Hi all, I came upon a few threads in this forum while working on the bootloader for my ESPRESSObin Ultra. I noticed all of the warnings here about CPU frequency (https://www.armbian.com/espressobin/#), and I think this community might be interested in the work I'm doing.
I've have an ESPRESSObin Ultra which ships from Globalscale with old, buggy, and unmaintained firmware. I think the old firmware could explain a lot of the issues users have reported here with the V7. I forked the old factory firmware build script from Globalscale and moved it all to up-to-date, upstream projects: https://github.com/bschnei/ebu-bootloader
I believe with some small modifications, it is possible to also build an up-to-date bootloader for other Globalscale devices that also use the Armada 37XX SoC, for example the ESPRESSObin V7.
I currently use Arch Linux ARM on my device and have notified their community as well: https://archlinuxarm.org/forum/viewtopic.php?f=67&t=16746
One of the issues I can confirm has been fixed is EFI booting from U-Boot. Fixing this means we can use U-Boot Standard Boot (bootflow scan) to load user-friendly EFI apps like systemd-boot, GRUB, etc. This significantly streamlines the boot process eliminating the need for u-boot to load separate kernel, initramfs, and device tree files. This also makes packaging it a lot easier too.
It also means your bootloader becomes configurable from the OS which is really nice because it means your distro of choice can configure the bootloader instead of requiring users to configure U-Boot manually. I'm not familiar with Armbian, but I think it ships with systemd-boot (?) which has an EFI application that gives you a user friendly way to control device booting. GRUB has a similar capability.
Please send me a note if you are interested in testing firmware for the ESPRESSObin V7 or Ultra.
Hi! Thanks for mentioning me. I've just noticed your message accidentally.
It is indeed an interesting u-boot development. My both ESPRESSObin V5 and V7 are in production now. I can make some testing once I program their replacement. But no schedule has been fixed as yet pending acquiring a new board.
Posted (edited)
Hi @y52, I've been using the bootloader builds from my repo above on my ESPRESSObin Ultra for quite some time now. Not only do they have up-to-date U-boot, but frequency scaling works perfectly. I'm not very familiar with the V5 and V7 variants, but I think the V7 has the same CPU (possibly different memory).
> hostnamectl
 Static hostname: espressobin-ultra
       Icon name: computer-embedded
         Chassis: embedded
      Machine ID: 2ba0ba22c6164c
         Boot ID: 514bc8387b7847
Operating System: Arch Linux
          Kernel: Linux 6.17.3-1-a3700
    Architecture: arm64
 Hardware Vendor: globalscale
  Hardware Model: Globalscale Marvell ESPRESSOBin Ultra Board
Firmware Version: 2025.10-ge50b1e871501
   Firmware Date: Wed 2025-10-01
    Firmware Age: 1month
Edited by bschnei
Posted (edited)
I believe you have managed to overcome the majour Espressobin culprits, i.e. frequency scaling resulting in instability. It was a deadlock for me in the kernel choice and uboot frequency build version. At some moment I was compelled flashing uboot with frequency downgraded to 1GHz and 800 MHz in order to get stable setup for production. Good catch!
Your use of Arch Linux is also interesting. Which flavor have you installed ? Is it from
https://archlinuxarm.org/platforms/armv8/marvell/espressobin ?
I routinely out of curiosity try alternative builds for testing and comparison when making new setups despite that Armbian remains a preferred one so far with general score of usability.
Edited by y52
I've recently encountered when generating rsa keys low entropy available to OS on espressobin.
You mention that "The hardware random number generator contained in the Cortex-M3 coprocessor was not available to the OS."
It may explain the reason. Which entropy numbers do you reach now with the fixed u-boot ?
Posted (edited)
DVFS has been working well for me on two devices for over a year now. Linux accepted my patch to re-enable 1.2Ghz in 6.15.
I build my own Arch packages, but I started with ALARM. I didn't like the way they packaged the kernel and it wasn't being maintained. There are a few of us working on bringing Arch to aarch64. You'll find us on IRC. Libera.chat #archlinux-ports The ALARM project is a completely independent project of Arch Linux (despite the confusing name).
I have no issues with random number generation. It was actually fixed by this project: https://gitlab.nic.cz/turris/mox-boot-builder which builds one component of the bootloader. So I use that project (instead of Marvell) for that part of the bootloader.
Edited by bschnei
It sounds very promising for Espressobin usage and further kernels upgrades.
It is yet to discover how could your u-boot port be built and which changes to code should be made for espressobin v5 and v7. I believe, they use the same chip.
As you have a working build environment already, it would be worth sharing your pre-built binaries for testing in the 1st run. It could be a big step forward.
Probably Armbian could offer them for downloads as well as alternatives in parallel with their own builds.
Posted (edited)
To build for other devices, you need to figure out the correct configuration and adjust these values accordingly:
https://github.com/bschnei/ebu-bootloader/blob/main/Makefile#L15-L19
Reference for configuration options is here: https://trustedfirmware-a.readthedocs.io/en/latest/plat/marvell/armada/build.html
So for V7 you probably want DDR_TOPOLOGY of 5 or 6 depending on RAM size; for V5 a value of 2. You'll have to look up your defconfig in u-boot. It's probably this one: https://github.com/u-boot/u-boot/blob/master/configs/mvebu_espressobin-88f3720_defconfig but note that I have added an ultra variant here: https://github.com/u-boot/u-boot/blob/master/configs/mvebu_espressobin_ultra-88f3720_defconfig which has settings required to provide HWRNG to the kernel at boot. So you may way want to start with the default if it is known to work and experiment with your own configuration file.
You know how to test an image without flashing it to SPINOR, right? I have a guide at my repo above.
Regarding Armbian and device support in general, there is another thread here where I had some back and forth a while back:
Edited by bschnei
Hi @bschnei - i'm late to the party, tried using the standard instructions from GTI... Thanks for putting all this together!  I'm running into an issue building the A3700, with an error about relocation.
   dangerous relocation: unsupported relocation
Could be related to having LSB set to 1 for safely identifying the relocation target?... based on searches  Any hints what I'm missing?
