eddievxx Posted January 14, 2017 Share Posted January 14, 2017 Hello, I have got my Orange Pi PC+ reading a DS18B20, but it only gives 0.5 degree increments so I believe the resolution is set to 9 bit. This is nowhere near good enough for the application I plan to use it for. When I cat w1_slave I get: 90 01 80 01 1f ff 02 04 5c : crc=5c YES 90 01 80 01 1f ff 02 04 5c t=25000 I have attempted to use this: https://github.com/danjperron/BitBangingDS18B20 but it appears to be specifically for RaspPi. Does anyone know how I can change the resolution to 11 or 12 bit? Many thanks Link to comment Share on other sites More sharing options...
martinayotte Posted January 14, 2017 Share Posted January 14, 2017 There is a thread where someone tweak the kernel to get this functionality : https://forum.armbian.com/index.php/topic/1558-w1-therm-driver-modifications/#entry12058 But it seem that he never completed the task to provide actual patch for Armbian build. Looking at kernel history, I saw that someone else done it a different way : https://github.com/megous/linux/commit/0a19f129d71f18e73249d54de96c835186b8607e It should be done like : echo 12 > /sys/bus/w1/devices/28-000005a2fac5/w1_slave But comments say that this change is volatile and will be reset at next power recycle : Writing a value between 9 and 12 to the sysfs w1_slave file will change the precision of the sensor for the next readings. This value is in (volatile) SRAM, so it is reset when the sensor gets power-cycled. To store the current precision configuration into EEPROM, the value 0 has to be written to the sysfs w1_slave file. Since the EEPROM has a limited amount of writes (>50k), this command should be used wisely. Link to comment Share on other sites More sharing options...
nedoskiv Posted March 8, 2017 Share Posted March 8, 2017 rc14_one:/sys/bus/w1/devices/28-0115832712ff/driver# echo 12 > 28-0115831d2eff/w1_slave -bash: 28-0115831d2eff/w1_slave: Permission denied setting manual write permission to w1_slave rc14_one:/sys/bus/w1/devices/28-0115832712ff/driver/28-0315826d08ff# echo 12 > w1_slave -bash: echo: write error: Input/output error I was using latest armbian debian jessie. How can I implement that to it? Link to comment Share on other sites More sharing options...
martinayotte Posted March 8, 2017 Share Posted March 8, 2017 Which kernel are you running ? My above post was for 4.9.x, and I've just verify that the same code is present on 4.10.x. Link to comment Share on other sites More sharing options...
borombo Posted March 10, 2017 Share Posted March 10, 2017 try: su -c "echo 12 > /sys/bus/w1/devices/28-0316a154bfff/w1_slave" Link to comment Share on other sites More sharing options...
nedoskiv Posted March 10, 2017 Share Posted March 10, 2017 oh I was on 3.4.113, gonna upgrade and test it, thank you Link to comment Share on other sites More sharing options...
