Hi,
Anyone can help me?
My chip is rk3229, wifi is esp8089 26Mhz, running 6.12.63 trixie.
I followed most of the instructions here without hope. My dmesg said "esp8089: unknown parameter 'crystal_26M_en' ignored" for:
options esp8089 crystal_26M_en=1
and "esp8089: unknown parameter 'config' ignored" for:
option esp8089 config=crystal_26M_en=1
modprobe parameter should be crystal=1, not crystal_26M_en anymore (see here)
Otherwise you could try led-conf6 overlay (but I don't know if it fits your board...) which has the attribute esp,crystal-26M-en = <1> in the device tree to set the crystal to 26 MHz
Hi,
So, Previously this massage (No emmc) appeared if the preinstalled Android was able to boot up completely and then restarted by repowering while the sdcard was inserted or the tvbox was rebooted while the sdcard was in the slot, however this got fixed if the device was powered off during the android bootanimation but after accidentally installing an incomplete image of latest armbian release I am no longer able to get the emmc working even after trying restarting at various boot levels.
I have found others experiencing the same issue in this post but according to the circumstances I am in I think my issue might have a different solution.
Any way through which this issue can be solved ?
This might help :
root@multitool:~# dmesg -T | grep mmc2
[Tue Jan 6 21:06:28 2026] mmc_host mmc2: Bus speed (slot 0) = 2343750Hz (slot req 400000Hz, actual 390625HZ div = 3)
[Tue Jan 6 21:06:28 2026] mmc_host mmc2: Bus speed (slot 0) = 50000000Hz (slot req 50000000Hz, actual 50000000HZ div = 0)
[Tue Jan 6 21:06:28 2026] mmc2: Card stuck in programming state! __mmc_switch
[Tue Jan 6 21:06:28 2026] mmc2: error -110 whilst initialising MMC card
I have also attached the whole dmesg log and lsblk output if needed.
multitool-ssh-output.txt
Just to add, Armbian boots upto systemd and then gets stuck at loading some scripts.
This image gives some additional information.
I solved the issue !
I flashed the latest armbian release raw image to the sdcard and plugged it in the TV box. It magically booted from the SDCard and now I have mmcblk2 as a block device. Now I can run armbian-install command to get everything going correctly.
Also, this TVBOX contains the less known S9012P wifi chip. However on this github repository some kind of unofficial driver support is available, can this driver get the wifi chip working on Armbian ?
Hey there forum!
I've got this MXQ PRO 5G TV Box (Yes, I know It's been said the brand isn't important, but I figured I might as well say it anyways) thing a few days ago and, as you do, my first instinct was 'Let's linux it', which Is, as It turns out far more trouble than I had initially imagined. And frankly I am a little tired of slamming my head into a brick wall, repeating the same steps again and again so as a sort of last resort, I'm here to ask for your help (thanks in advance).
To check which image to download and what steps to follow I've opened the box to take a peek at It's board. As the main CPU, RK3228A, for the storage 128GB of eMMC, and for the memory 8GB of RAM (which exactly type, I can't discover).
Following the instructions on the first page of this topic, I downloaded an image, downloaded multitool, got my SD card. At first everything went according to the guide. Multitool flashed, the thing booted It and the partition expanded, then I shut it down and put the extracted .img into the 'images' folder, plug the card back in boot, flash, shut down once more and upon trying to boot, the LED stays off and doesn't turn on. After waiting for a solid 10 minutes I decide I'll just try booting it directly off the card. I flash It, plug it in and some images booted partially and some didn't. Some boot only to a certain point like starting a specific service (usually it got stuck after or during starting armbian-ramlog.service) and some just don't boot at all. I've tried disabling the services by manipulating the files on the card yet they just reappear again.
After that I noticed that upon each boot there's a quick 'error' that happens, returning different numbers seemingly depending on the image on the card, either Internal error: Oops: 805 [#1] SMP ARM, or Oops: 80000005 SMP ARM or just Oops 5 which as far as I could find meant something related to illegal instructions (specifically interrupts). I haven't really made any progress past that. Also, If It's of any help, I can provide images of the board (from both sides) and all of It's components.
Thanks in advance for all your help, friends!
vor 34 Minuten schrieb Dangrain:
MXQ PRO 5G TV Box (
 this looks like we mention many times that OPTEE or Secureboot interrupte the boot at diffirent time
you say 128GB and 8 GB , thats not possible with rk3228 it can handle only 1GByte RAM (8Gbits)  (maybe you mean Gbit than 8Gbit = 1GByte Ram Looks ok )
Oh yes, forgive me, I must've been mistaken!
