Ake Posted December 21, 2016 Posted December 21, 2016 Hi. I have Cubieboard 1 with Armbian Jessie installed on NAND. I've tried to disable output during boot as described here: https://docs.armbian.com/User-Guide_Fine-Tuning/#how-to-toggle-boot-output, but there are no existing boot.cmd and boot.scr in boot partition. I've found out that uEnv.txt have same purpose but it seems that editing this file doesn't affects arguments, /proc/cmdline remains the same.
Igor Posted December 21, 2016 Posted December 21, 2016 NAND installation uses old stock uboot which require special treat. Check/adjust "extraargs" within your uEnv.txt file.
Ake Posted December 21, 2016 Author Posted December 21, 2016 /boot/uEnv.txt: console=tty1 root=/dev/nand2 rootwait extraargs="console=tty1 hdmi.audio=EDID:0 disp.screen0_output_mode=EDID:0 consoleblank=0 loglevel=1 sunxi_ve_mem_reserve=128" dmesg: Kernel command line: console=ttyS0,115200 root=/dev/nand2 rootwait loglevel=8 panic=10 console=tty1 hdmi.audio=EDID:0 disp.screen0_output_mode=EDID:0 consoleblank=0 loglevel=1 Does uEnv.txt require any actions other than editing?
Ake Posted December 22, 2016 Author Posted December 22, 2016 Problem is solved. My mistake was adjusting uEnv.txt located in first partition (/dev/nanda) which mounts to /boot. In fact, actual uEnv.txt located in /boot directory of second (root) partiton (/dev/nandb). I've booted from SD, edited it and now everything works properly. 1
Igor Posted December 22, 2016 Posted December 22, 2016 I hope one day we will move nand uboot to recent uboot where those settings are done better. Wrote on mobile phone
