jobenvil Posted October 19, 2015 Posted October 19, 2015 I cannot understand how the drivers (dtb) could be choosen properly for banana pi pro. I download the 4.5 wheezy version for Banana Pi Pro but dmesg shows that the board is a "banana pi BP1-M1": [ 0.000000] Linux version 4.2.3-sunxi (root@production) (gcc version 4.8.2 (Ubuntu/Linaro 4.8.2-16ubuntu4) ) #2 SMP Sun Oct 11 14:12:18 CEST 2015 [ 0.000000] CPU: ARMv7 Processor [410fc074] revision 4 (ARMv7), cr=10c5387d [ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache [ 0.000000] Machine model: Banana Pi BPI-M1 I checked the /boot directory and I see that the script.bin is linked with "bananapi.bin" even inside /boot/bin we can find the "bananapipro.bin" file: root@bananapi:/boot# ls -ltr total 7396 -rwxr-xr-x 1 root root 5468416 Oct 11 14:12 vmlinuz-4.2.3-sunxi -rw-r--r-- 1 root root 1955569 Oct 11 14:12 System.map-4.2.3-sunxi -rw-r--r-- 1 root root 115484 Oct 11 14:12 config-4.2.3-sunxi lrwxrwxrwx 1 root root 25 Oct 11 19:10 zImage -> /boot/vmlinuz-4.2.3-sunxi drwxr-xr-x 2 root root 4096 Oct 11 19:10 dtb -rw-r--r-- 1 root root 6944 Oct 11 19:10 boot.bmp -rw-r--r-- 1 root root 1901 Oct 11 19:11 boot.cmd -rw-r--r-- 1 root root 1973 Oct 11 19:11 boot.scr drwxr-xr-x 2 root root 4096 Oct 11 19:11 bin lrwxrwxrwx 1 root root 25 Oct 19 11:23 script.bin -> /boot/bin/bananapi.bin I modified the link to point to bananapipro.bin, but theoretically this has no sense anymore because with this new kernel we use the dtb files and I see that in dmesg has nothing changed. Is my supposition correct? When I check the boot.cmd: --------- # Boot loader script to boot with different boot methods for old and new kernel #-------------------------------------------------------------------------------------------------------------------------------- if ext4load mmc 0 0x00000000 /boot/.next || fatload mmc 0 0x00000000 .next then # sunxi mainline kernel #-------------------------------------------------------------------------------------------------------------------------------- ext4load mmc 0 0x49000000 /boot/dtb/${fdtfile} || fatload mmc 0 0x49000000 /dtb/${fdtfile} ext4load mmc 0 0x46000000 /boot/zImage || fatload mmc 0 0x46000000 zImage env set fdt_high ffffffff bootz 0x46000000 - 0x49000000 #-------------------------------------------------------------------------------------------------------------------------------- else # sunxi android kernel #-------------------------------------------------------------------------------------------------------------------------------- ext4load mmc 0 0x43000000 /boot/script.bin || fatload mmc 0 0x43000000 script.bin ext4load mmc 0 0x48000000 /boot/zImage || fatload mmc 0 0x48000000 zImage bootz 0x48000000 I cannot understand how the boot process chooses the properly "sun7i-a20-bananapro.dtb" between all the *.dtb files: ... -rw-r--r-- 1 root root 27637 Oct 11 14:13 sun7i-a20-bananapro.dtb -rw-r--r-- 1 root root 27261 Oct 11 14:13 sun7i-a20-bananapi-r1.dtb -rw-r--r-- 1 root root 27902 Oct 11 14:13 sun7i-a20-bananapi-m1-plus.dtb -rw-r--r-- 1 root root 27145 Oct 11 14:13 sun7i-a20-bananapi.dtb -rw-r--r-- 1 root root 19291 Oct 11 14:13 sun6i-a31s-cs908.dtb -rw-r--r-- 1 root root 23022 Oct 11 14:13 sun6i-a31s-bananapi-m2.dtb ... and how to confirm it with CLI that I'm using the properly .dtb file after every kernel update. Thanks in advance!
Igor Posted October 19, 2015 Posted October 19, 2015 There is one image for all bananas and DTB file is encoded into u-boot. For bananapro you only need to change: ext4load mmc 0 0x49000000 /boot/dtb/${fdtfile} || fatload mmc 0 0x49000000 /dtb/${fdtfile} to ext4load mmc 0 0x49000000 /boot/dtb/sun7i-a20-bananapro.dtb || fatload mmc 0 0x49000000 /dtb/sun7i-a20-bananapro.dtb and recompile the boot.cmd to boot.scr as stated in file. reboot and you are done. 1
jobenvil Posted October 19, 2015 Author Posted October 19, 2015 (edited) There is one image for all bananas and DTB file is encoded into u-boot. For bananapro you only need to change: ext4load mmc 0 0x49000000 /boot/dtb/${fdtfile} || fatload mmc 0 0x49000000 /dtb/${fdtfile} to ext4load mmc 0 0x49000000 /boot/dtb/sun7i-a20-bananapro.dtb || fatload mmc 0 0x49000000 /dtb/sun7i-a20-bananapro.dtb and recompile the boot.cmd to boot.scr as stated in file. reboot and you are done. I got it, shame on me! thanx, thanx!! and thanx! this looks like much better now: [ 0.000000] Booting Linux on physical CPU 0x0 [ 0.000000] Initializing cgroup subsys cpuset [ 0.000000] Initializing cgroup subsys cpu [ 0.000000] Initializing cgroup subsys cpuacct [ 0.000000] Linux version 4.2.3-sunxi (root@production) (gcc version 4.8.2 (Ubuntu/Linaro 4.8.2-16ubuntu4) ) #2 SMP S un Oct 11 14:12:18 CEST 2015 [ 0.000000] CPU: ARMv7 Processor [410fc074] revision 4 (ARMv7), cr=10c5387d [ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache [ 0.000000] Machine model: LeMaker Banana Pro <=======================THANKS!!=================================== [ 0.000000] Memory policy: Data cache writealloc [ 0.000000] On node 0 totalpages: 262144 [ 0.000000] free_area_init_node: node 0, pgdat c0a2c800, node_mem_map eeef8000 Edited October 19, 2015 by jobenvil 1
Igor Posted October 19, 2015 Posted October 19, 2015 It's better to ask than wasting time I might solve this by some automatic hack in the future, but currently this is how things are.
matteobp Posted November 13, 2015 Posted November 13, 2015 Hi. I have a Banana Pi M1+, and I'm using Armbian_4.5_Bananapi_Debian_jessie_3.4.109. If I'm not mistaken the M1+ is very similar to PRO version. Also in my case the script.bin is linked with "bananapi.bin", but I have no /boot/dtb folder. Is it a feature available with 4.x kernel images? I've changed the script.bin to link "bananapipro.bin" and recompiled the boot.cmd to boot.scr. Is it correct? About this fix for the wi-fi apt-get install linux-image-banana do I have to apply it with "bananapi.bin" or "bananapipro.bin"? Thanks in advance.
