InfernalWolf666 Posted October 7, 2023 Posted October 7, 2023 Hello. The official adapter does not work for my orange pi 5 plus. https://aliexpress.ru/item/1005005956334270.html?spm=a2g2w.orderdetail.0.0.4e224aa6r3APff&sku_id=12000035019805399 The problem is this. Wi-Fi works, you turn on bluetooth, bluetooth doesn’t work initially. After turning on bluetooth, Wi-Fi does not work and bluetooth does not work either. Realtek RTL8852BE-CG BE CPU work in all officials builds. Help me please 0 Quote
Werner Posted October 7, 2023 Posted October 7, 2023 Providing logs with armbianmonitor -u helps with troubleshooting and significantly raises chances that issue gets addressed. 0 Quote
InfernalWolf666 Posted October 7, 2023 Author Posted October 7, 2023 (edited) Orange pi OS (arch) I found these files in the folder. /boot/dtbs/rockchip/overlay I can't be sure. But please look at these files. I think these are the drivers Now I will install Armibian and take your advice rk3588-wifi-pcie.dtbo rk3588-wifi-ap6275p.dtbo Edited October 7, 2023 by InfernalWolf666 0 Quote
schwar3kat Posted October 7, 2023 Posted October 7, 2023 @InfernalWolf666 As you have provided no logs, I can't see what Armbian image you have used. Your board is very new and it is likely that things are still missing from the upstream Kernel and the legacy build . In such cases the legacy build is often more complete than the current build. Those are device tree overlay files that you have found, however they are from another source and another board and are not relevant. Hardware devices that are not included by default on the board are usually not included in the default device tree. They would normally be added as device tree overlays. They are not drivers, they just map the hardware addresses so that the devices can be addressed by software. Drivers are generally included in the Kernel if they exist in the mainline Kernel or have been added as patches into the Armbian build. Device tree overlays can be applied through armbian-config, System, Hardware. (possibly not relevant but included for your understanding) Screenshots of armbian-config from a legacy build: (From a console type armbian-config) There are a number of overlays available for Opi5+ but I don't see anything related to your issue use the arrow keys to scroll. I suspect that your device may not currently be supported by the build that you are using. EDIT: According to the download page, you need to enable orangepi-5-ap6275p overlay from Hardware menu of armbian-config and reboot. 0 Quote
InfernalWolf666 Posted October 20, 2023 Author Posted October 20, 2023 Sorry that I was gone for a long time. There, Ubuntu release 1.28 was released on Github. There Wi-Fi works correctly, but bluetooth still does not work. So for now I’ll stick to the orange OS Archlinux 0 Quote
InfernalWolf666 Posted November 8, 2023 Author Posted November 8, 2023 Github ubuntu Jshoua Riek ! Realse 1.29 - repair work bluetooth . Team Armbian ay ?! Everebody home ?! 0 Quote
Werner Posted November 8, 2023 Posted November 8, 2023 https://docs.armbian.com/Process_Contribute/ 0 Quote
Spooky Posted November 18, 2023 Posted November 18, 2023 This WiFi + Bluetooth card should now fully work on the legacy kernel. Bluetooth was fixed by the below commit. Users may need to install armbian-firmware-full to get the required firmware. https://github.com/armbian/linux-rockchip/commit/0d05f8c90fbdcf35e63fa58c0d0400a19bc3a33f 2 Quote
BOFFBOY Posted January 11, 2024 Posted January 11, 2024 (edited) hi, is there a simple guide on how to fix this ? thanks Edited January 11, 2024 by BOFFBOY 0 Quote
Werner Posted January 12, 2024 Posted January 12, 2024 On 1/11/2024 at 4:58 AM, BOFFBOY said: hi, is there a simple guide on how to fix this ? thanks As @Spooky stated this should work OOB. Install armbian-firmware-full via apt. Both Armbian and their own OS' kernel base are very close. 0 Quote