Built /srv/development/espressobin-ultra/2026-03-bschnei/ebu-bootloader/trusted-firmware-a/build/a3700/release/boot-image.bin successfully
make -C wtmi LOCAL_VERSION_STRING=-devel-18.12.1
cp -f ../../mox-boot-builder/wtmi_app.bin build/wtmi_app_pad.bin
truncate -s %16 build/wtmi_app_pad.bin
make -C sys_init LOAD_OFFSET=15360 COMMON_PATH=/srv/development/espressobin-ultra/2026-03-bschnei/ebu-bootloader/A3700-utils-marvell/wtmi/common CROSS_CM3=arm-linux-gnueabi-
  CHK     autoconf.h
  UPD     autoconf.h
  AS    start.S
  CC    apctl.c
  CC    avs.c
  CC    clock.c
  CC    main.c
  CC    printf.c
  CC    uart.c
  CC    ddr/ddr.c
  CC    ddr/ddrcore.c
  CC    ddr/ddr_support.c
  CC    ddr/dll_tuning.c
  CC    ddr/new_qs_gating.c
  CC    ddr/vref_training.c
  CC    /srv/development/espressobin-ultra/2026-03-bschnei/ebu-bootloader/A3700-utils-marvell/wtmi/common/delay.c
  CC    -nostdlib -T sys_init.ld -Xlinker --build-id=none  start.o  apctl.o avs.o clock.o main.o printf.o uart.o ddr/ddr.o ddr/ddrcore.o ddr/ddr_support.o ddr/dll_tuning.o ddr/new_qs_gating.o ddr/vref_training.o /srv/development/espressobin-ultra/2026-03-bschnei/ebu-bootloader/A3700-utils-marvell/wtmi/common/delay.o -o build/sys_init.elf
/usr/lib/gcc-cross/arm-linux-gnueabi/14/../../../../arm-linux-gnueabi/bin/ld: warning: build/sys_init.elf has a LOAD segment with RWX permissions
/usr/lib/gcc-cross/arm-linux-gnueabi/14/../../../../arm-linux-gnueabi/bin/ld: (*ABS*0x1fff0000): Unknown destination type (ARM/Thumb) in main.o
main.o: in function `main':
/srv/development/espressobin-ultra/2026-03-bschnei/ebu-bootloader/A3700-utils-marvell/wtmi/sys_init/main.c:349:(.text.startup+0x38): dangerous relocation: unsupported relocation
collect2: error: ld returned 1 exit status
make[4]: *** [Makefile:149: build/sys_init.elf] Error 1
make[3]: *** [Makefile:42: sys_init/build/sys_init.bin] Error 2
make[2]: *** [Makefile:36: WTMI] Error 2
make[1]: *** [plat/marvell/armada/a3k/common/a3700_common.mk:158: /srv/development/espressobin-ultra/2026-03-bschnei/ebu-bootloader/./A3700-utils-marvell/wtmi/build/wtmi.bin] Error 2
make[1]: Leaving directory '/srv/development/espressobin-ultra/2026-03-bschnei/ebu-bootloader/trusted-firmware-a'
make: *** [Makefile:28: /srv/development/espressobin-ultra/2026-03-bschnei/ebu-bootloader/./trusted-firmware-a/build/a3700/release/flash-image.bin] Error 2
Hi @KV1 looks like you are hitting this issue: https://github.com/MarvellEmbeddedProcessors/A3700-utils-marvell/issues/35
As you can see, Marvell is not very active in these repos. So you have two choices: 1) use older binutils/gcc (probably the easiest option), or 2) fix the issue with the source code. The fixes I'm seeing look simple enough to implement, and I will likely need to include them in the future when/if I update the github runners used to build releases.
See also:
https://community.arm.com/support-forums/f/compilers-and-libraries-forum/57077/binutils-2-44-and-gcc-15-1-0---dangerous-relocation-unsupported-relocation-error-when-trying-to-build-u-boot
https://lists.denx.de/pipermail/u-boot/2025-May/589102.html
Thanks @bschnei.  I tried for a while to  figure out what to do, but couldn't really understand.. not sure if i should be trying to set it to thumb or arm mode at that point, even.  I did fallback to earlier binutils, and the build went fine.
However, trying to boot from the flash-image.bin with mox-imager results in incomplete load and reset back to mmc/spinor ... any ideas?
/mox-imager/mox-imager -D /dev/ttyUSB0  -t -E  /srv/development/espressobin-ultra/2026-03-bschnei/built-on-old-bb/flash-image-20260401-bb.bin
TIM version 3.6.00, issue date 2026-04-01, non-trusted, 3 images, 0 keys, boot flash sign SPI NOR
Reserved area packages:
  CRV2 (size 20)
  CIDP (size 32)
    Consumer TBRI, packages: GPP1 GPP2 DDR3
  GPP1 (size 852)
    Ignore timeouts in instructions: 0
  GPP2 (size 456)
  DDR3 (size 2024)
    Initialize DDR memory: 1
  Term (size 8)
Found TIMH, hash sha-256, encryption none, size 3780, load 0x20006000, flash 0x00000000
Found WTMI, hash sha-256, encryption none, size 24336, load 0x1fff0000, flash 0x00004000
Found OBMI, hash sha-256, encryption none, size 1140712, load 0x64100000, flash 0x00015000
Going to send images to the device
Sending escape sequence, please power up the device
Received sync reply
Sending escape sequence with delay
Detected BootROM command prompt
Sending wtp sequence
Received ack reply
Sending clearbuf sequence
Initialized UART download mode
GetVersion response: version 3.4.01, date 2016-05-15, CPU ARMA
Sending image type TIMH
100% sent in 00:00
TIM-1.0
mv_ddr-devel-g7bcb9dc DDR4 16b 1GB 1CS
Sending image type WTMI
100% sent in 00:02
Sending image type OBMI
100% sent in 01:40
[Type Ctrl-\ + c to quit]
WTMI-devel-18.12.1-a3e1c67
WTMI: system early-init
SVC REV: 5, CPU VDD voltage: 1.213V
Setting clocks: CPU 1200 MHz, DDR 750 MHz
