ricardo_brz Posted December 17, 2023 Posted December 17, 2023 After looking at this message from @Seb042 I thought it would be better to open a new topic to discuss this. From what I saw from my install: $ dmesg ... [ 6.166453] iwlwifi 0002:21:00.0: api flags index 2 larger than supported by driver [ 6.166480] iwlwifi 0002:21:00.0: TLV_FW_FSEQ_VERSION: FSEQ Version: 93.8.63.28 [ 6.167021] iwlwifi 0002:21:00.0: loaded firmware version 59.601f3a66.0 ty-a0-gf-a0-59.ucode op_mode iwlmvm [ 6.267334] iwlwifi 0002:21:00.0: Detected Intel(R) Wi-Fi 6 AX210 160MHz, REV=0x420 [ 6.273748] iwlwifi 0002:21:00.0: reporting RF_KILL (radio disabled) [ 6.450150] iwlwifi 0002:21:00.0: WFPM_UMAC_PD_NOTIFICATION: 0x1f [ 6.450175] iwlwifi 0002:21:00.0: WFPM_LMAC2_PD_NOTIFICATION: 0x1f [ 6.450189] iwlwifi 0002:21:00.0: WFPM_AUTH_KEY_0: 0x90 [ 6.450206] iwlwifi 0002:21:00.0: CNVI_SCU_SEQ_DATA_DW9: 0x0 [ 6.450997] iwlwifi 0002:21:00.0: Detected RF GF, rfid=0x10d000 [ 6.517606] iwlwifi 0002:21:00.0: base HW address: ab:cd:ef:01:23:45 [ 6.571168] iwlwifi 0002:21:00.0 wlP2p33s0: renamed from wlan0 ... I had the same error, with the same chip (AX210). I looked for each of the message and maybe, and this is just an assumption, we, AX201 users, will have to wait until the the driver is updated for the 6.7 line? Is that right? 0 Quote
Solution Werner Posted December 18, 2023 Solution Posted December 18, 2023 Probably. (bleeding) edge follows upstream not much involvement from Armbian developers there. If you want stuff working use legacy 5.10.y kernel. 0 Quote
ricardo_brz Posted December 18, 2023 Author Posted December 18, 2023 Yeah, but how boring would the world be if there were no (bleeding) edge users to complain about things not working and everything just works! Thanks for the reply, btw! 0 Quote
ricardo_brz Posted January 2, 2024 Author Posted January 2, 2024 (edited) Tried the latest version, still no lucky with the Wi-Fi, but I noticed this: iw reg get global country 00: DFS-UNSET (755 - 928 @ 2), (N/A, 20), (N/A), PASSIVE-SCAN (2402 - 2472 @ 40), (N/A, 20), (N/A) (2457 - 2482 @ 20), (N/A, 20), (N/A), AUTO-BW, PASSIVE-SCAN (2474 - 2494 @ 20), (N/A, 20), (N/A), NO-OFDM, PASSIVE-SCAN (5170 - 5250 @ 80), (N/A, 20), (N/A), AUTO-BW, PASSIVE-SCAN (5250 - 5330 @ 80), (N/A, 20), (0 ms), DFS, AUTO-BW, PASSIVE-SCAN (5490 - 5730 @ 160), (N/A, 20), (0 ms), DFS, PASSIVE-SCAN (5735 - 5835 @ 80), (N/A, 20), (N/A), PASSIVE-SCAN (57240 - 63720 @ 2160), (N/A, 0), (N/A) phy#0 (self-managed) country 00: DFS-UNSET ... And I was not able to set the country for phy#0 at all. I've tried iw reg set BR but will only change global, but phy#0 will stay the same. Also, this config is lost once I reboot. In the legacy version, this configuration is fine: ... phy#0 (self-managed) country BR: DFS-UNSET ... Edited January 2, 2024 by ricardo_brz 0 Quote
Werner Posted January 3, 2024 Posted January 3, 2024 Have you installed armbian-firmware-full via apt? 0 Quote
ricardo_brz Posted January 3, 2024 Author Posted January 3, 2024 6 hours ago, Werner said: Have you installed armbian-firmware-full via apt? Yes, no lucky. Have set all the location information in armbian-config, but it's locked in phy#0 (self-managed) country 00: DFS-UNSET 0 Quote
jimtjames Posted May 30, 2024 Posted May 30, 2024 Just thought I'd add that this appears to be fixed in the latest "stable" release with edge kernel (6.8.10). Connecting to WiFi networks works out of the box, and creating a hotspot works if you install armbian-firmware-full. 3 Quote
ricardo_brz Posted May 31, 2024 Author Posted May 31, 2024 That's right! I just tested it today and it's working fine! 0 Quote
