Hi all,
I need a help. I installed the armbian Debian Jessie 4.9.5 in my cubietruck. It is connected via HDMI. How do I set the output of sound to be HDMI?
Thanks and best regards
Hi Igor,
With armbian Debian 3.4.113 the cubietruck wifi not work but with mainline 4.9.5 it´s works. Is there any configuration for it to work in 3.4.113?
# iwconfig wlan0
wlan0     IEEE 802.11   Acess Point: Not-Associated
               Link Quality:0    Signal level:0   Noise level:0
               RX invalid nwid:0   invalid crypt:0   invalid misc:0
Do I need to load any modules?
I tried:
# modprobe bcmhd
Modprobe FATAL: Module bcmhd not found.
Thanks
We don't use that module since some time ... ap6211 and check if firmware is in place and loaded. In any case, logs would drastically help to see what's wrong  :)
armbianmonitor -u
Driver should be ap6210 ... sorry.
Check my bootlog. Wifi is working fine
http://sprunge.us/Beed
root@cubietruck:~# iwconfig wlan0
wlan0     IEEE 802.11  ESSID:"XXXXX"
          Mode:Master  Frequency:2.427 GHz  Access Point: XX:XX:XX:XX:XX:XX
          Bit Rate=65 Mb/s   Tx-Power:32 dBm
          Retry min limit:7   RTS thr:off   Fragment thr:off
          Encryption key:off
          Power Management:off
          Encryption key:off
Very strange. Can it be the cubietruck review?
I can not see the review of my cubietruck because it already came with the heatsink on the processor.
When I use mainline version 4.9.5, the wifi works correctly.
I am trying to connect cubietruck as a client of my routerboard.
I'll try some more tests here.
Anyway thanks for the help Igor.