CZ.NIC's Armada 3720 Secure Firmware v2024.04.15-6-gd6d9646 (Apr  1 2026 16:32:36)
Running on ESPRESSObin Ultra
NOTICE:  Booting Trusted Firmware
NOTICE:  BL1: v2.14.0(release):sandbox/v2.14-774-g8dae0862c
NOTICE:  BL1: Built : 16:32:41, Apr  1 2026
NOTICE:  BL1: Booting BL2
NOTICE:  BL2: v2.14.0(release):sandbox/v2.14-774-g8dae0862c
NOTICE:  BL2: Built : 16:32:51, Apr  1 2026
NOTICE:  BL1: Booting BL31
NOTICE:  BL31: v2.14.0(release):sandbox/v2.14-774-g8dae0862c
NOTICE:  BL31: Built : 16:32:56, Apr  1 2026
U-Boot 2026.04-rc5-00019-gc704af3c8b0f (Apr 01 2026 - 17:08:14 -0400)
DRAM:  1 GiB
"Synchronous Abort" handler, esr 0x96000044, far 0xd5380000aa1e03fd
elr: 0000000000036a08 lr : 0000000000036a64 (reloc)
elr: 000000003ff4aa08 lr : 000000003ff4aa64
x0 : 0000000000000098 x1 : d5380000aa1e03fd
x2 : 0000000000000000 x3 : 000000003fb07b00
x4 : 0000000000000000 x5 : 0000000000000000
x6 : 0000000000000000 x7 : 000000003fb07b20
x8 : 000000003faff64c x9 : 000000003fb00034
x10: 0000000000000000 x11: 0000000000000600
x12: 000000003faff70c x13: 000000003faff9b0
x14: 000000003faff9b0 x15: 0000000000000000
x16: 0000000000000000 x17: 0000000000000000
x18: 000000003fb03e10 x19: 0000000000000000
x20: 000000003fb07780 x21: 000000003fb077a0
x22: 0000000000000000 x23: 0000000000000000
x24: 0000000000000000 x25: 0000000000000000
x26: 0000000000000000 x27: 0000000000000000
x28: 0000000000000000 x29: 000000003faff7a0
Code: f9405261 f9005274 f81e02a0 f9000681 (f9000034)
Resetting CPU ...
resetting ...
TIM-1.0
WTMI-devel-18.12.1-1a13f2f
NOTICE:  BL1: v1.5(release):e65dc63 (Marvell-devel-18.12.2)
NOTICE:  BL1: Built : 22:43:22, Mar  4 2026
NOTICE:  BL2: v1.5(release):e65dc63 (Marvell-devel-18.12.2)
NOTICE:  BL2: Built : 22:43:25, Mar  4 2026
NOTICE:  BL31: v1.5(release):e65dc63 (Marvell-devel-18.12.2)
NOTICE:  BL31: Built : 22
U-Boot 2020.10-6.0.0-g29a6ea5c-dirty (Mar 28 2026 - 21:49:54 -0400)
Model: gti cellular cpe board
DRAM:  1 GiB
Comphy chip #0:
Comphy-0: USB3_HOST0
Comphy-1: PEX0          2.5 Gbps
Comphy-2: SATA0         6 Gbps
Target spinup took 0 ms.
AHCI 0001.0300 32 slots 1 ports 6 Gbps 0x1 impl SATA mode
flags: ncq led only pmp fbss pio slum part sxs
PCIE-0: Link up
MMC:   sdhci@d8000: 0
Loading Environment from SPIFlash... unrecognized JEDEC id bytes: 61, 12, 9b
*** Warning - spi_flash_probe_bus_cs() failed, using default environment
Net:
Error: neta@30000 address not set.
mdio_register: non unique device name 'neta@30000'
No ethernet found.
starting USB...
Bus usb@58000: Register 2000104 NbrPorts 2
Starting the controller
USB XHCI 1.00
Bus usb@5e000: USB EHCI 1.00
scanning bus usb@58000 for devices... 1 USB Device(s) found
scanning bus usb@5e000 for devices... 2 USB Device(s) found
Hit any key to stop autoboot:  0
Marvell>>
@KV1 nice work! Looks like it made it to U-Boot before it died. Instead of building your own, have you tried to see if it boots using a release image built with a github runner here: https://github.com/bschnei/ebu-bootloader/releases/tag/2026.02.24. Even if you want to eventually build it yourself, you could just test to see if the image built at github works. If it does, and you know the source code is the same (it looks like you are building an -rc of U-Boot) then you can narrow it down to the compiler tools you are using. Just to confirm: this is for an EspressoBIN Ultra right? Not the V7/V5 or some other variant?
Posted (edited)
Thanks @bschnei!  Yes, using the prebuilt image from your release worked -- the base mmc installation boots fine.
And i do have the Espressobin-Ultra model.
I still end up stuck in the Armbian (from SATA) build at:
[    1.580359] PM: genpd: Disabling unused power domains
[    1.585946] Waiting for root device /dev/sda1...
[    1.606664] usb 1-1: New USB device found, idVendor=1a40, idProduct=0101, bcdDevice= 1.11
[    1.614861] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[    1.621998] usb 1-1: Product: USB 2.0 Hub
[    1.626711] hub 1-1:1.0: USB hub found
[    1.630668] hub 1-1:1.0: 4 ports detected
[   11.622348] platform d0070000.pcie: deferred probe pending: platform: wait for supplier /soc/internal-regs@d0000000/phy@18300/phy@1
[   11.634188] platform d00e0000.sata: deferred probe pending: platform: wait for supplier /soc/internal-regs@d0000000/phy@18300/phy@2
[   11.645998] platform d0058000.usb: deferred probe pending: platform: wait for supplier /soc/internal-regs@d0000000/phy@18300/phy@0
However, putting it together, i'm guessing this is back to your mention of needing 6.15 or later kernel.  Which Debian/Armbian hasn't folded in yet?
I'll have to look into whether i can fork the Armbian, back-port the kernel patch.  The fact that my build environment ended up with the initial issue makes me wonder if that's going to run into similar issues though.
Either way, really appreciate all the work you've done in this space, and the help you're providing!
Edited by KV1
Added model.
