Hi everybody,
First I would like to thank you Igor's work.... Excellent!!!
I discovered this week your new armbian site. I decided to try wheezy for cubieboard1 but can't startup. Jessie started but never ends LSB raise network interface......
It's my fault?
Excuse me i'm not english
Regards
No, Jessie is broken in last build ... I need to fix it. Sorry.
Use anything else.
Thanks ;)
What? It should.
Cubieboard 1 / Vanilla kernel 4.2.x works.
I don't have this board here (getting it soon) but I tested Wheezy on Cubietruck, Banana, Lime. It works.
Where does it stops?
Hi Igor,
Sorry about that, but doesn't start. It alway started my nandb debian previous image. No the sd image with your wheezy 4.2.2
Also i've tried Wheezy 4.1.6 and this one started but keyboard it's no operative from console. I connected via ssh and works but no directly from console.
I could send you any log or file, if you would like to take a look
Thank you and regards
Hi again,
Good news....
Using Wheezy 4.1.6, I've updated and upgraded. Once upgraded Linux cubieboard 4.2.2-sunxi is working
Up to now everything it's working and fine.
Thank you
Yes, this is proper procedure but there is no download yet for this fix.
You need to rebuild from sources or wait for next version (4.5). I need few days.
