guidol Posted November 25, 2019 Posted November 25, 2019 1 hour ago, alterfritz said: When I run ./compile I can not see any rda8810... guess it is not that easy... No it isnt that easy You could use of my old images (when the i96/2G-iot was in the armbian-build-system):https://drive.google.com/drive/folders/18r98nniuPmGMx2puxQleT9jtRWK03_VS or try to use build-root fromhttps://github.com/txurtxil/broot2g Maybe the following thread will bring you some alternatives:
alterfritz Posted November 26, 2019 Posted November 26, 2019 Yep - get all compiled - it has to be ubuntu 16.04. Thanks. The only one annoying thing left - this random MAC address. Is this fixed somewhere?
guidol Posted November 26, 2019 Posted November 26, 2019 38 minutes ago, alterfritz said: The only one annoying thing left - this random MAC address. Is this fixed somewhere? you could try to set it inside /etc/network/interfaces (when not using network-manager): with hwaddress ether auto eth0 iface eth0 inet dhcp hwaddress ether 01:02:03:04:05:06
alterfritz Posted November 26, 2019 Posted November 26, 2019 Will try that... thanks. Btw. currently testing those Buildroot images. Nice. But I do not see any wlan0, so no wifi. https://github.com/txurtxil/broot2g Did you get that working?
alterfritz Posted November 26, 2019 Posted November 26, 2019 Orange Pi 2G-IOT login: root Password: Login incorrect 2G-IOT login: root Password: # ifconfig lo Link encap:Local Loopback inet addr:127.0.0.1 Mask:255.0.0.0 inet6 addr: ::1/128 Scope:Host UP LOOPBACK RUNNING MTU:65536 Metric:1 RX packets:0 errors:0 dropped:0 overruns:0 frame:0 TX packets:0 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:0 RX bytes:0 (0.0 TX bytes:0 (0.0 #
guidol Posted November 26, 2019 Posted November 26, 2019 1 minute ago, alterfritz said: https://github.com/txurtxil/broot2g Did you get that working? I didnt try that myself, because my build-system is ubuntu 18.04 64bit
alterfritz Posted November 26, 2019 Posted November 26, 2019 It build on 16.04, I can confirm that. Lets see if I can get wifi working. So far your armbian ones seems to be the most stable. Nice work!
Ahmed Wahdan Posted December 6, 2019 Posted December 6, 2019 Hello, After configuring the WIFI and reboot the board stuck while trying to bring up WIFI. Is it a known issue?
asimrasheed Posted April 10, 2020 Posted April 10, 2020 Hi, I am making Asterisk PBX over Orange Pi - 2g IoT, I have tried Armbian as well as Ubuntu. Everything is working fine, but I am stuck on two issues, a. How to add built-in GSM module of Orange Pi 2g IoT board in asterisk, so that A GSM trunk call/text can be transferred on SIP extension. I know chan-dongle, but asterisk is not detecting GSM module. I ahve tried different versions of asterisk. b. How to change IMEI of Orange Pi 2g IoT Looking for solutions Regards
Gabor5745737 Posted April 13, 2021 Posted April 13, 2021 Here is the official source code for i96: https://github.com/orangepi-xunlong/OrangePi_Build The official debian/ubuntu release freezes every time for me..
Gabor Hidvegi Posted October 18, 2021 Posted October 18, 2021 Hello all, I bought one of these nice little devices, and and after a week of playing with it, I'm quite satisfied. Of course the software side is not the best, but the board itself is powerful, cheap, and it is full of features. Right now all I am missing is a working LCD under Linux. I bought the official phone display from Aliexpress, it works under Android, but no success so far in Linux. So I'm looking for some help here with it. I have cleaned and formatted the kernel source code (kernel/drivers/video/rda directory), it uses and registers the ILI9806g_mcu according to the dmesg output, but there is only garbage on the screen after it is initialized. So I think the FrameBuffer driver maps to a wrong RAM address. The rda-fb module outputs this: "rda-fb rda-fb: init done, 480 x 800 = 1540096, at cf028000, phys 0x8e200000" When I convert the 0x8e200000 to decimal, it is an insanely high number (around 2 terabytes), which is suspicious. Is there anyone here with kernel and LCD programming experience, who could help me with sorting this out? I also tried to compile a kernel from the released Android source code, which is a bit different, but it doesn't work either. My next project is to make working the Vivante driver, also found in the Android source. 1
Gabor Hidvegi Posted October 21, 2021 Posted October 21, 2021 The USB A port with the original kernel is pretty slow, I plugged in a 10/100 MCS7830 Ethernet adapter, and the average up/download speed is around 400 KB/s. I took a look at the code and in kernel/drivers/usb/musb/rda.c I found the following in the rda_start_host() function: /* disable high speed when host*/ power = musb_readb(regs, MUSB_POWER); power &= ~MUSB_POWER_HSENAB; musb_writeb(regs, MUSB_POWER, power); I commented it out, rebuilt the kernel, and now I'm testing whether the USB is reliable or not. The download speed from the board with SSH is now around 1 MB/s.
