Flops Posted November 30, 2023 Posted November 30, 2023 Suddenly after updating via armbian-config I lost ssh access and found the port closed. I rewrote the latest armbian version, stuck the sd card in, connected to ethernet cable via router and started up. The red and green lights were on as they should be and the internet cable was flashing green. Waited 3 minutes and checked the ports with nmap. And the port is closed again. Not responding to ping at all. I am still new to this topic. Please help and sorry if the translator translates crookedly. 0 Quote
Charles Lee Scoville Posted December 8, 2023 Posted December 8, 2023 Sorry if this comes off as obvious or unhelpful... but if it were me I would hook up HMDI + USB KB real quick just to verify that the board was fully coming online. 0 Quote
Werner Posted December 8, 2023 Posted December 8, 2023 Or do it properly via UART https://www.youtube.com/watch?v=UpVMO7gbnYM 0 Quote
Flops Posted December 9, 2023 Author Posted December 9, 2023 (edited) Thanks for the answer. I'll give it a try. I do not have such an adapter, but I will buy it Edited December 9, 2023 by Flops 0 Quote
Flops Posted December 9, 2023 Author Posted December 9, 2023 (edited) In addition I want to say that when I tried to run armbian with usb ethernet started to light up and orange light. I am still waiting for the adapter to be delivered Edited December 9, 2023 by Flops 0 Quote
Flops Posted December 18, 2023 Author Posted December 18, 2023 I bought a uart and connected it according to the instructions in the video. I used screen and set the speed to 1500000 but the terminal shows only garbage. Maybe I should set a different speed? 0 Quote
Flops Posted December 18, 2023 Author Posted December 18, 2023 I use a CP2102 with UART Baud Rates: 300 bps -1 Mbps 0 Quote
Werner Posted December 18, 2023 Posted December 18, 2023 On 12/18/2023 at 4:32 PM, Flops said: CP2102 Expand Good enough for allwinner but too slow for AML or RK. Get a proper one. 1500000 is the correct speed. If the chip cannot handle it you obviously get an error or garbage. 0 Quote
Flops Posted December 18, 2023 Author Posted December 18, 2023 (edited) ok. I forgot to look. All right, I'll buy a proper adapter. Can you recommend an adapter or tell me where to look? Edited December 18, 2023 by Flops 0 Quote
Werner Posted December 18, 2023 Posted December 18, 2023 aliexpress, amazon, ebay,.... all of those should have some proper ones. For recommended chips please refer to the video mentioned above. 0 Quote
Flops Posted December 18, 2023 Author Posted December 18, 2023 I bought it. I'll wait a month 0 Quote
Flops Posted January 14, 2024 Author Posted January 14, 2024 (edited) I bought a uart and connected it as indicated in the video. The text is already readable, but sometimes it underwrites and moves away. What should I do next? Modified: it does not output correctly what I enter. Is there any way to improve it? Edited January 14, 2024 by Flops 0 Quote
Flops Posted January 14, 2024 Author Posted January 14, 2024 Saw this in the logs: INFOx4000001 != 0xfead0003 ERROR: INFO: BL31: Initializing Excervices WARNING: No OPTEE providon. SMC`s destined for OPTEE wil (eMMC) Maybe it means something? 0 Quote
Flops Posted January 14, 2024 Author Posted January 14, 2024 No, it was just me being stupid and mixing up the wires. 0 Quote
Flops Posted January 14, 2024 Author Posted January 14, 2024 (edited) The system boots from the sd card and correctly. sshd is also active. Strange... Edited January 14, 2024 by Flops 0 Quote
Flops Posted January 15, 2024 Author Posted January 15, 2024 It can work via uart, sshd works and yet it does not respond to a ping or ssh connection. At the same time it can connect to the internet and download packets by itself. 0 Quote
Flops Posted February 3, 2024 Author Posted February 3, 2024 I tried rebooting the router. Nothing changed in the end. The router does not respond to ping, but the board works properly via uart. Please help 0 Quote
Werner Posted February 3, 2024 Posted February 3, 2024 So when UART works you can use armbianmonitor -U to print debug output to serial and then use a pastebin service of your choice to share the whole output. 0 Quote
Flops Posted February 3, 2024 Author Posted February 3, 2024 Could you tell me how to conveniently transfer logs to a text file, because the terminal floats when scrolling? 0 Quote
Flops Posted February 3, 2024 Author Posted February 3, 2024 Here are the notes after the command logFetching info... 0 Quote
Werner Posted February 4, 2024 Posted February 4, 2024 1468 ### ip addr: 1469 p default qlen 1000 1471 link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00 1472 inet XXX.XXX.0.1/8 scope host lo 1473 valid_lft forever preferred_lft forever 1474 inet6 ::1/128 scope host noprefixroute 1475 valid_lft forever preferred_lft forever ult qlen 1000 1477 link/ether 6e:48:1c:02:bd:e7 brd ff:ff:ff:ff:ff:ff 1478 Either the logs are incomplete or the ethernet ports don't show up at all. Odd... 0 Quote
Flops Posted February 4, 2024 Author Posted February 4, 2024 (edited) When I connected to cable and uart it was able to update and download packages. I will try to copy the log again today. And I'll also check ifconfig Edited February 4, 2024 by Flops 0 Quote
Flops Posted February 4, 2024 Author Posted February 4, 2024 (edited) 1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000 link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00 inet 127.0.0.1/8 scope host lo valid_lft forever preferred_lft forever inet6 ::1/128 scope host noprefixroute valid_lft forever preferred_lft forever 2: end1: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq state UP group default qlen 1000 link/ether 2a:77:33:98:ba:5a brd ff:ff:ff:ff:ff:ff inet 192.168.0.108/24 brd 192.168.0.255 scope global dynamic noprefixroute end1 valid_lft 7145sec preferred_lft 7145sec inet6 fe80::8a87:d850:159c:a59e/64 scope link noprefixroute valid_lft forever preferred_lft forever This is what the ip a gave me when I plugged in the cable. Edited February 4, 2024 by Flops 0 Quote
Flops Posted February 4, 2024 Author Posted February 4, 2024 And yes, that log I sent you is without the cable connected. 0 Quote
Flops Posted February 4, 2024 Author Posted February 4, 2024 Is there anything else I need to check? 0 Quote
Flops Posted February 21, 2024 Author Posted February 21, 2024 When scanning the network via arp-scan it still writes (Unknown: locally administered). 0 Quote
Solution Flops Posted February 25, 2024 Author Solution Posted February 25, 2024 Anyway, as it turns out I didn't have "local access" enabled in the access point settings. LOL 0 Quote
