bschnei Posted February 5, 2024 Posted February 5, 2024 Hi all, I came upon a few threads in this forum while working on the bootloader for my ESPRESSObin Ultra. I noticed all of the warnings here about CPU frequency (https://www.armbian.com/espressobin/#), and I think this community might be interested in the work I'm doing. I've have an ESPRESSObin Ultra which ships from Globalscale with old, buggy, and unmaintained firmware. I think the old firmware could explain a lot of the issues users have reported here with the V7. I forked the old factory firmware build script from Globalscale and moved it all to up-to-date, upstream projects: https://github.com/bschnei/ebu-bootloader I believe with some small modifications, it is possible to also build an up-to-date bootloader for other Globalscale devices that also use the Armada 37XX SoC, for example the ESPRESSObin V7. I currently use Arch Linux ARM on my device and have notified their community as well: https://archlinuxarm.org/forum/viewtopic.php?f=67&t=16746 One of the issues I can confirm has been fixed is EFI booting from U-Boot. Fixing this means we can use U-Boot Standard Boot (bootflow scan) to load user-friendly EFI apps like systemd-boot, GRUB, etc. This significantly streamlines the boot process eliminating the need for u-boot to load separate kernel, initramfs, and device tree files. This also makes packaging it a lot easier too. It also means your bootloader becomes configurable from the OS which is really nice because it means your distro of choice can configure the bootloader instead of requiring users to configure U-Boot manually. I'm not familiar with Armbian, but I think it ships with systemd-boot (?) which has an EFI application that gives you a user friendly way to control device booting. GRUB has a similar capability. Please send me a note if you are interested in testing firmware for the ESPRESSObin V7 or Ultra. 1 Quote
Pali Posted February 6, 2024 Posted February 6, 2024 cc: @ManoftheSea @y52 you can be interested in this. 0 Quote
y52 Posted Friday at 09:43 PM Posted Friday at 09:43 PM Hi! Thanks for mentioning me. I've just noticed your message accidentally. It is indeed an interesting u-boot development. My both ESPRESSObin V5 and V7 are in production now. I can make some testing once I program their replacement. But no schedule has been fixed as yet pending acquiring a new board. 0 Quote
bschnei Posted Friday at 10:25 PM Author Posted Friday at 10:25 PM (edited) Hi @y52, I've been using the bootloader builds from my repo above on my ESPRESSObin Ultra for quite some time now. Not only do they have up-to-date U-boot, but frequency scaling works perfectly. I'm not very familiar with the V5 and V7 variants, but I think the V7 has the same CPU (possibly different memory). > hostnamectl Static hostname: espressobin-ultra Icon name: computer-embedded Chassis: embedded Machine ID: 2ba0ba22c6164c Boot ID: 514bc8387b7847 Operating System: Arch Linux Kernel: Linux 6.17.3-1-a3700 Architecture: arm64 Hardware Vendor: globalscale Hardware Model: Globalscale Marvell ESPRESSOBin Ultra Board Firmware Version: 2025.10-ge50b1e871501 Firmware Date: Wed 2025-10-01 Firmware Age: 1month Edited Friday at 10:26 PM by bschnei 0 Quote
y52 Posted Saturday at 05:53 PM Posted Saturday at 05:53 PM (edited) I believe you have managed to overcome the majour Espressobin culprits, i.e. frequency scaling resulting in instability. It was a deadlock for me in the kernel choice and uboot frequency build version. At some moment I was compelled flashing uboot with frequency downgraded to 1GHz and 800 MHz in order to get stable setup for production. Good catch! Your use of Arch Linux is also interesting. Which flavor have you installed ? Is it from https://archlinuxarm.org/platforms/armv8/marvell/espressobin ? I routinely out of curiosity try alternative builds for testing and comparison when making new setups despite that Armbian remains a preferred one so far with general score of usability. Edited Saturday at 06:09 PM by y52 0 Quote
y52 Posted Saturday at 08:56 PM Posted Saturday at 08:56 PM I've recently encountered when generating rsa keys low entropy available to OS on espressobin. You mention that "The hardware random number generator contained in the Cortex-M3 coprocessor was not available to the OS." It may explain the reason. Which entropy numbers do you reach now with the fixed u-boot ? 0 Quote
bschnei Posted Saturday at 09:35 PM Author Posted Saturday at 09:35 PM (edited) DVFS has been working well for me on two devices for over a year now. Linux accepted my patch to re-enable 1.2Ghz in 6.15. I build my own Arch packages, but I started with ALARM. I didn't like the way they packaged the kernel and it wasn't being maintained. There are a few of us working on bringing Arch to aarch64. You'll find us on IRC. Libera.chat #archlinux-ports The ALARM project is a completely independent project of Arch Linux (despite the confusing name). I have no issues with random number generation. It was actually fixed by this project: https://gitlab.nic.cz/turris/mox-boot-builder which builds one component of the bootloader. So I use that project (instead of Marvell) for that part of the bootloader. Edited Saturday at 09:36 PM by bschnei 0 Quote
y52 Posted yesterday at 09:35 AM Posted yesterday at 09:35 AM It sounds very promising for Espressobin usage and further kernels upgrades. It is yet to discover how could your u-boot port be built and which changes to code should be made for espressobin v5 and v7. I believe, they use the same chip. As you have a working build environment already, it would be worth sharing your pre-built binaries for testing in the 1st run. It could be a big step forward. Probably Armbian could offer them for downloads as well as alternatives in parallel with their own builds. 0 Quote
bschnei Posted 16 hours ago Author Posted 16 hours ago (edited) To build for other devices, you need to figure out the correct configuration and adjust these values accordingly: https://github.com/bschnei/ebu-bootloader/blob/main/Makefile#L15-L19 Reference for configuration options is here: https://trustedfirmware-a.readthedocs.io/en/latest/plat/marvell/armada/build.html So for V7 you probably want DDR_TOPOLOGY of 5 or 6 depending on RAM size; for V5 a value of 2. You'll have to look up your defconfig in u-boot. It's probably this one: https://github.com/u-boot/u-boot/blob/master/configs/mvebu_espressobin-88f3720_defconfig but note that I have added an ultra variant here: https://github.com/u-boot/u-boot/blob/master/configs/mvebu_espressobin_ultra-88f3720_defconfig which has settings required to provide HWRNG to the kernel at boot. So you may way want to start with the default if it is known to work and experiment with your own configuration file. You know how to test an image without flashing it to SPINOR, right? I have a guide at my repo above. Regarding Armbian and device support in general, there is another thread here where I had some back and forth a while back: Edited 16 hours ago by bschnei 0 Quote