mahaju Posted October 27, 2021 Posted October 27, 2021 On 11/26/2019 at 2:52 AM, guidol said: No it isnt that easy You could use of my old images (when the i96/2G-iot was in the armbian-build-system): https://drive.google.com/drive/folders/18r98nniuPmGMx2puxQleT9jtRWK03_VS or try to use build-root from https://github.com/txurtxil/broot2g Maybe the following thread will bring you some alternatives: @guidolHi sorry to revive an old post but I am working on an orangepi 2g-iot board and I wanted to check out your armbian image I am stuck at the login prompt I have tried orangepi / orangepi and root / orangepi as username / password but both don't work Could you please let me know the username and password for these images?
Gabor Hidvegi Posted October 27, 2021 Posted October 27, 2021 The "official" LCD works with the device under Android for sure. https://www.aliexpress.com/item/32816194245.html I compiled the Android kernel separately, and used it with Linux (I had to add devtmpfs configuration options), but with the same results, after it turns on, the Framebuffer driver cannot draw on it.
guidol Posted October 27, 2021 Posted October 27, 2021 7 hours ago, mahaju said: @guidol Could you please let me know the username and password for these images? as a normal armbian-image it should be root as user and 1234 as initial password 1
Gabor Hidvegi Posted February 2, 2022 Posted February 2, 2022 I managed to draw on the screen under Linux by playing with the driver. It's far from working, but at least now I understand a few things. Now it only refreshes the screen when the FrameBuffer fb_pan_display() function is called, which does a full refresh. It gives no sign of life when only a portion of the screen should be redrawn, like the cursor. I couldn't yet figure out how to detect when the framebuffer memory changes.
Gabor Hidvegi Posted February 5, 2022 Posted February 5, 2022 So, I managed to make usable the framebuffer driver under Linux. It's still far from perfect, and the refresh rate is now five frames per second, but of course I can increase it, it's just not necessary yet. On the first picture there is the console I used with an attached keyboard, on the second picture there is a light Window Manager (JWM) I compiled on the machine running with an attached mouse. The distribution is Armbian 5.27, which I found somewhere on the net. The USB port is a budget one, according to the kernel message it doesn't support USB hubs, but I have to try that out yet. Theoretically it is possible to integrate the framebuffer driver into the Linux Kernel's FBTFT subtree, that way it could be more easily ported to mainline. I wonder if I can make usable the WiFi driver along with the sound card.
Gabor Hidvegi Posted February 6, 2022 Posted February 6, 2022 The WiFi seems to be okay (not too fast though), the sound card doesn't work under Linux, because it's driver is not finished (like the framebuffer driver), it has only enough functionality to work under Android.
CarlosRupp Posted February 21, 2022 Posted February 21, 2022 On 2/5/2022 at 2:46 PM, Gabor Hidvegi said: So, I managed to make usable the framebuffer driver under Linux. It's still far from perfect, and the refresh rate is now five frames per second, but of course I can increase it, it's just not necessary yet. On the first picture there is the console I used with an attached keyboard, on the second picture there is a light Window Manager (JWM) I compiled on the machine running with an attached mouse. The distribution is Armbian 5.27, which I found somewhere on the net. The USB port is a budget one, according to the kernel message it doesn't support USB hubs, but I have to try that out yet. Theoretically it is possible to integrate the framebuffer driver into the Linux Kernel's FBTFT subtree, that way it could be more easily ported to mainline. I wonder if I can make usable the WiFi driver along with the sound card. Great work! Could you make a public image from this system for download?
Gabor Hidvegi Posted February 21, 2022 Posted February 21, 2022 14 minutes ago, CarlosRupp said: Great work! Could you make a public image from this system for download? Of course, I will, but I'm far from that. Most probably it would be faster if I shared the kernel file, that would render all available 2G IoT images usable. I will see what I can do. Unfortunately I couldn't make the sound card work yet, and on my device the touch screen stopped to respond. I ordered another one from Aliexpress, but it will take a few weeks to arrive. I also discovered that the full size USB port is running at 10 mbps normally, because the modem needs to initialize the micro USB port first, and this procedure takes about six seconds. If we start to load the kernel USB drivers after this, then our USB works at 480 mbps. I have to figure out how to deal with it. 1
