Hqnicolas Posted December 3, 2023 Posted December 3, 2023 H96 Max With USB 2.0 rk3566-firefly-roc-pc.dtbrk3566-firefly-roc-pc.dts 0 Quote
ning Posted December 4, 2023 Author Posted December 4, 2023 after check firefly roc pc dts, they almast same as my dump from jianpian box. I have done the develop, but I still don't understand why WIFI only works once. and BT still not work. I may need to disable WIFI BT in original OS, and try again. 0 Quote
maka Posted December 5, 2023 Posted December 5, 2023 (edited) Delete this: wifi@1 { compatible = "brcm,bcm4329-fmac"; reg = < 0x01 >; interrupt-parent = < 0x63 >; interrupts = < 0x0a 0x04 >; interrupt-names = "host-wake"; pinctrl-names = "default"; pinctrl-0 = < 0x64 >; phandle = < 0xf8 >; }; Edited December 5, 2023 by maka 0 Quote
ning Posted December 5, 2023 Author Posted December 5, 2023 2 hours ago, maka said: Delete this: wifi@1 { compatible = "brcm,bcm4329-fmac"; reg = < 0x01 >; interrupt-parent = < 0x63 >; interrupts = < 0x0a 0x04 >; interrupt-names = "host-wake"; pinctrl-names = "default"; pinctrl-0 = < 0x64 >; phandle = < 0xf8 >; }; why? I check other rk3566 board with this wifi/bt chip, also don't have wifi@1. if I remove this would bt works? 0 Quote
maka Posted December 5, 2023 Posted December 5, 2023 I think it will work if you have firmware and loads. Maybe that refuses. dmesg | grep -i error ' 0 Quote
ning Posted December 9, 2023 Author Posted December 9, 2023 wifi works, with remove sd-uhs-sdr104; or change it to sd-uhs-sdr50; but bt still not work: [ 23.521445] Bluetooth: hci1: BCM: failed to write update baudrate (-110) [ 23.522130] Bluetooth: hci1: Failed to set baudrate [ 25.541403] Bluetooth: hci1: command 0x0c03 tx timeout 0 Quote
maka Posted December 11, 2023 Posted December 11, 2023 Quote wifi works, with remove sd-uhs-sdr104; or change it to sd-uhs-sdr50; I see , you have inherited wrong nodes from your github downloaded file that are not present in firefly or box-demo dtbs. Maybe you have to use these ones as reference. 0 Quote
ning Posted December 12, 2023 Author Posted December 12, 2023 Sata works, it's sata2. but BT still not work. 0 Quote
ning Posted December 12, 2023 Author Posted December 12, 2023 a mistake happens in u-boot, I forget to change/add boot device, only MMC1 is boot device, but MMC1 is wifi in dts. MMC2 is emmc. I have to buy a male-to-male usb cable and a rom. (less than 1RMB together) when I write the post, I suddenly realize I don't need to buy a rom, I can use RKdevtool to flash the uboot only!! let m try it when usb cable arrive. 0 Quote
ning Posted December 13, 2023 Author Posted December 13, 2023 @maka do you know how to drive front LED dispaly, it can display "boot", "WIFI" and time. 0 Quote
maka Posted December 13, 2023 Posted December 13, 2023 I don't use the display because I tinker just for fun 🙃 I believe you must have nodes for vfd and drive the display with a service like openvfd. Here is one related for an rk3566 android box. }; meson-vfd { compatible = "amediatech,aml_vfd"; dev_name = "meson-vfd"; vfd_data_gpio = <0x6d 0x14 0x00>; vfd_clock_gpio = <0x6d 0x15 0x00>; vfd_stb_gpio = <0x6d 0x16 0x00>; status = "okay"; }; 0 Quote
ning Posted December 13, 2023 Author Posted December 13, 2023 thank you let me know it's openvfd 0 Quote
