pinebookpro-owner Posted December 19, 2023 Share Posted December 19, 2023 Hello, as already mentioned in topic USB C port doesn't work after upgrading to the latest kernel 6.6.2 . The previous problem with not working left usb 3 port persist no more. Everything is fine. As I remember , before update the usb c port has worked with the adapter and the devices like mouse, usb flash etc. Now it doesn't work any more, furthermore it gives no signal of life. There is 0 amps current measured, also dmesg -W gives no output at all after plugging in the device. PS: I was unable to upload the report file, also the service paste.armbian.com doesn't work at the moment. 0 Quote Link to comment Share on other sites More sharing options...
Igor Posted December 19, 2023 Share Posted December 19, 2023 6 hours ago, pinebookpro-owner said: PS: I was unable to upload the report file, also the service paste.armbian.com doesn't work at the moment. It works: https://status.armbian.com/ Perhaps some network related issue. 0 Quote Link to comment Share on other sites More sharing options...
pinebookpro-owner Posted December 20, 2023 Author Share Posted December 20, 2023 Some issue is, but I don't know. Just checked again. Still not working . With manual paste on paste.armbian.com by saving come pop out message "some went wrong". And output from terminal by issuing sudo armbianmonitor -u gives me following output: System diagnosis information will now be uploaded to https://paste.armbian.com/ https://paste.armbian.com/ https://paste.armbian.com/ https://paste.armbian.com/ https://paste.armbian.com/ https://paste.armbian.com/ https://paste.armbian.com/ Please post the URL in the forum where you've been asked for. As seen above there is no url with id. About the problem with usb port itself. I could not state anything general, it could be that is some hardware problem only at my side, I don't know therefore I asked. 0 Quote Link to comment Share on other sites More sharing options...
Werner Posted December 22, 2023 Share Posted December 22, 2023 Use armbianmonitor -U to dump to terminal, then c&p to a paste service of your choice like paste.debian.net or p.na4.eu Not sure whats wrong with armbian paste or if pbp has trouble. 0 Quote Link to comment Share on other sites More sharing options...
pinebookpro-owner Posted December 22, 2023 Author Share Posted December 22, 2023 Unfortunatelly it doesn't goes with pastebin services, some doesn't work some have small limits. I hope this workaround is acceptable too. Filesharing : https://file.io/ipqR5jRbhSF6 0 Quote Link to comment Share on other sites More sharing options...
pinebookpro-owner Posted March 1 Author Share Posted March 1 Hello, It is good news that is new armbian version here. But unfortunatelly my issue listed above was not resolved. Both problems persists. The usb c port still doesn't work and the initramfs issue is also not resolved: Quote run-parts: /etc/initramfs/post-update.d//99-uboot exited with return code 1 dpkg: error processing package initramfs-tools (--configure): installed initramfs-tools package post-installation script subprocess returned error exit status 1 Errors were encountered while processing: initramfs-tools E: Sub-process /usr/bin/dpkg returned an error code (1) Could you tell me is this error with usb c only on my comp or is it general, also for iniramfs? 0 Quote Link to comment Share on other sites More sharing options...
pinebookpro-owner Posted March 4 Author Share Posted March 4 With the latest update initramfs solved. USB C port , unfortunatelly still doesn't work. 0 Quote Link to comment Share on other sites More sharing options...
