JianPian RK3566 TV Box (8G+32G) develop log
ning
after check firefly roc pc dts, they almast same as my dump from jianpian box.
I have done the develop, but I still don't understand why WIFI only works once. and BT still not work.
I may need to disable WIFI BT in original OS, and try again.
Delete this:
wifi@1 {
            compatible = "brcm,bcm4329-fmac";
            reg = < 0x01 >;
            interrupt-parent = < 0x63 >;
            interrupts = < 0x0a 0x04 >;
            interrupt-names = "host-wake";
            pinctrl-names = "default";
            pinctrl-0 = < 0x64 >;
            phandle = < 0xf8 >;
Edited by maka
2 hours ago, maka said:
Delete this:
wifi@1 {
            reg = < 0x01 >;
            phandle = < 0xf8 >;
why? I check other rk3566 board with this wifi/bt chip, also don't have wifi@1. if I remove this would bt works?
wifi works, with remove sd-uhs-sdr104; or change it to sd-uhs-sdr50;
but bt still not work:
[   23.521445] Bluetooth: hci1: BCM: failed to write update baudrate (-110)
[   23.522130] Bluetooth: hci1: Failed to set baudrate
[   25.541403] Bluetooth: hci1: command 0x0c03 tx timeout
Quote
I see , you have inherited wrong nodes from your github downloaded file that are not present in firefly or box-demo dtbs. Maybe you have to use these ones as reference.
a mistake happens in u-boot, I forget to change/add boot device, only MMC1 is boot device, but MMC1 is wifi in dts. MMC2 is emmc.
I have to buy a male-to-male usb cable and a rom. (less than 1RMB together)
when I write the post, I suddenly realize I don't need to buy a rom, I can use RKdevtool to flash the uboot only!!
let m try it when usb cable arrive.
I don't use the display because I tinker just for fun 🙃
I believe you must have nodes for vfd and drive the display with a service like openvfd. Here is one related for an rk3566 android box.
    meson-vfd {
        compatible = "amediatech,aml_vfd";
        dev_name = "meson-vfd";
        vfd_data_gpio = <0x6d 0x14 0x00>;
        vfd_clock_gpio = <0x6d 0x15 0x00>;
        vfd_stb_gpio = <0x6d 0x16 0x00>;
        status = "okay";
Quote
ning@Jianpian:~$ uname -a
Linux Jianpian 6.5.0-5-arm64 #1 SMP Debian 6.5.13-1 (2023-11-29) aarch64 GNU/Linux
ning@Jianpian:~$ journalctl -b
12月 20 15:03:51 Jianpian kernel: Booting Linux on physical CPU 0x0000000000 [0x412fd050]
12月 20 15:03:51 Jianpian kernel: Linux version 6.5.0-5-arm64 (debian-kernel@lists.debian.org) (gcc-13 (Debian 13.2.0-7) 13.2.0, GNU ld (GN>
12月 20 15:03:51 Jianpian kernel: KASLR disabled due to lack of seed
12月 20 15:03:51 Jianpian kernel: Machine model: Rockchip RK3566 JianPian 8G TV Box
ning@Jianpian:~$ free -m
               total        used        free      shared  buff/cache   available
内存:          7689         257        7432           1         150        7431
交换:             0           0           0
ethernet fixed.
almost done.
my kernel saves the dts for jianpian.
Vendor dts for bluetooth
        wireless-bluetooth {
                pinctrl-names = "default\0rts_gpio";
                pinctrl-0 = <0x13c>;
                clock-names = "ext_clock";
                clocks = <0x138 0x01>;
                BT,wake_gpio = <0x13a 0x11 0x00>;
                BT,reset_gpio = <0x13a 0x0f 0x00>;
                uart_rts_gpios = <0x13a 0x0d 0x01>;
                compatible = "bluetooth-platdata";
                BT,wake_host_irq = <0x13a 0x10 0x00>;
                pinctrl-1 = <0x13d>;
                status = "okay";
                phandle = <0x1e7>;
pinctrl-0, pinctrl-1 and uart_rts_gpio are decription for gpio2 RK_PB5, which is uart1 rtsn pin.
phandle <0x13a> is gpio2.
My mainline dts for bluetooth:
&uart1 {
	pinctrl-0 = <&uart1m0_xfer &uart1m0_ctsn &uart1m0_rtsn>;
	status = "okay";
	uart-has-rtscts;
	bluetooth {
		compatible = "brcm,bcm43438-bt";
		clocks = <&rk809 1>;
		clock-names = "lpo";
		device-wakeup-gpios = <&gpio2 RK_PC1 GPIO_ACTIVE_HIGH>;
		host-wakeup-gpios = <&gpio2 RK_PC0 GPIO_ACTIVE_HIGH>;
		shutdown-gpios = <&gpio2 RK_PB7 GPIO_ACTIVE_HIGH>;
		pinctrl-0 = <&bt_host_wake_l &bt_wake_l &bt_enable_h>;
		vbat-supply = <&vcc3v3_sys>;
		vddio-supply = <&vcca1v8_pmu>;
but bluetooth failed:
Quote
[   14.433949] Bluetooth: hci0: command 0xfc18 tx timeout
[   22.498017] Bluetooth: hci0: BCM: failed to write update baudrate (-110)
[   22.498690] Bluetooth: hci0: Failed to set baudrate
[   24.514009] Bluetooth: hci0: command 0x0c03 tx timeout
[   32.737999] Bluetooth: hci0: BCM: Reset failed (-110)
