Console output while booting
Go to solution Solved by martinayotte,
I'm running a freshly installed armbian with mainline kernel 4.9.5 on my cubietruck.
Between u-boot messages and login prompt I don't get any output while booting.
I've tried several values for the "console" parameter in the armbianEnv.txt and recompiled the /boot/boot.scr file without success.
I've tested both VGA and HDMI (with an HDMI to VGA adapter) outputs without success too.
What should I do to get things to work please ?
Thanks for your time and your great work on armbian.
Problem solved after setting the "console" parameter to "display" instead of "both" in /boot/armbianEnv.txt and recompiling /boot/boot.scr
  • Solution
BTW, recompiling /boot/boot.scr is only needed after changes to /boot/boot.cmd. Changes to /boot/armbianEnv.txt doesn't requires recompiling.
