/cache/sdcard-default-orangepizero-xenial/etc/lirc/hardware.conf: No such file or directory
cp: cannot create regular file '/root/armbian-devel/output/cache/sdcard-default-orangepizero-xenial/etc/lirc/lircd.conf': No such file or directory
qemu: Unsupported syscall: 384
Created symlink /etc/systemd/system/getty.target.wants/serial-getty@ttyGS0.service, pointing to /lib/systemd/system/serial-getty@.service.
[ o.k. ] Installing extra applications and drivers
[ o.k. ] Installing linux firmware [ 5.24 ]
dpkg: warning: parsing file '/var/lib/dpkg/status' near line 75 package 'dpkg':
missing description
missing maintainer
missing architecture
[ o.k. ] Installing additional driver [ MT7601U ]
[ o.k. ] Checking git sources [ mt7601 old ]
[ .... ] Creating local copy
[ .... ] Fetching updates
remote: Counting objects: 264, done.
remote: Compressing objects: 100% (207/207), done.
remote: Total 264 (delta 54), reused 255 (delta 53), pack-reused 0
Receiving objects: 100% (264/264), 1.29 MiB | 681.00 KiB/s, done.
Resolving deltas: 100% (54/54), done.
From https://github.com/igorpecovnik/mt7601
* branch            old        -> FETCH_HEAD
* [new branch]      old        -> origin/old
[ .... ] Checking out
/root/armbian-devel/lib/extras/mt7601.sh: line 71: depmod: command not found
[ o.k. ] Installing additional driver [ RT8192 ]
[ o.k. ] Checking git sources [ rt8192cu master ]
remote: Counting objects: 201, done.
remote: Compressing objects: 100% (177/177), done.
remote: Total 201 (delta 43), reused 71 (delta 21), pack-reused 0
Receiving objects: 100% (201/201), 1.17 MiB | 0 bytes/s, done.
Resolving deltas: 100% (43/43), done.
From https://github.com/dz0ny/rt8192cu
* branch            master     -> FETCH_HEAD
* [new branch]      master     -> origin/master
/root/armbian-devel/lib/extras/rtl8192cu.sh: line 56: depmod: command not found
[ o.k. ] Installing [ armbian-tools-xenial_5.24_armhf.deb ]
missing description
missing maintainer
dpkg: dependency problems prevent configuration of armbian-tools-xenial:
armbian-tools-xenial depends on libc6 (>= 2.10); however:
 Package libc6 is not installed.
armbian-tools-xenial depends on libusb-1.0-0 (>= 2:1.0.8); however:
 Package libusb-1.0-0 is not installed.
armbian-tools-xenial depends on libusb-0.1-4; however:
 Package libusb-0.1-4 is not installed.
armbian-tools-xenial depends on libudev1; however:
 Package libudev1 is not installed.
dpkg: error processing package armbian-tools-xenial (--install):
dependency problems - leaving unconfigured
Errors were encountered while processing:
[ o.k. ] Installing additional application [ USB redirector ]
cp: target '/root/armbian-devel/output/cache/sdcard-default-orangepizero-xenial/usr/local/bin/' is not a directory
cp: cannot create regular file '/root/armbian-devel/output/cache/sdcard-default-orangepizero-xenial/usr/local/bin/': No such file or directory
/tmp/install.sh: line 3: apt-get: command not found
/tmp/install.sh: line 12: apt-get: command not found
/tmp/install.sh: line 13: apt-get: command not found
[ o.k. ] Calling image customization script [ customize-image.sh ]
dpkg-divert: warning: parsing file '/var/lib/dpkg/status' near line 88 package 'dpkg':
missing description
missing maintainer
missing description
missing maintainer
[ o.k. ] Preparing image file for rootfs [ orangepizero xenial ]
[ o.k. ] Current rootfs size [ 237 MiB ]
[ o.k. ] Creating blank image for rootfs [ 461 MiB ]
461MiB [ 331MiB/s] [===================================================================================================================================================================================================================================================>] 100%
[ o.k. ] Creating partitions [ root: ext4 ]
mknod: /dev/loop0: File exists
[ .... ] Creating rootfs [ ext4 ]
mknod: 1: File exists
The file /dev/loop0p1 does not exist and no size was specified.
tune2fs: No such file or directory while trying to open /dev/loop0p1
Couldn't find valid filesystem superblock.
mount: special device /dev/loop0p1 does not exist
[ o.k. ] Copying files to image [ .raw ]
       201.34M  99%  158.79MB/s    0:00:01 (xfr#16403, to-chk=0/21755)
sent 202.52M bytes  received 335.03K bytes  135.24M bytes/sec
total size is 202.62M  speedup is 1.00
[ o.k. ] Copying files to /boot partition [ .raw ]
         8.93M  99%  530.38MB/s    0:00:00 (xfr#47, to-chk=0/50)
sent 8.94M bytes  received 921 bytes  17.87M bytes/sec
total size is 8.93M  speedup is 1.00
[ o.k. ] Free space: [ SD card ]
tmpfs           1.5G  237M  1.3G  16% /root/armbian-devel/output/cache/sdcard-default-orangepizero-xenial
[ o.k. ] Writing U-boot bootloader [ /dev/loop0 ]
umount: /root/armbian-devel/output/cache/mount-default-orangepizero-xenial: not mounted
[ o.k. ] Done building [ /root/armbian-devel/output/images/Armbian_5.24_Orangepizero_Ubuntu_xenial_3.4.113.img ]
[ o.k. ] Runtime [ 8 min ]
root@f01fb9beeb7e:~/armbian-devel#
I am not sure if everything works fine under docker yet but one is for sure. Deboostrap process failed:
Cache files are more than 200M in size. This process can fail due to some network troubles even in native environment. It's an rear even, but happen. Removing roofs cache solves this.
There were problems during previous run, please delete rootfs cache (files in output/cache/rootfs).
Also Docker support is still experimental, but, thanks to your log, I found some issues and they should be fixed now.
So please try again and provide output if things still don't work.
Everything is OK now!  I did as you suggested and basically just deleted everything and started over from scratch.  I've now got a working build.
...and eth0 has an IPv6 address so building custom fixed *that* problem too!   :D
