Armbian 23.8 Bookworm eth0 missing
Fazik83
The interface name is end0
Use udev rules to rename to eth0 if you want.
Link to comment
Share on other sites
But I have not internet access via eth (end0)
Ifconfig
lo: flags=73<UP,LOOPBACK,RUNNING>  mtu 65536
        inet 127.0.0.1  netmask 255.0.0.0
        inet6 ::1  prefixlen 128  scopeid 0x10<host>
        loop  txqueuelen 1000  (Local Loopback)
        RX packets 32  bytes 2592 (2.5 KiB)
        RX errors 0  dropped 0  overruns 0  frame 0
        TX packets 32  bytes 2592 (2.5 KiB)
        TX errors 0  dropped 0 overruns 0  carrier 0  collisions 0
wlan0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 1500
        inet 192.168.2.102  netmask 255.255.255.0  broadcast 192.168.2.255
        inet6 fe80::3ad5:4df8:1ff:4c0e  prefixlen 64  scopeid 0x20<link>
        ether b0:02:47:b9:f0:e9  txqueuelen 1000  (Ethernet)
        RX packets 1422  bytes 166846 (162.9 KiB)
        TX packets 1216  bytes 525875 (513.5 KiB)
Link to comment
33 minutes ago, Fazik83 said:
 2023	[   14.365868] dwmac-sun8i 5020000.ethernet end0: __stmmac_open: Cannot attach to PHY (error: -19)
I see. Something is fishy. No instant solution. You can try to revert to an older kernel using armbian-config for now.
Btw. you are sure you have the OPi3 without LTS? Because the LTS variants differs hardware-wise and that is why there are separate images for it.
Link to comment
The link you followed is just fine.
As stated you could try to use an older kernel (like 5.15.y) or try edge branch which follows 6.x.y, not sure if 6.5 already but 6.4.y I think
And check if this makes a difference. It is easier to investigate if known that it works properly on other firmware.
Link to comment
@Fazik83 Does this happen only on warm reboot or on cold boot(removing power and plugging back in) as well?
Also could you please try the image from the below link and check if it works better. Make sure to check after reboot as well.
https://drive.google.com/drive/folders/1mD8q60uruA_iWpN1Njy0H9FVw7lPZReY?usp=sharing
Link to comment
hello, I also had this problem which I just solved by reinstalling the version:
Armbian_23.02.2_Orangepi3_bullseye_current_5.15.93.img.xz
Once you have rebooted on your OPI3, followed the startup script and done the first
# apt update
please run the armbian-config script and freeze the firmware upgrade.
If in doubt you can use the
# apt-mark hold [PACKAGENAME]
command.
Link to comment
@Fazik83I have made few changes and have uploaded new Images here - https://drive.google.com/drive/folders/1Pq7iYzIBPhPPACGxDqan0obbl8wNVY8t?usp=sharing
Could you please test the same and let me know if it works?
PS: The image has console set to serial, so there might be no login prompt on hdmi. If you need to use hdmi, set console=both in boot/armbianEnv.txt file.
Link to comment
29.09.2023 в 21:59, Gunjan Gupta сказал:
Hello! I tested it, but it doesnt work on my orange pi 3 (not LTS). I tried apt update and upgrade, but dont luck.
I can give diagnostic information if you tell me the commands.
Link to comment
Its ok. I am already aware that the image was broken. It was already tried by someone else from the community. I will try to fix it later, dealing with some personal stuff right now.
Link to comment
Armbian 23.11.1 (Linux 6.1.63-current-sunxi64) - A similar problem with the eth0 interface not working on this board:
[    2.865410] dwmac-sun8i 5020000.ethernet: IRQ eth_wake_irq not found
[    2.865438] dwmac-sun8i 5020000.ethernet: IRQ eth_lpi not found
[    2.865881] dwmac-sun8i 5020000.ethernet: PTP uses main clock
[    2.865914] dwmac-sun8i 5020000.ethernet: Current syscon value is not the default 58000 (expect 50000)
[    2.866325] dwmac-sun8i 5020000.ethernet: No HW DMA feature register supported
[    2.866336] dwmac-sun8i 5020000.ethernet: RX Checksum Offload Engine supported
[    2.866344] dwmac-sun8i 5020000.ethernet: COE Type 2
[    2.866353] dwmac-sun8i 5020000.ethernet: TX Checksum insertion supported
[    2.866361] dwmac-sun8i 5020000.ethernet: Normal descriptors
[    2.866368] dwmac-sun8i 5020000.ethernet: Chain mode enabled
[    2.968350] dwmac-sun8i 5020000.ethernet: EMAC reset timeout
[    2.968383] dwmac-sun8i 5020000.ethernet eth0: stmmac_dvr_remove: removing driver
[    3.051836] dwmac-sun8i: probe of 5020000.ethernet failed with error -110
Is there a solution to this problem? thx
Edited by Aleksey Gavrikov
Link to comment
@Aleksey GavrikovWe were not able to fix this before we made 23.11 release. We have now fixed the issue and the PR is merged. Fix will be available in beta apt repository first (beta.armbian.com) and will be included in next release. As the fix is in bootloader, once new linux-u-boot-* package is provided via apt, Bootloader has to be reflashed on the system (See https://docs.armbian.com/User-Guide_Getting-Started/#how-to-update-u-boot). Ethernet should start working after reboot.
