Following the instructions from the download page for the Lime2-eMMC we tried to apply the commands listed, but it looks that something is garbled here
apt-get update
apt-get upgrade
source /etc/armbian-release
dpkg -r linux-u-boot-lime2-${BRANCH} linux-$(lsb_release -cs)-root-${BRANCH}-lime2
apt-get -y install linux-u-boot-lime2-emmc-${BRANCH} linux-$(lsb_release -cs)-root-${BRANCH}-lime2-emmc
ln -fs bin/lime2-emmc.bin /boot/script.bin
echo lime2-emmc > /etc/hostname
reboot
source is not a command AFAIK and if I use it as an apt-get option the system complaints about missing entries in sources.
What is the correct way?
Nothing is wrong - this is the correct way and valid for recent images while this might not work on some older and not upgraded builds where this file is not present.
Command source executes /etc/armbian-release and we get values for needed variables. This is example of this file:
# PLEASE DO NOT EDIT THIS FILEBOARD=orangepipcplus
BOARD_NAME="Orange Pi PC +"
VERSION=5.24
LINUXFAMILY=sun8i
BRANCH=dev
ARCH=arm
Thanks Igor,
the image is the latest one - downloaded two days ago.
Did run apt-get update and upgrade again right now.
Though there is no file named armbian-release in /etc, making "source" protesting "no such file or directory".
Hubert
OK, than we have a problem ... well, there are two prebuild images for emmc version here.
We are reworking download section those days so this might not be valid long.
Thanks for the links.
We are on Mainline 4.7.3 Deb Jessie but will give a try.
Question: does the images allow to install into and boot from eMMC?
Sure yes, as written in docs.
Iḿ trying to follow these instructions:
apt-get update
apt-get upgrade
reboot
But in
it launches
Reading package lists... Done
Building dependency tree
E: Unable to locate package linux-jessie-root-default-lime2-emmc
And I'm stucked there.
Default packages are without default in the name - we have to fix this.
linux-jessie-root-lime2-emmc
ok. that worked. Thanks!
