HI,
I'm testing Debian wheezy, for now work well but i cant use LCD
How do I change display out ?...in olimex image I had some script like ./change_display
Thanks
With kernel 4.x ? I am afraid that won't be this simple since there is (probably?) no support for this display.
Legacy kernel within Armbian for Allwinner A10 is not available yet. I just started to work on it - already build a test one for Cubieboard 1 which is similar and it's working fine. I'll build for Olimex A10 too but can't test since I don't have this board.
For display you only need to use a proper configuration for display - FEX file. This is going into function with the script you run. If you wan't to use advantages of Armbian, you only need to boot kernel with that settings and it should work. Speaking for legacy kernel (3.4.x) ...
For kernel 4.x is another story. If no configuration exists, than some advanced work need to be done ...
Generally speaking - Armbian can't directly support external devices. I am adding support for HW / display that are around my desk, for which I can prove with my own eyes, that they work ... and if I find time and motivation to do so ;)