@KV1 I'm happy I'm able to help. I got a lot of help originally from @Pali and by the time we sorted out that the bootloader was the problem it seems that people have largely given up on these devices. It is a shame because they are actually quite good routers (except the wifi). You are actually the first person with an Ultra to reach out.
OK, that's looking good. It means the bootloader image works for you and you should be safe to flash it if you want. The messages you posted above are indeed kernel output. To be clear, you don't have to have a more recent kernel to get the device to boot, but DVFS (frequency scaling) may not work without the patch to enable 1.2Ghz clock speed. If you run a kernel without that patch, everything will still work it will just run at full speed all the time which isn't very energy efficient.
You are now at the stage where you have to consider how Armbian configures and packages the kernel for this device and ensure that your U-Boot configuration is using a supported boot flow. For example, U-Boot can support loading the kernel as an UEFI image directly (EFISTUB) among many other variations. The messages you posted above suggest that the device tree that is getting loaded may be incorrect/old and I would probably start by examining that.
I don't know much about Armbian, but @Igor may also be able to point you in the right direction. Feel free to post your u-boot configuration here too as that could provide some insight into the boot process being used.
Posted (edited)
OK, I'm getting somewhere, I think -- with your help.  I went ahead and flashed the image, which took fine:
TIM-1.0
mv_ddr-devel-g4a3dc09 DDR4 16b 1GB 1CS
CZ.NIC's Armada 3720 Secure Firmware 14f39dd (Feb 24 2026 19:59:06)
NOTICE:  BL1: v2.14.0(release):1d5aa93
NOTICE:  BL1: Built : 19:59:08, Feb 24 2026
NOTICE:  BL2: v2.14.0(release):1d5aa93
NOTICE:  BL2: Built : 19:59:11, Feb 24 2026
NOTICE:  BL31: v2.14.0(release):1d5aa93
NOTICE:  BL31: Built : 19:59:12, Feb 24 2026
U-Boot 2026.01-g127a42c7257a (Feb 24 2026 - 19:57:59 +0000)
DRAM:  1 GiB
Core:  59 devices, 27 uclasses, devicetree: separate
WDT:   Not starting watchdog@8300
Comphy chip #0:
Comphy-0: USB3_HOST0    5 Gbps
Comphy-1: PEX0          5 Gbps
PCIe: Link up
MMC:   mmc@d8000: 0
Loading Environment from SPIFlash... SF: Detected mx25u3235f with page size 256 Bytes, erase size 4 KiB, total 4 MiB
OK
MMC Device 1 not found
Net:   eth0: ethernet@30000 [PRIME]
My attempt to target the drive for boot was using scsi via so:
=> scsi scan
scanning bus for devices...
  Device 0: (0:0) Vendor: ATA Prod.: ORICO Rev: Y090
            Type: Hard Disk
            Capacity: 976762.3 MB = 953.8 GB (2000409265 x 512)
=> setenv scsi_fdt_name "/boot/dtb/marvell/armada-3720-espressobin-ultra.dtb"
=> setenv scsiboot "scsi dev 0; ext4load scsi 0:1 $kernel_addr_r $image_name;ext4load scsi 0:1 $fdt_addr_r $scsi_fdt_name;setenv bootargs $console root=/dev/sda1 rw rootwait net.ifn"
=> scsi info
            Type: Hard Disk
=> run scsiboot
            Type: Hard Disk
... is now current device
36991488 bytes read in 580 ms (60.8 MiB/s)
13472 bytes read in 6 ms (2.1 MiB/s)
## Flattened Device Tree blob at 06f00000
   Booting using the fdt blob at 0x6f00000
Working FDT set to 6f00000
   Using Device Tree in place at 0000000006f00000, end 0000000006f0649f
Starting kernel ...
[    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
[    0.000000] Linux version 6.12.68-current-mvebu64 (build@armbian) (aarch64-linux-gnu-gcc (Ubuntu 13.3.0-6ubuntu2~24.04) 13.3.0, GNU ld (GNU Binutils for Ubuntu) 2.42) #5 SMP PREE6
[    0.000000] KASLR enabled
Trying again to load from the SATA M/B-key drive, via SCSI, perhaps I'm confusing myself or the SATA is not properly initializing?  It looks as if we get pretty far -- if i leave the USB drive plugged in.. but i'm assuming that is taking /dev/sda1, which is why we're not finding a rootfs... but i'm obviously missing how to engage and/or reference the SATA drive, then?
[    3.098515] usb-storage 1-1.1:1.0: USB Mass Storage device detected
[    3.105468] scsi host0: usb-storage 1-1.1:1.0
[    4.132658] scsi 0:0:0:0: Direct-Access     Generic- SD/MMC           1.00 PQ: 0 ANSI: 0 CCS
[    4.484329] sd 0:0:0:0: [sda] 3907584 512-byte logical blocks: (2.00 GB/1.86 GiB)
[    4.492568] sd 0:0:0:0: [sda] Write Protect is off
[    4.498058] sd 0:0:0:0: [sda] No Caching mode page found
[    4.503387] sd 0:0:0:0: [sda] Assuming drive cache: write through
[    4.532225]  sda: sda1
[    4.535092] sd 0:0:0:0: [sda] Attached SCSI removable disk
[    4.549528] FAT-fs (sda1): IO charset iso8859-1 not found
[    4.564748] FAT-fs (sda1): IO charset iso8859-1 not found
[    4.572867] List of all partitions:
[    4.576509] 0100           48000 ram0
[    4.576522]  (driver?)
[    4.582715] 1f00            3968 mtdblock0
[    4.582724]  (driver?)
[    4.589256] 1f01              64 mtdblock1
[    4.589262]  (driver?)
[    4.595906] 1f02              64 mtdblock2
[    4.595912]  (driver?)
[    4.602444] b300         7636800 mmcblk0
[    4.602450]  driver: mmcblk
[    4.609231]   b301         7635776 mmcblk0p1 89708921-01
[    4.609238]
[    4.616022] b308            4096 mmcblk0boot0
[    4.616027]  (driver?)
[    4.622811] b310            4096 mmcblk0boot1
[    4.622817]  (driver?)
