vysec Posted September 21, 2023 Posted September 21, 2023 Hi there, I've been trying to enable g_ether and USB OTG on my Orange PI 5+. I've tried things like editing /boot/orangepiEnv.txt and adding module-load dwc2,g_ether. However, I don't get any usb0 interface pop up which indicates to me that the USB/OTG mode is not set to peripheral on the settings. I'm not sure how to go about it? Would anyone be able to advise? I want to use the power port for also Ethernet. 0 Quote
Werner Posted September 22, 2023 Posted September 22, 2023 10 hours ago, vysec said: /boot/orangepiEnv.txt looks like you are not using Armbian. Therefore support cannot be provided. 0 Quote
vysec Posted September 22, 2023 Author Posted September 22, 2023 That's fine, I can also use Armbian. 0 Quote
koshi Posted July 17, 2024 Posted July 17, 2024 Is that even supported on the hardware at all? I am on armbian (23.5.5 Orangepi5 plus jammy legacy 5.10.160 because I need HDMI-in), but can find no overlay for that. Gadget kernel modules seem to be also missing and I cannot make out a dedicated OTG-port in the official documentation for the hardware itself... 0 Quote
Werner Posted July 17, 2024 Posted July 17, 2024 legacy is considered deprecated. Try vendor (6.1.y) kernel. 0 Quote
