DenisS Posted September 22, 2023 Posted September 22, 2023 I have board which has 2 slaves on the SPI bus, requiring ce0 and ce1. My system: Armbian 23.8.1 Bookworm with Linux 6.1.47-current-sunxi I applied overlays: spi-add-cs1 and spi-spidev, there's an spi in the system. As soon as I apply spi-double-spidev-bus.dts, the spi disappears. Скрытый текст /dts-v1/; /plugin/; / { compatible = "allwinner,sun4i-a10", "allwinner,sun7i-a20", "allwinner,sun8i-h3", "allwinner,sun50i-a64", "allwinner,sun50i-h5"; fragment@0 { target = <&spi0>; __overlay__ { #address-cells = <1>; #size-cells = <0>; status = "okay"; spidev@0 { reg = <0>; /* Chip Select 0 */ compatible = "spidev"; spi-max-frequency = <1000000>; status = "okay"; }; }; }; fragment@1 { target = <&spi1>; __overlay__ { #address-cells = <1>; #size-cells = <0>; status = "okay"; spidev@0 { reg = <0>; /* Chip Select 0 */ compatible = "spidev"; spi-max-frequency = <1000000>; status = "okay"; }; }; }; }; How to make two cs? As soon as I apply spi-double-spidev-bus.dts, the spi disappears. Also, as I assume there is a problem with CS1, I reassign it with my overlay: Скрытый текст /dts-v1/; /plugin/; / { compatible = "allwinner,sun8i-h3"; fragment@0 { target = <&pio>; __overlay__ { spi0_cs1: spi0_cs1 { pins = "PC3"; function = "gpio_out"; output-high; }; }; }; fragment@1 { target = <&spi0>; __overlay__ { pinctrl-names = "default", "default"; pinctrl-1 = <&spi0_cs1>; cs-gpios = <&pio 2 3 0>; /* PC3 */ }; }; }; CS is reassigned in the system, but the spi device polls once. When polling again, errors occur. When I manually set the cs there are no re-polling errors. I use "spi-device" - accessing the SPI serial bus using Node.js on Linux boards https://github.com/fivdi/spi-device On another board, the author's "spi-device" SPI polling works without problems https://github.com/fivdi/spi-device/issues/27 Please help to make sense of these two issues. 0 Quote
Werner Posted September 22, 2023 Posted September 22, 2023 Providing logs with armbianmonitor -u helps with troubleshooting and significantly raises chances that issue gets addressed. 0 Quote
DenisS Posted September 22, 2023 Author Posted September 22, 2023 https://paste.armbian.com/wosilicuda 0 Quote
DenisS Posted September 26, 2023 Author Posted September 26, 2023 (edited) I installed my overlay: Скрытый текст /dts-v1/; /plugin/; / { compatible = "allwinner,sun8i-h3"; fragment@2 { target = <&pio>; __overlay__ { spi0_pi_pins: spi0-pi-pins { pins = "PC0", "PC1", "PC2"; function = "spi0"; }; spi0_cs0_pi_pin: spi0-cs0-pi-pin { pins = "PC3"; function = "spi0"; }; spi0_cs1_pi_pin: spi0-cs1-pi-pin { pins = "PG8"; function = "spi0"; }; }; }; fragment@1 { target = <&spi0>; __overlay__ { #address-cells = <1>; #size-cells = <0>; status = "okay"; pinctrl-names = "default"; pinctrl-0 = <&spi0_pi_pins>; spi-max-frequency = <1000000>; num-chipselects = <2>; spidev@0 { reg = <0>; /* Chip Select 0 */ compatible = "armbian,spi-dev"; pinctrl-names = "default"; pinctrl-0 = <&spi0_cs0_pi_pin>; status = "okay"; }; spidev@1 { reg = <1>; /* Chip Select 1 */ compatible = "armbian,spi-dev"; pinctrl-names = "default"; pinctrl-0 = <&spi0_cs1_pi_pin>; status = "okay"; }; }; }; }; two spi's appearing: den@nanopineo:~$ ls /dev/ | grep spi spidev0.0 spidev0.1 den@nanopineo:~$ sudo cat /sys/kernel/debug/gpio gpiochip0: GPIOs 0-223, parent: platform/1c20800.pinctrl, 1c20800.pinctrl: gpio-67 ( |spi0 CS0 ) out hi ACTIVE LOW gpio-166 ( |cd ) in hi ACTIVE LOW gpio-200 ( |sysfs ) out hi gpio-203 ( |sysfs ) in lo gpio-204 ( |usb0_id_det ) in hi IRQ gpiochip1: GPIOs 352-383, parent: platform/1f02c00.pinctrl, 1f02c00.pinctrl: gpio-355 ( |k1 ) in hi IRQ ACTIVE LOW gpio-358 ( |vdd-cpux ) out lo den@nanopineo:~$ dmesg | grep spi [ 2.600676] spidev@0 enforce active low on chipselect handle [ 4.022764] sun8i-h3-pinctrl 1c20800.pinctrl: unsupported function spi0 on pin PG8 [ 4.022867] spidev spi0.1: there is not valid maps for state default https://paste.armbian.com/yurepiyuve spi 0.0 doesn't work! How do I get it to work ? And set PG8 as cs1? Edited September 26, 2023 by DenisS 0 Quote
Gunjan Gupta Posted September 26, 2023 Posted September 26, 2023 1 hour ago, DenisS said: spi0_cs1_pi_pin: spi0-cs1-pi-pin { pins = "PG8"; function = "spi0"; }; Based on the schematics of the board, PG8 only support uart1 or gpio function. So you can't set function = spi0 for the same. Now this is a shot in the dark, but may by you can experiment with cs-gpios property. 0 Quote
going Posted September 26, 2023 Posted September 26, 2023 2 часа назад, DenisS сказал: spi0_cs0_pi_pin: spi0-cs0-pi-pin { pins = "PC3"; function = "spi0"; }; spi0_cs1_pi_pin: spi0-cs1-pi-pin { pins = "PG8"; function = "spi0"; function = "gpio_out"; 1 Quote