[    4.629596] 0800         1953792 sda
[    4.629602]  driver: sd
[    4.635695]   0801         1953761 sda1 169d3094-01
[    4.635701]
[    4.642048] No filesystem could mount root, tried:
[    4.642051]  ext3
[    4.646922]  ext4
[    4.648837]  ext2
[    4.650757]  vfat
[    4.652672]  xfs
[    4.654592]
[    4.657900] Kernel panic - not syncing: VFS: Unable to mount root fs on "/dev/sda1" or unknown-block(8,1)
Pulling the DTB from the drive,  and decompiling, i do see SATA references:
dtc -I dtb -O dts armada-3720-espressobin-ultra.dtb > armada-3720-espressobin-ultra.dts
            phy@18300 {
                compatible = "marvell,comphy-a3700";
                reg = <0x18300 0x300 0x1f000 0x400 0x5c000 0x400 0xe0178 0x08>;
                reg-names = "comphy", "lane1_pcie_gbe", "lane0_usb3_gbe", "lane2_sata_usb3";
                #address-cells = <0x01>;
                #size-cells = <0x00>;
                clocks = <0x04>;
                clock-names = "xtal";
            sata@e0000 {
                compatible = "marvell,armada-3700-ahci";
                reg = <0xe0000 0x178>;
                interrupts = <0x00 0x1b 0x04>;
                clocks = <0x02 0x01>;
                phys = <0x1e 0x00>;
                phy-names = "sata-phy";
                status = "okay";
But i don't know enough to know why it's not initializing.  the 2GB SDA above is clearly the USB drive.
Edited by KV1
Updated to add devicetree info
@KV1 nice! So I think the kernel is saying it can "see" /dev/sda1 but that whatever filesystem you've got on that partition it does not recognize and could not mount after trying fat, ext4, and xfs. Are you sure /dev/sda1 has been formatted/imaged correctly? That looks like it's a USB thumb drive, right? If so, I would plug it into another working host and check that it is properly formatted and does indeed contain the intended root file system you'd like to boot.
Where is /boot? /dev/mmcblk0p1?
Sorry if i wasn't clear - that's two separate boot profiles... one with a USB drive plugged in, but just left it in after `bubt'ing.  The real drive I'm trying to boot from is the SATA nVME 2280 (M+B Key).  Once i take the USB drive out, no SDA devices are identified by the kernel.
The 6.12.x kernel is on the 2280 drive (SATA/SCSI)... basically `uboot' is able to ext4load the kernel, but once the kernel drops in, it must not be initializing scsi/SATA support, only USB support.  Thus, it can't find rootfs, because it hasn't initialized it... but i'm not sure why it hasn't initialized support.
All the discussions / AI results suggest it's either a power issue -- which doesn't make sense if it *booted* from the drive itself already?! -- or a device tree issue.  I don't know enough about device trees to know, but the above snippet looked like it had support.
I reflashed/updated the NVMe via armbian-imager -- looks like a monthly release update, but no change.
Are you booting from the emmc or USB then? You're not using the internal SATA/NVMe 2280 connector for boot?
Presumably i COULD put root/boot fs on the emmc, but i like to have the fallback option if something goes wrong.
This is what i did with my old one -- a DreamPlug, where i just have an SD Card drive everything. If i screw something up, I just take the SD Card out, and it boots off the good-but-old emmc.
Oh I see now. I've had problems using root=/dev/sdX. I would try to use UUIDs which you should be able to query with blkid.
But I doubt that is going to fix the above. I suspect the drivers needed to boot from NVME are probably not being loaded. That could mean they are not being compiled (either built in or as modules) OR  if built as modules  they are not being included in your initramfs. Actually...I don't see that you are loading an initramfs. Again, I'm not familiar with armbian but many distros rely on an initramfs to provide needed drivers for early userspace.
I have one device with a NVME and one without. Booting from either MMC or NVME does work with the right config/initramfs.
I would include your full u-boot config and all kernel boot messages. You can attach them instead of putting in the body of the post. There may be other subtle/cryptic warnings that indicate a driver is missing.
Posted (edited)
@bschnei - Yep.. it was modules, via uInitrd.  Sadly the legacy config says the kernel bootarg param is 'initrd', so that lost me a good chunk of my life i'll never get back.  using RAMDISK_START as the boot arg helped.  This did, indeed, load the sata modules, which raised the disk.
[EDIT: lol. RAMDISK_START apparently isn't even relevant?
grep 'Unknown kernel command line parameters' *.log
EspressoBin_Ultra-Bootlog.2026-04-03_001.log:[    0.000000] Unknown kernel command line parameters "RAMDISK_START=0xa00000 biosdevname=0", will be passed to user space.
EspressoBin_Ultra-Bootlog.2026-04-03_003.log:[    0.000000] Unknown kernel command line parameters "RAMDISK_START=0xa00000 biosdevname=0", will be passed to user space.
EspressoBin_Ultra-Bootlog.2026-04-03_004.log:[    0.000000] Unknown kernel command line parameters "RAMDISK_START=0xa00000 biosdevname=0", will be passed to user space.
Not sure why it's working now...
