Hi everyone,
Very green here. Basically I setup 1 of my orange pi a few months back with "Armbian_23.02.3_Orangepizero2_jammy_legacy_4.9.318". I recently bought another pi and wanted to set it up with a newer version. I see bookworm is now the latest. I have tried both CLI and Minimal but whenever I flash those into my micro SD the orange pi never boots up.
My router doesnt see the connection, so it cant hand off an IP. I thought maybe it was a bad mini SD or a bad pi. But when I flashed the old jammy image into the same SD, the pi immediately picked up the connection, my router gave it an IP and I was able to log in as a root to the pi.
I read the documentation, and even saw the beginner videos to see that I wasnt doing something wrong. I had the SD connected before I powered on the PI, ensured I was the usb c for power. And that the SD has enough memory (8gb).
Does anyone have an idea of what could be happening here with the bookworm armbian?
moved to staging since unclear which board you actually have (topic and tag state "Zero", image name states "Zero 2" which are totally different boards).
Thanks Werner,
Wow I cant believe I downloaded the wrong model file. I will double check this from now own. After downloading armbian for for orange pi zero 2 I was able to set up my pi as intended.
Thanks, sorry for missing such a basic thing.
NAJ
