freestart Posted August 30, 2017 Posted August 30, 2017 24 minutes ago, balbes150 said: 1. According to the log, the problem with the SD card. The system is unable to read some blocks on it, perhaps the reason for poor compatibility settings of the card and the reader. 2. You can write the image to USB and run from USB flash drive. SD card is required only to activate the multi-boot (using a toothpick or application Update&Backup). By the way, if there is a console UART, multi-upload, you can activate the manual commands from the console UART (using a USB flash drive). thanks! I will try with onther sd card; I have activated multi-boot; where I find the manual commands from the console UART? thanks!
freestart Posted August 30, 2017 Posted August 30, 2017 1 hour ago, balbes150 said: 1. According to the log, the problem with the SD card. The system is unable to read some blocks on it, perhaps the reason for poor compatibility settings of the card and the reader. 2. You can write the image to USB and run from USB flash drive. SD card is required only to activate the multi-boot (using a toothpick or application Update&Backup). By the way, if there is a console UART, multi-upload, you can activate the manual commands from the console UART (using a USB flash drive). I tried now with SD CARD Samsung 32gb class 10 but same problem I have tried now with Jessie Debian XFCE and SERVER rom image but have same problem, look my log thanks! S82_Debian_jessie_3.10.99_xfce.txt
balbes150 Posted August 30, 2017 Posted August 30, 2017 Multiboot you have already activated, so not something in the console UART should not be executed. I wrote this for those who have no opportunity to activate the multi-boot using a standard procedure (using SD card). They can do it through the console UART. Try any USB flash drive.
freestart Posted August 30, 2017 Posted August 30, 2017 7 minutes ago, balbes150 said: Multiboot you have already activated, so not something in the console UART should not be executed. I wrote this for those who have no opportunity to activate the multi-boot using a standard procedure (using SD card). They can do it through the console UART. Try any USB flash drive. thanks but the true problem is that I tried with SD CARD Samsung 32gb class 10 but same problem, stuck loading and showes black screen with no signal; have you seen my last log? thanks!
freestart Posted August 30, 2017 Posted August 30, 2017 2 hours ago, balbes150 said: Show log run from a USB flash drive. ok I will do, thanks!
freestart Posted August 30, 2017 Posted August 30, 2017 3 hours ago, balbes150 said: Show log run from a USB flash drive. here my log with USB flash drive: PS. you can see that your system doesn't boot with USB flash drive; it bypass boot from flash usb drive and loading regular system S82_log_flashusb.txt
balbes150 Posted August 31, 2017 Posted August 31, 2017 Try unplugging all USB devices except USB flash drive. Try connecting a USB flash drive in all the connectors. The results of the tests USB, show logs.
freestart Posted August 31, 2017 Posted August 31, 2017 7 hours ago, balbes150 said: Try unplugging all USB devices except USB flash drive. Try connecting a USB flash drive in all the connectors. The results of the tests USB, show logs. ok thanks I will try
freestart Posted August 31, 2017 Posted August 31, 2017 8 hours ago, balbes150 said: Try unplugging all USB devices except USB flash drive. Try connecting a USB flash drive in all the connectors. The results of the tests USB, show logs. now some it is changed, I have unplugged the usb wireless and now loading from usb but showes always black screen with no signal; this my new log: I used meson8_k200b_2G_emmc_sdio.dtb S82_log_flashusb_sdio.txt
freestart Posted August 31, 2017 Posted August 31, 2017 this is log with meson8_vega_s89.dtb: S82_log_flashusb_VegaS89.txt
freestart Posted August 31, 2017 Posted August 31, 2017 this is log with meson8_k200b_2G_emmc_sdhc.dtb: PS. I want say that my flash usb drive is a adapter microSD to usb S82_log_flashusb_sdhc.txt
freestart Posted September 1, 2017 Posted September 1, 2017 1 hour ago, balbes150 said: Try to use ordinary USB flash drive. ok thanks! I will try
freestart Posted September 4, 2017 Posted September 4, 2017 S82_flashdrive_sdhc.txt On 1/9/2017 at 11:25 AM, balbes150 said: Try to use ordinary USB flash drive. Hi, I have tried with flashdrive but I have same error, same problems! balbes150 please help me! I read here someone with the same problem "aml_sdhc_print_err" solved by disabling UHS https://archlinuxarm.org/forum/viewtopic.php?f=60&t=8283 how can I to do it? thanks!
