I have a non compliant usb device that I want to work with my Orange Pi Lite board.
I know how to make it work under Arch linux. For that I need to edit source for the usb generic hid driver (kernel/drivers/hid/hid-core.c), recompile the usb kernel module and reinstall it to intramfs (mkinitcpio -p linux). To recompile kernel module I followed this guide: https://wiki.archlinux.org/index.php/Compile_kernel_module
What procedure do I need to follow under Armbian?
One way is to set up a development environment on a PC, with Virtual Box running Ubuntu Xenial, etc. Recompile the whole armbian and copy the compiled kernel module over to Orange Pi Lite.
But it takes a long time. Is there any way to recompile a kernel modue directly on the board?
Thanks for your time.
hid-core.c is a built-in object, so full kernel recompilation is required. Compiling the kernel on the board itself is possible, but there is no automation for this process yet, so you have to do everything manually - clone the sources, grab and apply the patches, grab the kernel config, compile and install resulting packages.
Can I just use Igor's lib tool on the Orange Pi Lite?
Nope. It's a tool to run on a x86 desktop PC (cross compile).
In the end I decided to go with creating a x-compile environment to get a patched hid.ko.gz
However I just noticed that my current armbian does not have a hid.ko.gz module. It has only g_hid.ko.gz
So would I go about installing a hid.ko.gz module?
my current setup: (uname -r)
Linux orangepilite 3.4.112-sun8i #10 SMP PREEMPT Sun Oct 23 16:06:55 CEST 2016 armv7l GNU/Linux
Legacy Debian Jessie
Please read my message again. In current Armbian config
CONFIG_HID=y
so it's a built-in, not a module, and hid-core.c ends up in the main kernel binary (zImage), so, as I said before, full kernel recompilation is required to patch this file.
Alright, I will just leave the instructions here for the record:
So I went with x-compiling.
(looks like now there is a vargrand config to set up the x-compile environment, so you can use that)
Installed VitrualBox & put Ubuntu Xenial on it.
sudo apt-get install linux-headers-$(uname -r) build-essentials
Then according to https://github.com/igorpecovnik/lib
I git cloned the lib
Then edited the compile.sh with the following options:
KERNEL_ONLY="yes" # leave empty to select each time, set to "yes" or "no" to skip dialog prompt
KERNEL_CONFIGURE="no" # change provided kernel configuration
CLEAN_LEVEL="make,debs" # comma-separated list of clean targets: "make" = make clean for selected kernel and u-boot,
# "debs" = delete packages in "./output/debs" for current branch and family,
# "alldebs" - delete all packages in "./output/debs", "images" = delete "./output/images",
# "cache" = delete "./output/cache", "sources" = delete "./sources"
DEST_LANG="en_US.UTF-8" # sl_SI.UTF-8, en_US.UTF-8
# advanced
KERNEL_KEEP_CONFIG="no" # do not overwrite kernel config before compilation
EXTERNAL="no" # build and install extra applications and drivers
EXTERNAL_NEW="no" # compile and install or install prebuilt additional packages
CREATE_PATCHES="yes" # wait that you make changes to uboot and kernel source and creates patches
FORCE_CHECKOUT="yes" # ignore manual changes to source
BUILD_ALL="no" # cycle through available boards and make images or kernel/u-boot packages.
# set KERNEL_ONLY to "yes" or "no" to build all packages/all images
BUILD_DESKTOP="no"
BOARD="orangepilite"
BRANCH="default"
RELEASE="jessie"
Then I run ./compile.sh with sudo.
Then when the script got to kernel compilation, I was prompted to edit the code and continue.
So I went ahead and modified the sources/linux-sun8i/sun8i/drivers/hid-core.c
Then I hit enter to let compilation continue and it told me that a patch was generated.
However that patch did not seem to get applied. So I moved the patch into userpatches/kernel/sun8i-default/my-kernel-patch.patch
and restarted the whole compile process (this time I compiled with CREATE_PATCHES="no")
In the end I got the deb files in the output
├── extra
├── jessie
│   └── linux-jessie-root-orangepilite_5.24_armhf.deb
├── linux-firmware-image-sun8i_5.24_armhf.deb
├── linux-headers-sun8i_5.24_armhf.deb
├── linux-image-sun8i_5.24_armhf.deb
└── linux-u-boot-orangepilite_5.24_armhf.deb
I used scp to copy them over to the orange pi lite.
After reading this thread: https://forum.armbian.com/index.php/topic/1315-custom-kernel-and-apt-get-update/
I realised that I only needed the headers, image and firmware debs. So I went ahead and installed them
with "sudo dpkg -i *.deb" (after removing u-boot deb package).
Then I pinned them, so they dont get changed on the next "apt-get upgrade".
And it works!
Thanks everyone!
Overall the toolchain is a bit difficult to grasp (argh, and the constant recompiles are off putting!), but serious kudos to you for creating and maintaning it! Because it actually works!
