Eddiie Posted October 3, 2023 Share Posted October 3, 2023 (edited) Hello, I installed 2022-09-27-Armbian_22.11.0-trunk_jammy_edge_lubuntu_5.19.6-qt5-swap-bpi-p2z-10804MB.img on my Banana Pi Zero and it works great! I run sudo apt update , sudo apt upgrade ... Hours later, time to reboot. The board reboots and crashes.. See pic. Hmmm can't attach pics for some reason. First error I see on the screen says Failed to load '/boot/dtb/sun8i-h2-plus-bananapi-p2-zero.dtb libfdt fdt_check_header(): FDT_ERR_BADMAGIC No FDT memory address configured. Please configure the FDT address via "fdt addr <address>" command. Aborting! Then a bunch of other errors ERROR: Did not find a cmdline Flattened Device Tree Could not find a valid device tree Script failures.. No ethernet found.. Eventually => Also had some fun fixing the github public key before I was able to do apt update. Edited October 3, 2023 by Eddiie 0 Quote Link to comment Share on other sites More sharing options...
Igor Posted October 3, 2023 Share Posted October 3, 2023 3 hours ago, Eddiie said: The board reboots and crashes https://docs.armbian.com/User-Guide_Getting-Started/#how-to-check-download-authenticity 0 Quote Link to comment Share on other sites More sharing options...
Gunjan Gupta Posted October 4, 2023 Share Posted October 4, 2023 Could you please confirm your device? I see the error message is for bananapi p2 zero, but you have reported it with bananapi m2 zero tag. I don't see any patches or config file for p2 zero. Could you please share the link for the image you installed? 0 Quote Link to comment Share on other sites More sharing options...
Gunjan Gupta Posted October 4, 2023 Share Posted October 4, 2023 @Eddiie Found the image you mentioned on https://wiki.banana-pi.org/Banana_Pi_BPI-P2_Zero page. Seems to me a third party created image. I don't see the board config for p2 zero in Armbian/build repository, so I am not sure if we ever supported this board. Not sure why the third party image contained Armbian repository urls as that would for sure break the board on upgrade. 0 Quote Link to comment Share on other sites More sharing options...
Eddiie Posted October 8, 2023 Author Share Posted October 8, 2023 Oh, wow. Thank you for that. I will grab an Armbian image. 0 Quote Link to comment Share on other sites More sharing options...
sagard Posted December 31, 2023 Share Posted December 31, 2023 I am having the exact same issues. Did you fix this by using the M2 zero armbian image? Or some other way? 0 Quote Link to comment Share on other sites More sharing options...
sagard Posted December 31, 2023 Share Posted December 31, 2023 Answering my question for others... - install latest M2 zero image from armbian website - it will come with ethernet disabled by default as the m2 zero doesn't have an ethernet port. To enable - make this file somewhere on your computer and follow the instructions to enable: - https://lisy.dev/swrep/BananaPI/m2-zero-eth0.dts 0 Quote Link to comment Share on other sites More sharing options...
Gunjan Gupta Posted December 31, 2023 Share Posted December 31, 2023 @sagard , you can combine dts compilation, copying and then editing of armbianEnv.txt into single command - armbian-add-overlay <dts_file_name> 0 Quote Link to comment Share on other sites More sharing options...