ning Posted December 16, 2023 Author Posted December 16, 2023 Uboot back with flash under maskrom mode. 0 Quote
ning Posted December 19, 2023 Author Posted December 19, 2023 my uboot bootable, but with some wrong config, 1, board is wrong 2, sysboot not support. 0 Quote
ning Posted December 20, 2023 Author Posted December 20, 2023 done, with my uboot, it boot automatically to debian-13. but for now: ethernet, bt are enabled but not work. openvfd, LED, IR receive are not enabled. next step fix those. 0 Quote
ning Posted December 20, 2023 Author Posted December 20, 2023 Quote ning@Jianpian:~$ uname -a Linux Jianpian 6.5.0-5-arm64 #1 SMP Debian 6.5.13-1 (2023-11-29) aarch64 GNU/Linux ning@Jianpian:~$ journalctl -b 12月 20 15:03:51 Jianpian kernel: Booting Linux on physical CPU 0x0000000000 [0x412fd050] 12月 20 15:03:51 Jianpian kernel: Linux version 6.5.0-5-arm64 (debian-kernel@lists.debian.org) (gcc-13 (Debian 13.2.0-7) 13.2.0, GNU ld (GN> 12月 20 15:03:51 Jianpian kernel: KASLR disabled due to lack of seed 12月 20 15:03:51 Jianpian kernel: Machine model: Rockchip RK3566 JianPian 8G TV Box ning@Jianpian:~$ free -m total used free shared buff/cache available 内存: 7689 257 7432 1 150 7431 交换: 0 0 0 ethernet fixed. almost done. 0 Quote
ning Posted December 21, 2023 Author Posted December 21, 2023 Uboot: https://github.com/zhangn1985/u-boot/tree/jianpian kernel: https://github.com/zhangn1985/linux-stable/tree/jianpian 0 Quote
maka Posted December 21, 2023 Posted December 21, 2023 Why a custom kernel? Mainline is fully supported. 0 Quote
ning Posted December 22, 2023 Author Posted December 22, 2023 my kernel saves the dts for jianpian. Vendor dts for bluetooth wireless-bluetooth { pinctrl-names = "default\0rts_gpio"; pinctrl-0 = <0x13c>; clock-names = "ext_clock"; clocks = <0x138 0x01>; BT,wake_gpio = <0x13a 0x11 0x00>; BT,reset_gpio = <0x13a 0x0f 0x00>; uart_rts_gpios = <0x13a 0x0d 0x01>; compatible = "bluetooth-platdata"; BT,wake_host_irq = <0x13a 0x10 0x00>; pinctrl-1 = <0x13d>; status = "okay"; phandle = <0x1e7>; }; pinctrl-0, pinctrl-1 and uart_rts_gpio are decription for gpio2 RK_PB5, which is uart1 rtsn pin. phandle <0x13a> is gpio2. My mainline dts for bluetooth: &uart1 { pinctrl-names = "default"; pinctrl-0 = <&uart1m0_xfer &uart1m0_ctsn &uart1m0_rtsn>; status = "okay"; uart-has-rtscts; bluetooth { compatible = "brcm,bcm43438-bt"; clocks = <&rk809 1>; clock-names = "lpo"; device-wakeup-gpios = <&gpio2 RK_PC1 GPIO_ACTIVE_HIGH>; host-wakeup-gpios = <&gpio2 RK_PC0 GPIO_ACTIVE_HIGH>; shutdown-gpios = <&gpio2 RK_PB7 GPIO_ACTIVE_HIGH>; pinctrl-names = "default"; pinctrl-0 = <&bt_host_wake_l &bt_wake_l &bt_enable_h>; vbat-supply = <&vcc3v3_sys>; vddio-supply = <&vcca1v8_pmu>; }; }; but bluetooth failed: Quote [ 14.433949] Bluetooth: hci0: command 0xfc18 tx timeout [ 22.498017] Bluetooth: hci0: BCM: failed to write update baudrate (-110) [ 22.498690] Bluetooth: hci0: Failed to set baudrate [ 24.514009] Bluetooth: hci0: command 0x0c03 tx timeout [ 32.737999] Bluetooth: hci0: BCM: Reset failed (-110) 0 Quote
ning Posted December 26, 2023 Author Posted December 26, 2023 bluetooth works, due to swapped host/device gpio. 0 Quote
Hqnicolas Posted February 15 Posted February 15 On 12/22/2023 at 5:41 AM, ning said: My mainline dts for bluetooth: good Job! you was working hard for so long. rk3566-jianpian.dts 0 Quote