In case this might help someone later, here's the uboot init config I used for the EspressoBin-Ultra to boot from NVMe / SATA / sda1 / SCSI:
=> setenv scsi_rootfs "UUID=8045e72d-9d9e-465c-a9ee-95cad5513ec8"
=> setenv scsi_boot_init 'scsi scan; scsi dev 0'
=> setenv scsi_kernel_addr_r '0x7000000'
=> setenv scsi_kernel_name '/boot/Image'
=> setenv scsi_kernel_load "ext4load scsi 0:1 $scsi_kernel_addr_r $scsi_kernel_name"
=> setenv scsi_initrd_name '/boot/uInitrd'
=> setenv scsi_initrd_addr 0xa00000
=> setenv scsi_initrd_load "ext4load scsi 0:1 $scsi_initrd_addr $scsi_initrd_name"
=> setenv scsi_fdt_name '/boot/dtb/marvell/armada-3720-espressobin-ultra.dtb'
=> setenv scsi_fdt_addr_r '0x6f00000'
=> setenv scsi_fdt_load "ext4load scsi 0:1 $fdt_addr_r $scsi_fdt_name"
=> setenv scsi_setbootargs "setenv bootargs $console root=$scsi_rootfs rw rootwait RAMDISK_START=$scsi_initrd_addr net.ifnames=0 biosdevname=0"
=> setenv scsi_booti "booti $kernel_addr_r $scsi_initrd_addr $fdt_addr_r"
=> setenv scsi_boot "$scsi_boot_init; $scsi_kernel_load; $scsi_initrd_load; $scsi_fdt_load; $scsi_setbootargs; $scsi_booti"
=> printenv scsi_boot
scsi_boot=scsi scan; scsi dev 0; ext4load scsi 0:1 0x7000000 /boot/Image; ext4load scsi 0:1 0xa00000 /boot/uInitrd;  ext4load scsi 0:1 0x6f00000 /boot/dtb/marvell/armada-3720-espressobin-ultra.dtb; setenv bootargs  console=ttyMV0,115200 earlycon=ar3700_uart,0xd0012000 root=UUID=8045e72d-9d9e-465c-a9ee-95cad5513ec8 rw rootwait RAMDISK_START=0xa00000 net.ifnames=0 biosdevname=0; booti 0x7000000 0xa00000
0x6f00000
=> run scsi_boot
And there we go:
[    3.783163] ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[    3.790704] ata1.00: ATA-11: ORICO, Y0908A0, max UDMA/133
[    3.796101] ata1.00: 2000409264 sectors, multi 1: LBA48 NCQ (depth 32)
[    3.824725] ata1.00: configured for UDMA/133
[    3.829607] scsi 0:0:0:0: Direct-Access     ATA      ORICO            8A0  PQ: 0 ANSI: 5
[    3.839402] sd 0:0:0:0: [sda] 2000409264 512-byte logical blocks: (1.02 TB/954 GiB)
[    3.847435] sd 0:0:0:0: [sda] Write Protect is off
[    3.852470] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[    3.861614] sd 0:0:0:0: [sda] Preferred minimum I/O size 512 bytes
[    3.883685]  sda: sda1
[    3.886538] sd 0:0:0:0: [sda] Attached SCSI disk
Sadly, the kernel is still panicing, during load.... which is basically where I started way back when using 2018 uboot version....  below is the summary, but attached are various boot logs.  _001 and _004 are probably the only useful ones though.
[    6.518199] systemd[1]: Starting keyboard-setup.service - Set the console keyboard layout...
[    6.537048] SError Interrupt on CPU0, code 0x00000000bf000001 -- SError
[    6.537084] CPU: 0 UID: 0 PID: 171 Comm: 9 Tainted: G   M               6.12.68-current-mvebu64 #5
[    6.537096] Tainted: [M]=MACHINE_CHECK
[    6.537099] Hardware name: Globalscale Marvell ESPRESSOBin Ultra Board (DT)
[    6.537104] pstate: 20000000 (nzCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[    6.537111] pc : 0000ffff9bb2be30
[    6.537114] lr : 0000ffff9bb2d268
[    6.537117] sp : 0000ffffea848f80
[    6.537119] x29: 0000ffffea848f80 x28: 0000ffff9bb51540 x27: 0000ffff9a95b8c8
[    6.537134] x26: 0000ffff9a880000 x25: 0000ffff9bb5eb70 x24: 0000000000000000
[    6.537144] x23: 0000000000000000 x22: 0000000000000000 x21: 0000ffff9a9771e0
[    6.537154] x20: 0000ffff9bb51540 x19: 0000000000000000 x18: 0000000000000fff
[    6.537163] x17: 0000000000000000 x16: 00000000ffffffff x15: 00000000000a6de8
[    6.537173] x14: 0000000000000000 x13: 0000ffffea849080 x12: 0000ffff9bb4e000
[    6.537183] x11: 0000000000000000 x10: 0000000000000000 x9 : 0000ffff9a88ae50
[    6.537192] x8 : 000000000001169a x7 : 0000ffff9a9771e0 x6 : 0000ffff9bb5e000
[    6.537202] x5 : 0000ffffea849080 x4 : 0000000000000000 x3 : 0000000000000000
[    6.537211] x2 : 0000000000601588 x1 : 0000ffff9ae62860 x0 : 0000ffff9a95a8c0
[    6.537223] Kernel panic - not syncing: Asynchronous SError Interrupt
[    6.537228] CPU: 0 UID: 0 PID: 171 Comm: 9 Tainted: G   M               6.12.68-current-mvebu64 #5
[    6.537236] Tainted: [M]=MACHINE_CHECK
[    6.537239] Hardware name: Globalscale Marvell ESPRESSOBin Ultra Board (DT)
[    6.537243] Call trace:
[    6.537248]  dump_backtrace+0x98/0xf8
[    6.537265]  show_stack+0x20/0x38
[    6.537272]  dump_stack_lvl+0x34/0x90
[    6.537283]  dump_stack+0x18/0x28
[    6.537290]  panic+0x3a8/0x410
[    6.537299]  nmi_panic+0x48/0xa0
[    6.537306]  arm64_serror_panic+0x78/0x90
[    6.537313]  do_serror+0x44/0x80
[    6.537320]  __el0_error_handler_common+0x3c/0xa0
[    6.537330]  el0t_64_error_handler+0x10/0x20
[    6.537340]  el0t_64_error+0x190/0x198
[    6.537350] SMP: stopping secondary CPUs
[    6.537373] Kernel Offset: 0x237629600000 from 0xffff800080000000
[    6.537377] PHYS_OFFSET: 0xffffacdfc0000000
[    6.537380] CPU features: 0x00,00000090,00200000,4200421b
[    6.537386] Memory Limit: none
[    6.742429] ---[ end Kernel panic - not syncing: Asynchronous SError Interrupt ]---
EspressoBin_Ultra-Bootlog.2026-04-03_001.log EspressoBin_Ultra-Bootlog.2026-04-03_002.log EspressoBin_Ultra-Bootlog.2026-04-03_003.log EspressoBin_Ultra-Bootlog.2026-04-03_004.log
Edited by KV1
RAMDISK_START doesn't seem relevant.
Hmm that doesn't look great. It looks like it is crashing at random places vs the same place every time. It makes you wonder if you have a true hardware problem (e.g. bad memory). Can you never make it to a login prompt?
