peter12 Posted December 20, 2016 Posted December 20, 2016 Hello, my syntek is on Orangepi Lite successfully identified as 05e1:0408 Syntek Semiconductor Co., Ltd STK1160 Video Capture Device but I don't see it in /dev (usually it displays as /dev/video0 on Raspberry) Any idea how can I play video from Syntek in vlc? Many thanks
Igor Posted December 20, 2016 Posted December 20, 2016 It's not part of the kernel but you can add it: http://learn.linksprite.com/pcduino/linux-applications/install-easycap-stk1160-usb-video-capture-dongle-on-pcduino3/
zador.blood.stained Posted December 20, 2016 Posted December 20, 2016 USB VID/PID suggest that this device is compatible with the Easycap driver, so I enabled it in the kernel config: https://github.com/igorpecovnik/lib/commit/c336b6e7034933584f269f874c49ccdebfd4573e 1
peter12 Posted December 20, 2016 Author Posted December 20, 2016 Hi friends, thanks for very fast response! It's not part of the kernel but you can add it: http://learn.linksprite.com/pcduino/linux-applications/install-easycap-stk1160-usb-video-capture-dongle-on-pcduino3/ I saw it is for pcduino. Does the same steps work with orangepi lite please? USB VID/PID suggest that this device is compatible with the Easycap driver, so I enabled it in the kernel config: https://github.com/igorpecovnik/lib/commit/c336b6e7034933584f269f874c49ccdebfd4573e Great. But what should I do to enable it in my orangepi lite please? P.S. I am newbie with my orangepi lite so please excuse my unprofessional questions.
Igor Posted December 20, 2016 Posted December 20, 2016 Go to download page and check how to switch to nighty / auto built kernel. It will work in the morning after apt-get update / upgrade.
zador.blood.stained Posted December 20, 2016 Posted December 20, 2016 ... or just install this kernel: https://dl.dropboxusercontent.com/u/5385968/linux-image-sun8i_5.24_armhf.deb Alternatively you may wait for the new release (in ~1-1.5 months)
peter12 Posted December 21, 2016 Author Posted December 21, 2016 ... or just install this kernel: https://dl.dropboxusercontent.com/u/5385968/linux-image-sun8i_5.24_armhf.deb I tried to install kernel like this: sudo dpkg -i linux-image-sun8i_5.24_armhf.deb it produced these warnings but installed successfully: dpkg: warning: unable to delete old directory '/lib/modules/3.4.112-sun8i/kernel/net/wireless': Directory not empty dpkg: warning: unable to delete old directory '/lib/modules/3.4.112-sun8i/kernel/net': Directory not empty dpkg: warning: unable to delete old directory '/lib/modules/3.4.112-sun8i/kernel': Directory not empty Then I run sudo shutdown -r now. Now my orangepi hdmi output is black, pi didn't boot, no LED is shining on orangepi. Any idea what went wrong please?
peter12 Posted December 21, 2016 Author Posted December 21, 2016 Hi there, I went through Igor's release and it is now identifing my usb syntek as /dev/video0. Thank you for help! 1
