octal8 Posted January 6, 2024 Posted January 6, 2024 (edited) Installed: Armbian_23.11.1_Orangepi5-plus_bookworm_edge_6.7.0-rc1 The analog device is visible, but there's no sound from the headphone jack. The hdmi device is not visible. aplay -l **** List of PLAYBACK Hardware Devices **** card 0: Analog [Analog], device 0: fe470000.i2s-es8328-hifi-analog es8328-hifi-analog-0 [fe470000.i2s-es8328-hifi-analog es8328-hifi-analog-0] Subdevices: 1/1 Subdevice #0: subdevice #0 There is no sound when I play a test file: aplay -D hw:0,0 /usr/share/sounds/alsa/Noise.wav Playing WAVE '/usr/share/sounds/alsa/Noise.wav' : Signed 16 bit Little Endian, Rate 48000 Hz, Mono aplay: set_params:1358: Channels count non available I've looked in the journal log but nothing stands out to me. Sound doesn't appear to be muted, I added amixer output below. What do I do next? amixer output: Simple mixer control 'PCM',0 Capabilities: volume Playback channels: Front Left - Front Right Capture channels: Front Left - Front Right Limits: 0 - 192 Front Left: 192 [100%] [0.00dB] Front Right: 192 [100%] [0.00dB] Simple mixer control 'Mic PGA',0 Capabilities: volume Playback channels: Front Left - Front Right Capture channels: Front Left - Front Right Limits: 0 - 8 Front Left: 0 [0%] [0.00dB] Front Right: 0 [0%] [0.00dB] Simple mixer control 'Capture Digital',0 Capabilities: volume Playback channels: Front Left - Front Right Capture channels: Front Left - Front Right Limits: 0 - 192 Front Left: 0 [0%] [-96.00dB] Front Right: 0 [0%] [-96.00dB] Simple mixer control 'Capture Polarity',0 Capabilities: enum Items: 'Normal' 'L Invert' 'R Invert' 'L + R Invert' Item0: 'Normal' Simple mixer control 'Capture ZC',0 Capabilities: pswitch pswitch-joined Playback channels: Mono Mono: Playback [off] Simple mixer control 'DAC Deemphasis',0 Capabilities: pswitch pswitch-joined Playback channels: Mono Mono: Playback [off] Simple mixer control 'Differential Mux',0 Capabilities: enum Items: 'Line 1' 'Line 2' Item0: 'Line 1' Simple mixer control 'Left Line Mux',0 Capabilities: enum Items: 'Line 1' 'Line 2' 'PGA' 'Differential' Item0: 'Line 1' Simple mixer control 'Left Mixer',0 Capabilities: pswitch pswitch-joined Playback channels: Mono Mono: Playback [off] Simple mixer control 'Left Mixer Left Bypass',0 Capabilities: volume volume-joined pswitch pswitch-joined Playback channels: Mono Capture channels: Mono Limits: 0 - 7 Mono: 0 [0%] [-15.00dB] Playback [off] Simple mixer control 'Left Mixer Right',0 Capabilities: pswitch pswitch-joined Playback channels: Mono Mono: Playback [off] Simple mixer control 'Left Mixer Right Bypass',0 Capabilities: volume volume-joined pswitch pswitch-joined Playback channels: Mono Capture channels: Mono Limits: 0 - 7 Mono: 2 [29%] [-9.00dB] Playback [off] Simple mixer control 'Left PGA Mux',0 Capabilities: enum Items: 'Line 1' 'Line 2' 'Line 3' 'Differential' Item0: 'Line 1' Simple mixer control 'Output 1',0 Capabilities: pvolume Playback channels: Front Left - Front Right Limits: Playback 0 - 36 Mono: Front Left: Playback 0 [0%] [-30.00dB] Front Right: Playback 0 [0%] [-30.00dB] Simple mixer control 'Output 2',0 Capabilities: pvolume Playback channels: Front Left - Front Right Limits: Playback 0 - 36 Mono: Front Left: Playback 0 [0%] [-30.00dB] Front Right: Playback 0 [0%] [-30.00dB] Simple mixer control 'Right Line Mux',0 Capabilities: enum Items: 'Line 1' 'Line 2' 'PGA' 'Differential' Item0: 'Line 1' Simple mixer control 'Right Mixer',0 Capabilities: pswitch pswitch-joined Playback channels: Mono Mono: Playback [off] Simple mixer control 'Right Mixer Left',0 Capabilities: pswitch pswitch-joined Playback channels: Mono Mono: Playback [off] Simple mixer control 'Right Mixer Left Bypass',0 Capabilities: volume volume-joined pswitch pswitch-joined Playback channels: Mono Capture channels: Mono Limits: 0 - 7 Mono: 2 [29%] [-9.00dB] Playback [off] Simple mixer control 'Right Mixer Right Bypass',0 Capabilities: volume volume-joined pswitch pswitch-joined Playback channels: Mono Capture channels: Mono Limits: 0 - 7 Mono: 0 [0%] [-15.00dB] Playback [off] Simple mixer control 'Right PGA Mux',0 Capabilities: enum Items: 'Line 1' 'Line 2' 'Line 3' 'Differential' Item0: 'Line 1' Simple mixer control 'Route',0 Capabilities: enum Items: 'Stereo' 'Mono (Left)' 'Mono (Right)' 'Digital Mono' Item0: 'Stereo' Edited January 6, 2024 by octal8 Added amixer output 0 Quote
Joe Pfeiffer Posted January 24, 2024 Posted January 24, 2024 I'm also not seeing hdmi sound with this image: kodi@kodi:/dev/snd/by-path$ aplay -l **** List of PLAYBACK Hardware Devices **** card 0: Analog [Analog], device 0: fe470000.i2s-es8328-hifi-analog es8328-hifi-analog-0 [fe470000.i2s-es8328-hifi-analog es8328-hifi-analog-0] Subdevices: 1/1 Subdevice #0: subdevice #0 I haven't tried the headphone jack, so I can't speak to whether it's working. Currently downloading legacy so I can try that one. 0 Quote
NicoD Posted January 24, 2024 Posted January 24, 2024 That is a mainline (edge) image. Support for that isn't there yet. Use Vendor kernel if you want support. Mainline is a work in progress. 0 Quote
BOFFBOY Posted January 24, 2024 Posted January 24, 2024 any ideas on ETA with the fix ? thanks 0 Quote
Werner Posted January 24, 2024 Posted January 24, 2024 59 minutes ago, BOFFBOY said: any ideas on ETA with the fix ? thanks no 2 hours ago, NicoD said: Use Vendor kernel if you want support. 0 Quote