I would double check all your memory locations for the FDT, ramfs and kernel to make sure you aren't accidentally overlapping anywhere. And yes, I would avoid starting anything at 0. I actually found a kernel bug from doing that.
You could also consider trying to load the kernel as an EFISTUB directly. I don't know if that's supported by armbian or not, but you could experiment.
You do know you can save u-boot variables to the SPINOR storage so you don't have to type them in every time, right? :)
Haha - yes, I did eventually `saveenv'... just being super-cautious, and not sure what was going to work, given all the Kernel Panics.  Also, in case some other poor guy comes by later and looks for some examples...
If i boot the stock kernel/OS from eMMC, it loads (most of the time) and runs fine.  I've had a few kernel panics, but usually it loads.  If i boot fresh to the eMMC, it also seems to do better.  There are some statements around the web that indicate uBoot might be 'hiding' errors prior to the booti, which causes people (like me) to tear their hair out looking in the wrong place -- i.e., register data is already bad before control is even transferred to the kernel.
I did pull down armbian build and build out the latest kernel - 6.18, to see if that might make a difference, but no luck. If anything it caused more issues.
I WAS able to get all the way booted up into Armbian one time -- adding the pcie power config switches (I thought), and it was stable for a while -- until i tried to `apt update', at which point it locked up.  Haven't been able to get all the way up again.
My current guesses to look into are:
1. make sure i'm not, as you said, overwriting myself during booti
2. continue to look for kernel config  / versions that have better luck with SATA + mvebu64/power config.
I'm guessing since I can boot the pre-installed OS that my hardware is actually OK.
If you could provide your relevant ext4load (or similar) that you're using for SATA load, i'd appreciate it.
I do get these bad rx status issues, and the networking isn't really coming up on the stock.
Base install:
[   11.352864] mvneta d0030000.ethernet eth0: bad rx status 0cc10000 (crc error), size=75
[   13.352762] mvneta d0030000.ethernet eth0: bad rx status 0cc10000 (crc error), size=75
root@ccpe10c1a5:~# cat /proc/cmdline
console=ttyMV0,115200 earlycon=ar3700_uart,0xd0012000 root=/dev/mmcblk0p1 rw rootwait net.ifnames=0 biosdevname=0
root@ccpe10c1a5:~# uname -a
Linux ccpe10c1a5 4.19.62-00036-gbc6a6e31fe72 #1 SMP PREEMPT Tue Jun 16 15:39:07 CST 2020 aarch64 aarch64 aarch64 GNU/Linux
root@ccpe10c1a5:~# free -m
              total        used        free      shared  buff/cache   available
Mem:            993          59         793           2         140         867
Swap:             0           0           0
root@ccpe10c1a5:/media/disk0# dmesg | grep -i panic
root@ccpe10c1a5:/media/disk0# w
 18:17:28 up 19 min,  1 user,  load average: 0.05, 0.03, 0.04
Posted (edited)
I'm not sure I follow. You have the factory OS (debian IIRC) on EMMC still and it is stable?? But Armbian on M2 does not boot and/or is unstable?
My setup has U-Boot loading systemd-boot via UEFI which then loads kernel. I also use Standard Boot so my entire bootcmd is simpy "bootflow scan -b". No complicated scripting. No loading things and calculating memory addresses. Moving away from all of that mess is really the primary motivation for building the firmware for this device in the first place. It is really nice--the only time I ever have to interact with u-boot is when I need to flash the firmware.
Edited by bschnei
Posted (edited)
Correct -- GTI ships it with Ubuntu.  Installing either of the Armbian supported models (Debian Trixie or Ubuntu Noble) on the SATA causes bootup issues.  The stock Ubuntu/eMMC boots up fine -- MOST of the time. i do get kernel panics sometimes even then.
On the stock install via eMMC:
root@ccpe10c1a5:~#   w
 04:41:40 up  8:24,  1 user,  load average: 0.00, 0.00, 0.00
root@ccpe10c1a5:~# lsb_release -d
Description:    Ubuntu 18.04 LTS
On the stock install, I was able to run a memtester test, 10 cycles, no errors.
The only thing i got was these xenon-sdhi errors every now and then during the test (below); not sure if it was relevant or not.
Although i have seen this when booting, before locking up:
[    3.650635] xenon-sdhci d00d8000.mmc: Timing issue might occur in DDR mode
So i'm thinking the hardware is actually OK.  It's got to be more a timing issue, or an overlap issue.  I restructured the booti components, so there should be no overlaps, though... leaving me with a boot timing issue.
Since the stock Ubuntu install fails via kernel panic at times, that's what I'm leaning towards.
I guess it could still be configuration in the device tree... i'm not familiar with how to tune those, so looks like I'm going to have to keep digging.
I'll have to look closer at what you're doing in ebu-bootloader... maybe it'll work around my issues somehow.
Thanks again for all the engagement!
E.g.,
Loop 10/10:
  Stuck Address       : ok
  Random Value        : ok
  Compare XOR         : ok
  Compare SUB         : ok
  Compare MUL         : ok
  Compare DIV         : ok
  Compare OR          : ok
  Compare AND         : ok
  Sequential Increment: ok
  Solid Bits          : ok
  Block Sequential    : setting   5[20847.635300] xenon-sdhci d00d8000.sdhci: eMMC PHY init cannot complete after 1 us
setting  91[20966.319305] xenon-sdhci d00d8000.sdhci: eMMC PHY init cannot complete after 1 us
setting 108[20989.955374] xenon-sdhci d00d8000.sdhci: eMMC PHY init cannot complete after 1 us
setting 160[21061.452841] xenon-sdhci d00d8000.sdhci: eMMC PHY init cannot complete after 1 us
ok
  Checkerboard        : ok
  Bit Spread          : ok
  Bit Flip            : setting 199[21753.608246] xenon-sdhci d00d8000.sdhci: eMMC PHY init cannot complete after 1 us
setting 256[21832.440524] xenon-sdhci d00d8000.sdhci: eMMC PHY init cannot complete after 1 us
ok
  Walking Ones        : ok
  Walking Zeroes      : ok
  8-bit Writes        : ok
  16-bit Writes       : ok
Done.
