Cannot connect via ssh protocol to orange pi 5b after installing sd card.
Flops
Go to solution Solved by Flops,
Suddenly after updating via armbian-config I lost ssh access and found the port closed. I rewrote the latest armbian version, stuck the sd card in, connected to ethernet cable via router and started up. The red and green lights were on as they should be and the internet cable was flashing green. Waited 3 minutes and checked the ports with nmap. And the port is closed again.
Not responding to ping at all. I am still new to this topic. Please help and sorry if the translator translates crookedly.
Screenshot_20231130_172722-1.png.9d27f66106109440941a9e99ab31e16c.pngScreenshot_20231130_173048-1.png.92d4db1f89aa9fc2635b1ecf10d5661c.png
I bought a uart and connected it as indicated in the video. The text is already readable, but sometimes it underwrites and moves away. What should I do next?
Modified: it does not output correctly what I enter. Is there any way to improve it?
Edited by Flops
So when UART works you can use armbianmonitor -U to print debug output to serial and then use a pastebin service of your choice to share the whole output.
 1468  ### ip addr:
  1469
p default qlen 1000
  1471      link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
  1472      inet XXX.XXX.0.1/8 scope host lo
  1473         valid_lft forever preferred_lft forever
  1474      inet6 ::1/128 scope host noprefixroute
  1475         valid_lft forever preferred_lft forever
ult qlen 1000
  1477      link/ether 6e:48:1c:02:bd:e7 brd ff:ff:ff:ff:ff:ff
  1478
Either the logs are incomplete or the ethernet ports don't show up at all. Odd...
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
    inet 127.0.0.1/8 scope host lo
2: end1: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq state UP group default qlen 1000
    link/ether 2a:77:33:98:ba:5a brd ff:ff:ff:ff:ff:ff
    inet 192.168.0.108/24 brd 192.168.0.255 scope global dynamic noprefixroute end1
       valid_lft 7145sec preferred_lft 7145sec
    inet6 fe80::8a87:d850:159c:a59e/64 scope link noprefixroute
This is what the ip a gave me when I plugged in the cable.
Edited by Flops
