Install to/update boot loader not working
Go to solution Solved by Igor,
I'm trying to install the system to external usb drive on my OrangePi PC + using armbian-config tool but I get this error
### Board installation issue: File /usr/lib/nand-sata-install/exclude.txt does not exist or is not accessible!
OS installed Armbian 23.8.1 with 6.1.53-current-sunxi kernel
Everything looks OK and I can't find a problem at our side at short notice.
Workaround. Create this file (/usr/lib/nand-sata-install/exclude.txt) with following content:
/boot/*
/dev/*
/proc/*
/sys/*
/media/*
/mnt/*
/run/*
/tmp/*
/ddbr/*
/var/log/journal
And try again.
I get following error
### Board installation issue: File /usr/lib/nand-sata-install/a20/bootloader does not exist or is not accessible!
I poked around and found folder /usr/lib/armbian-install which contains file with same content you mentioned above along with 3 subfolders titled a10, a20, a13.
Would copying all content from armbian-install to nand-sata-install help?
Edited by Wilson Wilson
