Daniel Turcich Posted December 2, 2023 Posted December 2, 2023 Hello, sorry if this has been answered somewhere else. I was just wondering how i upgrade my Orange Pi 5 running Arbmian 23.11.1 Bookworm w/ Linux 5.10.160-legacy-rk35xx to the latest Kernel. I tried using `sudo armbian-config` and updating via that with kernel upgrades unfrozen but it doesn't seem to work. Is there something I'm missing? Startup splash below: ___ ____ _ ____ / _ \| _ \(_) | ___| | | | | |_) | | |___ \ | |_| | __/| | ___) | \___/|_| |_| |____/ Welcome to Armbian 23.11.1 Bookworm with Linux 5.10.160-legacy-rk35xx System load: 4% Up time: 0 min Memory usage: 8% of 3.83G IP: 192.168.1.69 10.121.215.1 CPU temp: 40°C Usage of /: 6% of 57G RX today: 38.2 MiB 0 Quote
Werner Posted December 3, 2023 Posted December 3, 2023 5.10.160 is rockchip bsp kernel with some patches from Armbian on top. The version does not increase for this one and probably never will. The only thing what you could do is to switch to bleeding edge mainline kernel which at this very moment is shipped in version 6.7-rc1. If you prefer a system that is mostly stable and also supports most hardware features I recommend to stay with 5.10.160. 0 Quote
Daniel Turcich Posted December 3, 2023 Author Posted December 3, 2023 Gotcha! Will take your advice on that Thank you! 0 Quote
Eternalight7 Posted January 8, 2024 Posted January 8, 2024 (edited) 6.7-rc1 does not boot when flashed over. Any thoughts as to why. Edit: Spooky, on Ambian discord, said that 6.1 BSP is a Work in Progress. So I guess we have to wait. I'm waiting for my usb-ttl serial dongle to come in. I'll post here if I find the answer to the no boot question. Edited January 8, 2024 by Eternalight7 0 Quote
Marc R Posted January 9, 2024 Posted January 9, 2024 I'm running 6.7.0-rc8-edge-rockchip-rk3588 as a server. Everything is working except the vertical usb. 0 Quote
Gullik Posted January 13, 2024 Posted January 13, 2024 And I am running 6.7.0-rc8-edge-rockchip-rk3588 as a desktop. It seems OK, except for the vertical usb. Is this missing code in the kernel, or just an incomplete dtb? Gullik 0 Quote
Werner Posted January 13, 2024 Posted January 13, 2024 mainline support has still long way to go until completion. Current state is more or less to be considered experimental. For its current state it works suprisingly well. 0 Quote
