Mirrors are unreliable, causing frequent failures of installs / upgrades
dirkhh
Go to solution Solved by Igor,
I started seeing this happen "now and then" a couple of months ago, but over the last month it has gone to "multiple times a day". It's not always the same mirror. Frequently it's the airframes.io mirrors, this morning it was lv.auroradev.org
The pattern is usually like this:
Err:1 https://armbian.lv.auroradev.org/apt bookworm/main arm64 linux-libc-dev arm64 23.02.2
  404  Not Found [IP: 23.186.113.5 443]
E: Failed to fetch https://armbian.lv.auroradev.org/apt/pool/main/l/linux-6.1.11-sunxi64/linux-libc-dev_23.02.2_arm64.deb  404  Not Found [IP: 23.186.113.5 443]
Is there a place to report these issues to get those mirrors fixed?
  • Solution
We don't have a dedicated operator of mirrors but it seems we should appoint someone as maintaining is getting complicated despite of all automation which should prevent this to happen. This is a corner case, as it shows that mirror is synced ... but not all files are there.
I have removed this mirror as its probably running out of space. Airframes maintainer responded yesterday, so I assume its back in sync.
Thanks for the quick response, @Igor I know that others are running into this - I am wondering if there is a way to get engaged and help.
But one particular question that I have is about the mirror redirector. Because when I get a failure response and retry, it would be amazing if the redirector could recognize that I just asked for that same file and that maybe it shouldn't direct me to that same mirror again? A simple redis cache with a short timeout for originating IP plus requested URL and if you see it a second time, given them a different answer? Just a thought...
You could study the code and improve it. Also we haven't merge PR with lots of improvements as nobody had time to test it:
https://github.com/armbian/armbian-router
Mirrors are stored in database and here we are pulling them out:
https://github.com/armbian/os/blob/main/.github/workflows/redirector-update.yml
From there a config is generated that is passed to armbian-router AKA re-director.
Perhaps new version knows that. You will need to try the one from PR and open a ticket there.
Hi @Igor -- is it possible that the broken mirror is back? I just got this in a couple of builds:
2023-10-01T18:48:04.0451876Z Ign:2 http://armbian.lv.auroradev.org/apt bookworm/main arm64 armbian-firmware all 23.8.3
2023-10-01T18:48:04.0461377Z Err:2 http://apt.armbian.com bookworm/main arm64 armbian-firmware all 23.8.3
2023-10-01T18:48:04.0462970Z   404  Not Found [IP: 23.186.113.5 80]
2023-10-01T18:48:04.0677050Z Get:1 http://mirrors.jevincanders.net/armbian/apt bookworm/main arm64 base-files arm64 23.8.3-bookworm [53.0 kB]
2023-10-01T18:48:04.2046316Z Fetched 53.0 kB in 1s (76.1 kB/s)
2023-10-01T18:48:04.2050986Z E: Failed to fetch http://apt.armbian.com/pool/main/a/armbian-firmware/armbian-firmware_23.8.3_all__1-SA01f9-B981c-R448a.deb  404  Not Found [IP: 23.186.113.5 80]
2023-10-01T18:48:04.2051716Z E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