espressobin-ultra> grep sdhci Errors.txt
  Block Sequential    : setting  44[ 1160.445415] xenon-sdhci d00d8000.sdhci: eMMC PHY init cannot complete after 1 us
setting 104[ 1243.071074] xenon-sdhci d00d8000.sdhci: eMMC PHY init cannot complete after 1 us
  Bit Flip            : setting 207[ 2022.270265] xenon-sdhci d00d8000.sdhci: eMMC PHY init cannot complete after 1 us
setting 493[ 2419.709372] xenon-sdhci d00d8000.sdhci: eMMC PHY init cannot complete after 1 us
  Block Sequential    : setting  51[ 5613.205850] xenon-sdhci d00d8000.sdhci: eMMC PHY init cannot complete after 1 us
  Block Sequential    : setting  86[ 7831.212692] xenon-sdhci d00d8000.sdhci: eMMC PHY init cannot complete after 1 us
setting 114[ 7869.815417] xenon-sdhci d00d8000.sdhci: eMMC PHY init cannot complete after 1 us
setting 139[ 7904.632847] xenon-sdhci d00d8000.sdhci: eMMC PHY init cannot complete after 1 us
  Bit Flip            : setting 252[ 8698.620476] xenon-sdhci d00d8000.sdhci: eMMC PHY init cannot complete after 1 us
  Bit Flip            : setting 345[11019.588593] xenon-sdhci d00d8000.sdhci: eMMC PHY init cannot complete after 1 us
  Block Sequential    : setting 128[12258.573632] xenon-sdhci d00d8000.sdhci: eMMC PHY init cannot complete after 1 us
  Bit Flip            : tesetting 328[13172.479247] xenon-sdhci d00d8000.sdhci: eMMC PHY init cannot complete after 1 us
  Walking Zeroes      : setting 121[13773.551198] xenon-sdhci d00d8000.sdhci: eMMC PHY init cannot complete after 1 us
  Block Sequential    : setting  94[14421.542088] xenon-sdhci d00d8000.sdhci: eMMC PHY init cannot complete after 1 us
setting 241[14624.491234] xenon-sdhci d00d8000.sdhci: eMMC PHY init cannot complete after 1 us
  Solid Bits          : setting  33[16456.854416] xenon-sdhci d00d8000.sdhci: eMMC PHY init cannot complete after 1 us
  Block Sequential    : setting   7[16509.517668] xenon-sdhci d00d8000.sdhci: eMMC PHY init cannot complete after 1 us
setting 216[16797.761210] xenon-sdhci d00d8000.sdhci: eMMC PHY init cannot complete after 1 us
  Walking Ones        : setting  44[17908.735026] xenon-sdhci d00d8000.sdhci: eMMC PHY init cannot complete after 1 us
  Walking Zeroes      : setting  14[18044.789017] xenon-sdhci d00d8000.sdhci: eMMC PHY init cannot complete after 1 us
  Block Sequential    : setting 154[18905.444761] xenon-sdhci d00d8000.sdhci: eMMC PHY init cannot complete after 1 us
[18905.451549] xenon-sdhci d00d8000.sdhci: eMMC PHY init cannot complete after 1 us
setting 228[19007.479627] xenon-sdhci d00d8000.sdhci: eMMC PHY init cannot complete after 1 us
[19007.486828] xenon-sdhci d00d8000.sdhci: eMMC PHY init cannot complete after 1 us
  Bit Flip            : setting  14[19347.751784] xenon-sdhci d00d8000.sdhci: eMMC PHY init cannot complete after 1 us
setting 164[19556.154518] xenon-sdhci d00d8000.sdhci: eMMC PHY init cannot complete after 1 us
Edited by KV1
Clarified install config.
I get every boot so that should indeed be ignored. What do you mean by timing issue? I could build you a bootloader clocked at 800Mhz instead of 1.2Ghz if that is what you are referring to?
Moreso the timing of the boot sequence and device enablement.  The fact that i got the Debian-on-SATA to load ONE TIME strikes me as very odd.  The fact that i get kernel panics on the stock eMMC now and then, also strikes me as very odd.  I've tried using the different uboot clock-timing builds for DDR offered by armbian (
 ), but they all show the same thing... so i don't think it's the cpu/ddr timings.. i think its the bootup timings, or power configs or something introduced around pcie/sata since 4.x.   But clearly i'm shooting into the wind at this point.
I see. Well I can confirm my bootloader is very stable. I have been running it on two devices for a couple years now without any issues. It cannot hurt to flash it again (to rule out random bitflips), but if you are getting sporadic crashing no matter the kernel/OS it does start to indicate a hardware issue. I have a laptop that crashes sporadically but it isn't so bad that I cannot use it. I've run memtest on it countless times without issue, tried replacing RAM, etc. some devices really are just cursed for whatever reason unfortunately.
In case it is helpful, you can find the config for the kernel I run on my devices here: https://github.com/bschnei/linux-a3700
I tried using the 'bootflow scan -b` after getting the armbian efi build installed on the SATA, Grub came up fine, but it never made it past initrd loading... nothing further ever.
Using mox-imager and pushing your release image gave me a lot of stability for the standard eMMC install... Re-flashed that image, but didn't help... still panicing all the time -- different places -- with the 6.x kernels (6.12, 6.18, 6.19) on the Armbian install.
I've seen some comments about power draw / PSU issues in other threads, but i'm just using the stock PSU provided.
You're not doing anything special with Device Tree / Overlays are you?
The initrd might be missing needed drivers for you to continue getting console output. Kind of a pain to troubleshoot that. The kernel I linked above is configured so that it should actually boot with no initramfs at all (though that isn't recommended).
It  obviously can't hurt to try a different PSU if you have one. The device also will do PoE (on the WAN port I believe) which is a nice little feature so you could try that too.
The device tree I use comes directly from the linux tree. It is built into U-Boot and then U-Boot provides it to the kernel via standard location as specified in UEFI. It is entirely possible that older kernels might be unhappy with a newer device tree but you really shouldn't be having any issues with 6.18 and newer but they do need to be configured to load the device tree from UEFI. I think that kernel config option is CONFIG_OF.