debianxfce Posted September 9, 2017 Posted September 9, 2017 2 hours ago, freestart said: Where are you balbes150? please help me! You are using really old kernel. Try with the mainline kernel, see: http://linux-meson.com/doku.php
balbes150 Posted September 9, 2017 Posted September 9, 2017 On 04.09.2017 at 9:28 PM, freestart said: I read here someone with the same problem "aml_sdhc_print_err" solved by disabling UHS Try using this version of the script. It adds option to disable UHS. But I doubt it will help. https://yadi.sk/d/6MNTGkz13MjcRL
freestart Posted September 9, 2017 Posted September 9, 2017 12 hours ago, balbes150 said: Try using this version of the script. It adds option to disable UHS. But I doubt it will help. https://yadi.sk/d/6MNTGkz13MjcRL ok thanks I will try and make you know
freestart Posted September 9, 2017 Posted September 9, 2017 18 hours ago, debianxfce said: You are using really old kernel. Try with the mainline kernel, see: http://linux-meson.com/doku.php thanks! how can I to use the kernel with Armbian?
freestart Posted September 9, 2017 Posted September 9, 2017 13 hours ago, balbes150 said: Try using this version of the script. It adds option to disable UHS. But I doubt it will help. https://yadi.sk/d/6MNTGkz13MjcRL I have tried but nothing, same problem
freestart Posted September 19, 2017 Posted September 19, 2017 I have bought a microSD of Scandisk model Ultra 80Mb/s, I will try with it when arrive and make you know
debianxfce Posted September 20, 2017 Posted September 20, 2017 On 09/09/2017 at 11:06 PM, freestart said: thanks! how can I to use the kernel with Armbian? You create your own image. Take look of the armbian documentation and sources: https://docs.armbian.com/Developer-Guide_Build-Preparation/
freestart Posted September 20, 2017 Posted September 20, 2017 11 hours ago, debianxfce said: You create your own image. Take look of the armbian documentation and sources: https://docs.armbian.com/Developer-Guide_Build-Preparation/ thanks for information
freestart Posted September 26, 2017 Posted September 26, 2017 On 24/9/2017 at 7:28 PM, balbes150 said: Update image kernel 3.10.99 20170924 This is my new log with microSD ScanDisk Ultra 80mb/s (very fast) but same error; I will try with your new image with new kernel and make you know! S82_log.txt
freestart Posted September 26, 2017 Posted September 26, 2017 same errors with new kernel too S82_new_kernel_log.txt
balbes150 Posted October 4, 2017 Posted October 4, 2017 On 26.09.2017 at 11:50 AM, freestart said: same errors with new kernel too Now you have the UART console. Try to run from SD card version-4.x (try to use the dtb M8s and MXIII Plus)
freestart Posted October 5, 2017 Posted October 5, 2017 23 hours ago, balbes150 said: Now you have the UART console. Try to run from SD card version-4.x (try to use the dtb M8s and MXIII Plus) thanks I will try and post log
Bobek Posted October 13, 2017 Posted October 13, 2017 hello, I need support - I have S812 and I tried to follow these steps, where problem occurs in step n.8 - instead of "boot from external media" after second restart, it booted from original ROM immediately. There is no black screen for 7-10minutes, it just boot as usual. I also tried the step n.9 (swith dtb.img), but problem remains the same. I followed all the steps from this guide. Can you suggest possible mistakes, which I could made please ? I would take any suggestion. 1. Download the desired image 2. Unpack 3. Record an image on the medium 4. to run Android 5. open the app "Update&Backup" 6. Select local update and an archive on removable media (aml_update.zip) 7. Run update 8. System twice to reboot and start running the system from external media. 9. If after 7-10 minutes on the monitor not to receive any messages on system startup. Turn off TV box and add in manual in the first partition (FAT) the file "dtb.img". On the media there is a directory dtb from where you can take the files and copy them to the root of the renaming of "dtb.img". Need to pick up the option for the file system will run. Pay attention, after you add\change the dtb file, you need to try to run the system and waiting to run 7-10 minutes. If not happened, repeat with a different dtb file.
