Amir Samadpour Posted December 28, 2025 Posted December 28, 2025 good morning/evening lads can anyone help me on unbricking this? already tried sd card with multitool , no boot with or without sd card(blue and red light are steady and doesn't get bright , no display). looks like its an emmc chip (i brick it on image burning process ) images of the board: https://ibb.co/rRGxJfZ1 https://ibb.co/3524sZCQ https://ibb.co/yBBNYmbG 0 Quote
Euuaak Posted December 29, 2025 Posted December 29, 2025 Hello! It seems that there is some issue with the user files FTP server. The multitool image should be acessessible from: https://users.armbian.com/jock/web/rk322x/multitool/ But it is present in: https://users.armbian.com/users.armbian.com/jock/web/rk322x/multitool/ 0 Quote
Kuroi Akuma Posted January 3 Posted January 3 Hi, Anyone can help me? My chip is rk3229, wifi is esp8089 26Mhz, running 6.12.63 trixie. I followed most of the instructions here without hope. My dmesg said "esp8089: unknown parameter 'crystal_26M_en' ignored" for: options esp8089 crystal_26M_en=1 and "esp8089: unknown parameter 'config' ignored" for: option esp8089 config=crystal_26M_en=1 0 Quote
RaptorSDS Posted Saturday at 02:39 PM Posted Saturday at 02:39 PM fast search found that 8089 use 40Mhz not 26 so its ignored https://lists.infradead.org/pipermail/linux-arm-kernel/2016-August/447345.html was a talk on kernel developer , some 8089 ignore also 40Mhz some need also 8622 need some 26Mhz or not 1 Quote
Kuroi Akuma Posted Saturday at 03:10 PM Posted Saturday at 03:10 PM (edited) This is my wifi. On legacy image, wifi works if I edit /etc/modprobe.d/esp8089.conf to crystal_26M_en=1. Edited Saturday at 03:23 PM by Kuroi Akuma 0 Quote
jock Posted Saturday at 04:36 PM Author Posted Saturday at 04:36 PM 2 hours ago, Kuroi Akuma said: I followed most of the instructions here without hope. My dmesg said "esp8089: unknown parameter 'crystal_26M_en' ignored" for: options esp8089 crystal_26M_en=1 and "esp8089: unknown parameter 'config' ignored" for: option esp8089 config=crystal_26M_en=1 modprobe parameter should be crystal=1, not crystal_26M_en anymore (see here) Otherwise you could try led-conf6 overlay (but I don't know if it fits your board...) which has the attribute esp,crystal-26M-en = <1> in the device tree to set the crystal to 26 MHz 1 Quote
Kuroi Akuma Posted Sunday at 03:51 AM Posted Sunday at 03:51 AM Thank you. I'm gonna try that. 0 Quote
rk32 Posted Tuesday at 09:56 PM Posted Tuesday at 09:56 PM Hi, So, Previously this massage (No emmc) appeared if the preinstalled Android was able to boot up completely and then restarted by repowering while the sdcard was inserted or the tvbox was rebooted while the sdcard was in the slot, however this got fixed if the device was powered off during the android bootanimation but after accidentally installing an incomplete image of latest armbian release I am no longer able to get the emmc working even after trying restarting at various boot levels. I have found others experiencing the same issue in this post but according to the circumstances I am in I think my issue might have a different solution. Any way through which this issue can be solved ? This might help : root@multitool:~# dmesg -T | grep mmc2 [Tue Jan 6 21:06:28 2026] mmc_host mmc2: Bus speed (slot 0) = 2343750Hz (slot req 400000Hz, actual 390625HZ div = 3) [Tue Jan 6 21:06:28 2026] mmc_host mmc2: Bus speed (slot 0) = 50000000Hz (slot req 50000000Hz, actual 50000000HZ div = 0) [Tue Jan 6 21:06:28 2026] mmc2: Card stuck in programming state! __mmc_switch [Tue Jan 6 21:06:28 2026] mmc2: error -110 whilst initialising MMC card I have also attached the whole dmesg log and lsblk output if needed. multitool-ssh-output.txt 0 Quote
rk32 Posted Tuesday at 10:08 PM Posted Tuesday at 10:08 PM Just to add, Armbian boots upto systemd and then gets stuck at loading some scripts. This image gives some additional information. 0 Quote
rk32 Posted 17 hours ago Posted 17 hours ago I solved the issue ! I flashed the latest armbian release raw image to the sdcard and plugged it in the TV box. It magically booted from the SDCard and now I have mmcblk2 as a block device. Now I can run armbian-install command to get everything going correctly. 1 Quote
rk32 Posted 16 hours ago Posted 16 hours ago Also, this TVBOX contains the less known S9012P wifi chip. However on this github repository some kind of unofficial driver support is available, can this driver get the wifi chip working on Armbian ? 0 Quote
