Mr. Fennec Posted January 14, 2024 Posted January 14, 2024 Hi there, I am trying to build a voice assistant using OrangePiPc. This is not orangepi zero, but I am posting it here, because there is no subthread for orangepipc. OrangePiPc has an embedded microphone, but for some reason it doesn't work. When I run arecord, I get an input/output error. Any ideas? Here is a board description: http://www.orangepi.org/orangepiwiki/index.php/Orange_Pi_PC arecord -l card 0: Codec [H3 Audio Codec], device 0: CDC PCM Codec-0 [CDC PCM Codec-0] Subdevices: 1/1 Subdevice #0: subdevice #0 root@orangepipc:~# aplay -l **** List of PLAYBACK Hardware Devices **** card 0: Codec [H3 Audio Codec], device 0: CDC PCM Codec-0 [CDC PCM Codec-0] Subdevices: 1/1 Subdevice #0: subdevice #0 card 1: sun9ihdmi [sun9i-hdmi], device 0: SUN9I-HDMI PCM i2s-hifi-0 [SUN9I-HDMI PCM i2s-hifi-0] Subdevices: 1/1 Subdevice #0: subdevice #0 root@orangepipc:~# arecord -d 5 -f cd -t wav hello.wav Recording WAVE 'hello.wav' : Signed 16 bit Little Endian, Rate 44100 Hz, Stereoarecord: pcm_read:2221: read error: Input/output error root@orangepipc:~# cat /etc/issue Armbian 23.11.1 Bookworm \l root@orangepipc:~# uname -a Linux orangepipc 6.1.63-current-sunxi #1 SMP Mon Nov 20 10:52:19 UTC 2023 armv7l GNU/Linux 0 Quote
Gunjan Gupta Posted January 14, 2024 Posted January 14, 2024 Moved to community forums and relabeled to reflect the correct board. 0 Quote
SteeMan Posted January 14, 2024 Posted January 14, 2024 27 minutes ago, Mr. Fennec said: there is no subthread for orangepipc. That is because this board is not supported, and you were posting in the supported boards section of the forum. 1 Quote
