Creating image - httpredir.debian.org name resolution errors
I recently started getting these errors constantly... not sure what's going on. I can ping the address just fine, and even if I modify the lib config sources file to change it to ftp.us.debian.org, I still seem to run into the same errors.
Any suggestions on what might be causing the problem?
[ error ] Installation failed
Failed to fetch http://httpredir.debian.org/debian/pool/main/libn/libnl/libnl1_1.1-7+b1_armhf.deb Could not resolve 'httpredir.debian.org'​
Thanks.
Anyone?
I am still having this problem even after cleaning my folders and trying multiple times. I can ping and browse to the destination folder just fine (the httpredir address), but the installation always seems to fail with the same error.
I tried changing the defaults to the ones generated by the generator, but no luck.
I also tried deleting my VM and creating a new one (I generate my images in a VM) and am still running into the same issue.
I am not sure if it's something related to my DNS servers.. I'll try new DNS servers and see if that makes a difference.
So I don't think this is due to DNS.... I noticed that the error is occurring on the same 2 files every time i.e.:
[ o.k. ] Fixing release custom applications. [ wheezy ]
Failed to fetch http://httpredir.debian.org/debian/pool/main/libn/libnl/libnl-dev_1.1-7+b1_armhf.deb Could not resolve 'httpredir.debian.org'
E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?​
It also happens when I changed the apt sources list....
Failed to fetch http://mirrors.ocf.berkeley.edu/debian/pool/main/libn/libnl/libnl1_1.1-7+b1_armhf.deb Could not resolve 'mirrors.ocf.berkeley.edu'
Failed to fetch http://mirrors.ocf.berkeley.edu/debian/pool/main/libn/libnl/libnl-dev_1.1-7+b1_armhf.deb Could not resolve 'mirrors.ocf.berkeley.edu'
Any idea why it's failing at this point, and is there a way I could get around this?
Thanks.
Same problem here,  BananPi 5.31 jessie 4.11.6-sunxi
Problem disappears if :
- network if is set to DHCP
- network if is static and additional google-DNS-servers are enabled.
Very strange...