Link to comment
I do ran into the same problem today with my rock-3a running
    Armbian 24.2.1 Bookworm with Linux 6.6.16-current-rockchip64
It occurred after re-boot of the system because of the banner the message "Please reboot system do to kernel-updated" appeared. After that ethernet (was named "end0") did not come up anymore. When activating using "nmtui" the message comes:
"Activation failed. Device could not be prepared for activation ..." (freely translated from German language).
journalctl -x gives the following:
(armbian-monitor -u already performed)
Mar 14 10:51:01 cloud kernel: rk_gmac-dwmac fe010000.ethernet end0: __stmmac_open: Cannot attach to PHY (error: -19)
Mar 14 10:51:01 cloud NetworkManager[745]: <info>  [1710409861.7565] device (end0): state change: config -> failed (reason 'config-failed', sys-iface-state: 'managed')
Mar 14 10:51:01 cloud NetworkManager[745]: <warn>  [1710409861.7579] device (end0): Activation: failed for connection 'Ethernet'
Mar 14 10:51:01 cloud NetworkManager[745]: <info>  [1710409861.7588] device (end0): state change: failed -> disconnected (reason 'none', sys-iface-state: 'managed')
After all I updated the bootloader (using armbian-config) and it luckily resolved the problem ...
Thx for reading this. Hope it helps others ...
Edited by Hannes
Problem solved
Link to comment
I had the same problem with Eth0 missing, I had to connect via TTL-UART-dongle to assign the interface to new system. And it was end0 also. After that i got problems with high Soft-IRQ loads on my CPU(Nanopi M4V2 with OMV+docker+transmission with 1 SATA disk. See images attached, before and after upgrading). There is definitely something wrong with this release.
Guys who still didn't upgrade to Bookworm, could you pls send me results of "ethtool -k end0" command to compare TCP segmentation offload settings on NanoPi M4V2 ?
See https://balodeamit.blogspot.com/2013/10/tcp-segmentation-offloading.html for additional info
Edited by StormMaster
Link to comment
I've installed Armbian minimal version based on Debian Bookworm (image Armbian_community_24.8.0-trunk.495_Bananapi_bookworm_current_6.6.36_minimal.img.xz) on my Banana Pi M1.
Installation went well but I can't set up static ip address in armbian config. Anytime I run armbian-config and try to set static address it hangs for a while and exits with no error code. So, I set up static ip address mapping on my router.
After installation I runned apt update and apt upgrade.
I've noticed that there is no eth0 interface but end0.
Dmesg says that interface was renamed.
root@bananapi:/usr/local/bin# dmesg | grep end0
[    3.327770] sun7i-dwmac 1c50000.ethernet end0: renamed from eth0
[   10.106591] sun7i-dwmac 1c50000.ethernet end0: Register MEM_TYPE_PAGE_POOL RxQ-0
[   10.126691] sun7i-dwmac 1c50000.ethernet end0: PHY [stmmac-0:01] driver [RTL8211E Gigabit Ethernet] (irq=POLL)
[   10.126766] sun7i-dwmac 1c50000.ethernet end0: No Safety Features support found
[   10.126781] sun7i-dwmac 1c50000.ethernet end0: RX IPC Checksum Offload disabled
[   10.126799] sun7i-dwmac 1c50000.ethernet end0: No MAC Management Counters available
[   10.126813] sun7i-dwmac 1c50000.ethernet end0: PTP not supported by HW
[   10.127714] sun7i-dwmac 1c50000.ethernet end0: configuring for phy/rgmii-id link mode
[   14.547226] sun7i-dwmac 1c50000.ethernet end0: Link is Up - 1Gbps/Full - flow control rx/tx
I'm not sure if interface name causes problem with setting up static address in armbian-config.
Now I'm trying to rename end0 interface to eth0.
Link to comment