Anywho, mind telling me what I can do about Secureboot or OPTEE you mention?
Posted (edited)
vor 7 Stunden schrieb Dangrain:
please look herer , maybe some post later and newer
Some OPTEE Loader work 1min , one 30min ,
in the past same game was with trustOS (bootloader) there are two or three diffirrent
Edited by RaptorSDS
Posted (edited)
Quote
I've read that page and I can't seem to get it working with the image both jock and Victor Picinin recommended yet it doesn't boot off the eMMC nor the SD.
I'm at the end of my rope!
Edited by Dangrain
11 hours ago, digital said:
I have Dolamee D5 box. The legacy kernel 4.4.194-rk322x boots ok, but newer images from @jock or my own built image does not see EMMC. Any ideas? dmesgs attached.
hello @digital, in some rare cases there are some minor trickeries to try and improve compatibility with eMMC.
If you run rk322x-config, there is a panel dedicated to eMMC which allows you to select some compatiblity options, like emmc-pins and DDR/UHS modes. You may try first enabling emmc-pins and rebooting to see if it gets recognized. Anyway photos of the board and the original stock device tree could be useful to identify the compatibility problem.
Thanks, but I cannot run rk322x-config (or can I without being fully booted?). I suppose I can try in overlays=... line in /boot/armbianEnv.txt, but what should I write here?
Can't you run on sdcard? It is heavily suggested to run on sdcard before installing on emmc.
However the overlay is emmc-pins
Hi, still stuck on my Iconbit XDS16 (T95D数码管-201701111-V1.0 blue board).
Multitool menu loads, but mmcblk2 has no partitions at all (only mmcblk0p2).
lsblk -f output:
NAME         FSTYPE LABEL UUID FSAVAIL FSUSE% MOUNTPOINT
mmcblk0
|-mmcblk0p1
`-mmcblk0p2                          0   100% /
mmcblk2
mmcblk2boot0
mmcblk2boot1
mmcblk2rpmb
Is there a specific DTB for this board that makes eMMC visible in Multitool?
Thanks!
vor 1 Stunde schrieb araksys64:
 i think i have a identical box out of my 3 other , this board is i thing NAND memory no eMMC , its only supportet by legacy Firmware kernel <4.x
If the internal storage has android installed then it doesn't needs to have a partition table. Multiple partitions show up in android because the partition offset and size is passed with kernel commandline, you can just backup the mmc as a raw image and restore it as it is anytime later.
Multitool or Armbian can't recognize the partitions of Android in this tvbox as they need a partition table to be present in the initial bytes else they treat the whole mmc as raw data.
Also, mmcblk2boot0 and mmcblk2boot1 should either have the bootloader or in my case were filled with null bytes.
mmcblk2rpmb probably has something to do with TEE OS.
Having a backup of mmcblk2 is what that matters
The problem is that I wanted to change the fingerprint and changed build.prop. After that, the console boots up, but the launcher does not start. I can only access the settings. And I can't connect to the console to restore the build.prop backup. As I understand it, it is impossible to connect to this console via adb, and multitool also cannot see the internal memory. Are there any options for editing build.prop?
You can backup the mmc using multitool script and on a pc or phone extract the resulting gz file. Then from this raw disk image you need to get the offset and size of the system partition and then use dd to get the system partition out. After that you can make changes to files in the raw partition image and write the whole image back to the same offset. Never tried something like this but if it is possible to get into recovery mode and try if adb over usb is available then editing the system partition would be easier.
The first method might worsen things so having the gz file saved at a safe place will be better
I once got the TVBOX to boot into recovery by flashing the raw mmc image directly to a sdcard and then powering on the tvbox with the sdcard
I'll buy a new USB cable today and try connecting via ADB again. I can't even find the original firmware for this console. It seems like a trivial task to restore build.prop, but it's already driving me crazy. It won't connect via ADB, I can't find the firmware for this device, and it doesn't see the internal memory via Multitool. I'm at a dead end.
Hello, I just created this account!
I just want to ask if the newer OS / Firmware has VPU + MPP support? I've been trying to build OpenAuto for the RK3229 and the only issue im having is the lack of h264 decoding (i only need h264, but it would be nice to have a full support)
I'm using the latest trixie (minimal) with somewhat of a success, except for a laggy video decoding due to again lack of h264.
I can't seem to find an older build with a kernel of 4.4.xxx that probably has the full GPU support with VPU + MPP working.
@Harleyyyu  See this thread; hardware video decoding works fine with mainline kernel and does not need vendor MPP. Debian Trixie although has a "broken" mpv that won't work, better stay with Bookworm
